Explaining an error code on wash/machine 00101011
2 Suggested Answers
  • 99 Answers
SOURCE: Samsung front load washing machine model wf42h5000a. During rinse cycle machine stops and displays error code e4 and Cannot be reset.explain error code. What are possible solutions ?
The 4E error indicates that the washing machine has detected that there is a problem with the water supply.
The most common reason for a 4E error is a blocked or kinked water supply hose.
Follow these checks:
1. Check that the water tap connected to the washing machine is open to full.
2. Check that there are no kinks or bents in the water hose connected to the machine.
3. Check to see if the water hose mesh filter is not blocked. You should clean the water hose mesh filter at least twice a year to prevent build up.
Follow the below steps to clean a blocked water hose mesh filter.
1. Turn off the water source to the washing machine.
2. Unscrew the hose from the back of the washing machine.
3. With a pair of pliers, gently pull out the mesh filter from the end of the hose, then rinse it under the tap, until it is clean.
4. Push the filter back into place.
5. Screw the hose back onto the washing machine.
6. Turn on the tap and then make sure the connections are watertight.
7. Switch the power button off then on again.
This should resolve your problem.
Hope this helps
David
Posted on Nov 27, 2017
What does Code E:00 mean on a Bosch washing machine 7kg WAK2020SME?
It is strange, but this error code should not exist.
I found a youtube film, explaining most codes and what you can do to solve it. Take care, when you don't have the correct skills, ask a tech.
How to Identify an Error Code on Bosch Washing Machine
Apr 26, 2015 | Bosch Washing Machines
We are getting an LE error on a LG WT R852 washing machine
Here is a tip that explains what the LE error code means.....
LG Washing Machine LE Error Code or Fault Code
heatman101
Aug 13, 2011 | Washing Machines
LG washing machine loud and error code LE
heatman101
Jul 02, 2011 | LG WM2301HW Front Load Washer
Code F
These units have several very common error codes. the most common being error code F1. Oasis washer repair is simple. The link below has a video that explains how to replace the main control board on a Oasis washing machine.
Oasis Washing Machine Repair Video
http://www.appliancerepairlesson.com/
Mar 15, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
Fp excellence 7.5kg starts filling then stops, tries again a few times shorter each time and then errors with following led pattern: 00101011. We have levelled and tried over and over again, very...
Fault code 43
OOB switch error (out of balance)
CHeck Bowl Is Balanced Check Bias Spring is keeing bowl central
Most Likely Cause Corred terminals on Out Of balnce micro-switch
Jan 01, 2011 | Fisher and Paykel (IWL12)
What does error code LE mean?
heatman101
Sep 20, 2010 | LG Washing Machines
No spinning action on my MW511 Fisher and Paykell Wash Machine. Drains water ok. Then shows small beginning of back/ forth agitation - but not progressing to full spin mode. Warning lights showing...
Hi just read your posting.Now with the error code you have shown it tells me you have an out of balance fault.To find out if the fault is with the out of balance switch or the motor controller you will need an electrical test meter. the reason for this is to test the switch for conductivity,not to test for power or anything dangerous.Have you or can you borrow an electrical test meter to test the switch?please reply and I can guide you throe the repair of this fault.
Jun 14, 2010 | Fisher and Paykel GWL11 Top Load Washer
Washing Machines Logo
29 people viewed this question
Top Washing Machines Experts
