Question about The Office Equipment & Supplies
I have a KDE480SS3 GENERATOR. THE CONTROL PANEL IS SHOWING "ERROR 27"
2 Suggested Answers
  • 163 Answers
SOURCE: "Error code 27" coming on the generator control panel. KDE480SS3 GENERATOR
http://www.briggsandstratton.com/lam/es/support/faqs/home-standby-generator-fault-codes
This should help you
Sir Dana Taylor
IQ397
Posted on Apr 24, 2017
Tip
ERROR codes Canon 9800
Canon 9800 E000 The surface temperature of the fixing assembly upper roller fails to rise by a specified value within 90 sec after power-on. The surface temperature of the fixing assembly upper roller fails to reach 150 C within 8 min after power-on. E001 The surface temperature of the fixing assembly upper roller exceeds 250 C. E005 The cleaning belt inside the fixing assembly has been taken up more than a specified length. E010 After generation of the main motor drive signal, two or more pulses are not received within 2 sec. E013 The error detection circuit on the waste toner feed motor driver PCB has detected an overcurrent. E020 The accumulative time during which the toner supply signal (TSP) has been generated by the developing assembly reaches 3 min*. E050 The holding tray home position signal (THP) is not generated within 4 sec while the holding tray motor drive signal (TMDP1, 2) is being generated. The holding tray home position signal (THP) is generated 1 sec or more while the holding tray motor drive signal (TMDP1, 2) is being generated. E203 Input of two or more clock pulses is not received within 2 sec from the scanner motor drive signal is generated. E210 The lens home position signal (LHP) is not generated within 4.8 sec after power switch or door switch has gone ON. The lens home position signal (LHP) is generate 2 sec or more. E240 An error has occurred in the microprocessor on the DC controller PCB. E243 An error has occurred in the microprocessor of the DC controller PCB and the microprocessor in the control panel. E710 An error has occurred in the communication between the DC controller PCB and the controller PCB of the option, and the DC controller has detected the error. E712 No communication is perceived from the RF controller PCB for 200 ms or more the communication is monitored at all times.
on Jan 19, 2010 | Office Equipment & Supplies
Tip
ERROR codes Canon 8530
Canon 8530 E000 The surface temperature of the fixing assembly upper roller fails to rise by a specified value within 90 sec after power-on. The surface temperature of the fixing assembly upper roller fails to reach 150 C within 8 min after power -on. The surface temperature of the fixing assembly upper roller fails to reach 180 C within 5 min after it has reached 150 C. The surface temperature of the fixing assembly upper roller falls below 50 C in standby. E001 The surface temperature of the fixing assembly upper roller exceeds 250 C. E005 The cleaning belt inside the fixing assembly has been taken up more than a specified length. E010 After generation of the main motor drive signal, two or more pulses are not received within 2 sec. E020 The accumulative time during which the toner supply signal (TSP) has been generated by the developing assembly reaches 3 min. E050 The holding tray home position signal (THP) is not generated within 4 sec while the holding tray motor drive signal (TMDP1,2) is being generated. The holding tray home position signal (THP) is generated 1 sec or more while the holding tray motor drive signal (TMDP1.2) is being generated. E13 The error detection circuit on the waste toner feed motor driver PCB has detected on overcurrent. E203 Input of two or more clock pulses is not received within 2 sec from the scanner motor drive signal is generated. E210 The lens home position signal (LHP) is not generated within 4.8 sec after the power switch or door switch has gone ON. The lens home position signal (LHP) is generate 2 sec or more. E240 An error has occurred in the microprocessor on the DC controller PCB. E243 An error has occurred in the communication between the microprocessor of the DC controller PCB and the microprocessor in the control panel. E710 An error has occurred in the communication between the DC controller PCB and the controller PCB of the option, and the DC controller has detected the error.
Indesit Washing Machines
27 KVA is a huge generator and should work just as well as the grid. The only thing I can think of is the startup current, which can easily be 5 times the running current is playing havoc.
You might try tightening up all your lugs and screws in your panel. A loose neutral can create some truly weird problems.
Oct 29, 2013 | Indesit Washing Machines
Top oven temp display shows 4444
Control panel needs to be replaced. It may also be an error code for the repairman.
Jul 22, 2012 | Neff U1661 Double circotherm super...
My oven beeps and show error code F7 on the panel. Help!!!
Hello & Welcome to FixYa
F7 error code is displayed when the clock assembly/electronic range control (ERC) goes bad and needs replacement. Please get back to me if you have any other questions.
Kevin
Dec 02, 2010 | GE 27" Built-In Double Electric Convection...
TTMPL code showing on my Signature series control panel. ???
I have a Thermasol steam generator which had the error code TTMPL and it had to be replaced by the manufacturer. From memory, the error code might stand for "tank temperature monitor pressure low" or something similar. As an aside, the replacement generator just started to show the same error message -- so now I'm two for two -- and not entirely happy.
Jan 16, 2010 | Thermasol Steam Bath Generators - Ambiance...
F4
The F4 error code generally means a bad temperature sensor or a short in leads to the sensor. Under room temperature conditions the resistance should be approximately 1100 ohms. If you are not comfortable around electrical apparatus and/or don't have an ohmmeter, you will need to contact an appliance repair technician. GE typically places a trouble shooting guide in the top of their ovens behind the touchpanel. You will have to remove three screws in the bottom of the touchpanel to open the panel. Be sure and turn off the power before opening the touchpanel!!!
Aug 23, 2007 | GE JTP85 Electric Double Oven
24 people viewed this question
Top The Office Equipment & Supplies Experts
Gareth Cockram
Gareth Cockram
Tygh Duval
Tygh Duval
Jerry Greenberg
Jerry Greenberg
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
