Cars & Trucks Logo
Michael Reeves Posted on Jul 24, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Floor board wet drivers side. No drain tube for ac condensor. Not losing radiator water. Ac condensor not draing to outside. No tube on firewall. 4.2 dohc model
  • Michael Reeves
    Michael Reeves Jul 25, 2009
    Finally found the drain. Small and hidden, hard to get to. It wasn't clogged but yet the water came in the car when it wasn't raining. Strange.
Josue Almodovar
Level 3:
  • Master 298 Answers
  • Posted on Jul 24, 2009
Josue Almodovar
Master
Level 3:
Answers
298
Questions
0
Helped
156321
Points
1047
All of dodge models have a drain tube you'll find it over the rack n pinion on the right side passenger but you have to see when does the water comes in the floor board, when you use the AC or when it rains if it's the AC then it's you drain if it's when it rains then you have to check for leaks on your windshield or fire wall
1helpful
2answers
Water leak on drivers side in my 1999 Honda Civic DX Coupe
Go to the passenger side or driver side there you need to find the A/C drain tube make sure that it is draining outside and not in the compartment area.This drain hose tends to pop out, so when you have the A.C on you notice there is water draining out but in your case its going in thhe car.
3helpful
3answers
WET CARPET ON DRIVER'S SIDE
Could be the drain for the ac is plugged up. Usually when this happens the passenger side floor gets wet, but it could be coming out on the driver's side when you take a right turn.
The drain should be on the bottom of the firewall near the floor, you should see water dripping onto the ground when the ac is on.
2answers
Keep getting clear water in drivers side floor board, hasn't rained in days, is it something to do with the ac??....No holes found in floor board or firewall
Drain tube for your AC likely has debris or possibly a bug has made a home in there. Have it cleaned and see if it still drains.
2helpful
2answers
Water on the floor with air conditioner
have the AC evaporator (found under the dash) inspected. It may need cleaning or the drains may have fallen out of place.
2answers
AC is leaking water onto the floor on the passenger side, some said the drain line could be plugged?
Yes, the weep drain. Inside the engine compartment, on the firewall, passenger side, half way between top and bottom of firewall. Small rubber tube comes out, then does a 90* turn towards the ground then just stops. You can remove the weep drain and clean it, or use wire to "poke" around and break up the debris. I suggest removing it.
1helpful
We found water & mildew on floor board of passanger side of 2001 Chevy Blazer LS. We figured that the a/c evaporator line is clogged, but where is it located? How do you get to it? Any info greatly...
The ac drains to the outside thru the firewall under the outside part of the heat/ac box under the hood. Tube can get clogged. Does your car have a sun roof? the drain tubes on a sun roof can also come off and put water into the cabin.
3helpful
2answers
Location of ac drain to try and stop wet floor board on 98 tj?
The problem is with the evaporator drain. There is a, (usually soft flexable), tube that drains condensation from the evaporator to the outside. It is located in the passenger compartment, under the dash. The hose has, (A)-became disconnected from the evaporator. (B)- Has gotten a kink in it. (C)-Became clogged, causing the evaporator to overflow into your passenger floorboard. Your vehicle probably has some covers over these components, you will likely have to remove. Locate the hose, it typically drains just behind and inside your right front wheel. It may be concealed behind a kick panel, or may go thru the floor or firewall. You must find it and follow it to the evaporator and make sure it is not clogged or kinked and is properly connected to the evaporator.
3answers
Wet spot on passenger floor board and its not antifreeze could it be condensate
sounds like it check the a/c fluid drain for any restriction, or leaks
1helpful
2answers
Air condition leaks into driver side and rear floor board
The evaporator box drain is stopped up.Under hood,under the firewall,right below the ac lines,you will find the drain.Take a small wire,like balin wire and move it in and out of the drain hole to relieve the water,it will pour out pretty good.If this doesn`t work,try compressed air pressure.I hope this helps.
3helpful
3answers
Wet on Passenger side floor when AC is on
Auto ac units have an outside drain for the condensation. If you ever noticed a car running and it looks like it's leaking something on a hot day it's the condensed water from the ac unit draining. What you have is a clogged or disconnected drain hose.
You need to find the hose and drain and reconnect them. Sounds simple, good luck.
Top Dodge Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Dodge Expert? Answer questions, earn points and help others
