Question about Electrical Supplies
I have a KDE480SS3 KIPOR. ITS CONTROL PANEL IS SHOWING "ERROR 27"?
2 Suggested Answers
  • 163 Answers
SOURCE: "Error code 27" coming on the generator control panel. KDE480SS3 GENERATOR
http://www.briggsandstratton.com/lam/es/support/faqs/home-standby-generator-fault-codes
This should help you
Sir Dana Taylor
IQ397
Posted on Apr 24, 2017
How to reset Kipor KDE6700TA P06 emergency stop code.
Error P-06 is the failure of the emergency stopping button. Replace the emergency stopping button or if possible check for repair.then by pushing rest/clear button reset the alarm and start the engine. https://assets-cf.criticalpowersupplies.co.uk/.../Kaipor_KDE12STA3_Silent_Generator.
Oct 27, 2017 | Kipor Electrical Supplies
My Kipor KDE16STA3 shows p03 error after 15 min runing and shuts down after 3 sec.The voltage drops to 30,40 whta's happening?
[PDF]DIESEL GENERATING SET
www.kipor.com/upload/spec2011053011590766.pdf
3/KDE16STA3/ ..... P-03 Undervoltage: Indicating voltage higher (lower), the generator will self- braking. P-04 Generator ... KDE16STA3 KDE19STA KDE19STA3.
[PDF]2
www.kipor.com/upload/spec2011061109073968.pdf
P-03. Decrease load less than the related load, turn on the breaker. P-04. Replace the fuse of the same type. Check the circuit and inserter. Replace the starting ...
Oct 31, 2015 | Kipor Electrical Supplies
My Kipor KDE19STA3 shows lower voltage on one of three phases in control pannel and keep shutting down. Voltage is actually OK on all 3 phases, if I measure it with my voltmeter. I need to adjust measuring...
There is no way to adjust voltage on just one phase. I would check voltage sensing leads and check to see if there is a way to calibrate. Otherwise it sounds like a logic problem.
Jul 08, 2011 | Electrical Supplies
My oven beeps and show error code F7 on the panel. Help!!!
Hello & Welcome to FixYa
F7 error code is displayed when the clock assembly/electronic range control (ERC) goes bad and needs replacement. Please get back to me if you have any other questions.
Kevin
Dec 02, 2010 | GE 27" Built-In Double Electric Convection...
I have a kipor power with a fault code p-03 and it shuts off after a cople of secends . what could be the problem.i found in a forum that the posible cause could de the avr put i do not no were its located...
press and hold the function button turn on the ignition and hold until it ges into test mode should display something like ph 2 then start it up and test the output voltage and wether or not it produces power correctly. if it does test the output voltage with a multimeter to confirm the output is the same as displayed on the machine if not remove the control panel and adjust the trim pot on the rear of the display panel until it displays correctly,
if not it could be the carbon brushes in the altenator or the avr which is a black box bolted to the frame
Mar 09, 2010 | Kipor Electrical Supplies
Kipor 6700TA displaying charge fault (P5)
Check for loose or rusty battery cables. Unscrew the rear cover and locate the red battery wire. Disconnect it and, using a multi meter, check its resistance: it should have a very low value. Do the same with the other wire.
Start the generator and remove battery wires. If the voltage between them is zero then a fuse is blown.
Next open the front panel (where the display is), there you will find two blue wires with covered fuses, check and replace those fuses if found faulty.
If the problem is still there then it could be the charge regulator. Open the back cover by removing the six nuts. Near the edge you will find a component with silver cover resembling plates. There are three wires leading from it. Check resistance between these wires (one by one) and its body: it should be infinite, if not then replace it. remove the charge regulator and take it to a generator spare shop. The person there will further inspect it and will tell you if you need to replace it or repair it.
Hope this solves your problem.
Thank you for using fixya!
Aug 18, 2009 | Electrical Supplies
Electrical Supplies Logo
Top Electrical Supplies Experts
ken skalski
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
