Question about Radio Communications
How do you turn beeping call noise off everytime u key the mic to talk?
    Master:
  • 604 Answers
Read your manual
Posted on Apr 25, 2017
Radio beeps after you release push to talk
Might be a low battery warning. Try swapping battery.
Mar 20, 2014 | Motorola CLS 1410 (4 Channels) 2-Way Radio
Have a 99v was talking one nite talking great turn it off then back on no modulation check and change mics.still no mod.what should i look for ?
Check the mic gain.
Make sure it is not in PA mode.
Make sure the mic jack in the radio doesn't have a broke or loose wire.
Those are a few things I can think of based on the information given. More information is needed if these will no solve the problem.
Does it turn on?
Does it key up?
If it keys up is there carrier?
How many watts is the carrier?
Are there any mods done to the radio?
Does it have a roger beep installed? What kind?
Does it have an echo board install? What kind?
Did you do the mod or some one else?
What is your SWR?
Is the display flashing when you key it?
Are the displays lit at all?
Did you disconnect the power cord after you turned it off, and reconnect it?
What channel are you keying up on.
Was/is the case off the radio when you tried it or were you working on it at the time of the failure?
What mics have you tried.
are you using talk back?
did you some one on another radio tell you they do not hear you, or are you going by no swing on the meter in the radio?
Could the meter be bad?
Jul 31, 2011 | Galaxy Radios DX-99V 40-Channels Base CB...
I have a uniden grant and i have wired a galaxy power desk mic with rogger beep when ever i key it up it squeals was wondering is there a way to fix that
yeah your mic gain is way too high. You can either turn off talk back if you can, or turn the gain down. Depending on how loud the talk back is, your audio may suffer. If that is the case, you will not be able to run that mic. Get an RK-56 or a Skythumper mic. They are noise canceling. You will get no squeal with that mic, and it will sound awesome.
If you really want a roger beep, take it to a tech and them install one.
Oct 23, 2010 | Galaxy Radios DX-66V Base CB Radio
When pa is on all i get is a shrill noise when i key the mike to talk what is the problem
TURN DOWN THE VOLUME ! ! ! You are getting feedback thru the mic because the speaker is too close to the mic.
Nov 20, 2009 | Cobra 19 DX III 40-Channels Base CB Radio
Superstar 121 with astatic power mic and texas star dx 500 power..when I key up to talk they say I sound like I'm a ways from the mic, but I have a loud roger beep...any ideas....mic?...
try a stock mike or a noise canceling one. Hard to run power on top of power. And see what your radio is dead keying into the radio...usally with a 500 it can take up to a 6 watt dead key.
Nov 10, 2009 | Superstar SS-121 120-Channels Base CB...
The mic doesnt work ...it use to but all the sudden it quit doesnt even key up so i can hear it my talk back
First, try another mic on the radio to be sure it's the mic and not the radio causing the problem. If it's the mic, check the wiring circuits for a bad switch or broken wire. Simply...the TX circuit is closed and the RX is open when the key is squeezed. The RX circuit is closed and the TX circuit is open when the key is released. Use a simple ohm meter to check for resistance between the pins on the mic (after removal from the radio of course). Open circuit will read 1, closed circuit should be very close to zero. You'll probably find the TX circuit never closes when the key is squeezed. Could be a broken wire or faulty switch in the handset.
Also check...If the mic "keys up"...you see the meter move normally, but no voice...it's either a faulty mic element (the little round thing you talk into) or the audio circuit of the radio has a defective component which a good CB shop can replace.
Jun 14, 2009 | Astatic 636L Noise Canceling Microphone...
The marine cb radio turns on but you can't here noboby talking nor can u talk out from the cb
Sound like either an antenna problem, or a mic problem.
The mic on most cb's also serve as transmit/receive switching. A broken wire or bad switch in the mic or cord can cause either or both to fail.
If you have a bad antenna (or cable), you should still hear squelch noise on receive (maybe lower in volume) and be able key the mic and get a transmit light on the unit. Visually inspect the connector, cable and antenna. If need be use an swr meter to prove the antenna system is bad.
Hope that helped...
Geno
Aug 01, 2008 | Audio Players & Recorders
Connex 4300
Check for proper shielding,ground, turn mic gain down, move mike farther away from radio, turn off other accessories nearby-ie.-am/fm radio
Apr 02, 2008 | Connex 4400 320-Channels Base CB Radio
Radio Communications Logo
32 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
