Question about LG Washing Machines
Need change pump on lg wt-r854 washing mc fixings all rusted can the plate be removed with pump attached?
3 Suggested Answers
  • 11 Answers
SOURCE: I have an LG Wt-R854 turbo drum but it wont wash after it is filled. Nothing in the manual helps.
try filling it halfway first and if that works let it fill up all the way. Good luck
Posted on Jan 02, 2015
  • 9771 Answers
SOURCE: LG WT-R854 top loader has an Error Message A Have done extensive google search but no info on this error code. Any ideas?
LG WT R854 Owner Manual Troubleshooting This should help.
Posted on Jun 26, 2017
Testimonial: "Hi Lawrence, had a read of the manual and the specific error code (A) is not described. However i have done some further research and found the following procedure to reset the washing machine. This then revealed the correct error code for which i can commence repairs. The reset procedure is as follows: How to reset the washing machine: 1. Press POWER to turn the washer off. 2. Unplug the washer from the power outlet or turn the power switch to the unit off. 3. With the power disabled, press and hold the START/PAUSE button for 5 seconds. 4. Plug the washer back in, or turn the power switch back on."
I need an instruction manual for a LG WT-H755TH washing machine
10th item in a simple GOOGLE search for
LG WT-H755TH user manual!
You can view or download it from this website.
http://e.manualretriever.com/lect.php?ID=505713&lg=E&h=d41d8cd98f00b204e9800998ecf8427e&src=15
Jul 18, 2016 | LG Washing Machines
Jan 02, 2015 | LG Washing Machines
Need to remove pump on LG WM2701H washer
To get to the pump you need to remove the top plate, control panel and front cover in that order. for the front cover open the lid at the bottom left side and remove screws.
May 01, 2014 | LG WM-2277HW Front Load Washer
LG TURBO DRUM DD WT-R854
my LG Turbodrum DD 8.5 KG WT-R852 have an Error Message (A). What can i do
Oct 25, 2012 | LG Washing Machines
Manual for lg washing machine wtr854
LG has the manual for the WT-R854 on their site: http://www.lg.com/au/laundry-floorcare-appliances/washing-machines/LG-top-loader-washing-machine-WT-R854.jsp . Click on the Support tab and then look on the right side of the page.
I hope this helps.
Jan 12, 2012 | Washing Machines
How to replace copier drum Cleaning Blade UCLEZ0069FCZZ
Improper installation may damage the copier. Before disassembly, be sure to disconnect the power cord for safety. 1) Remove the drum cover. (4 Lock Tabs.)
2) Remove the drum fixing plate and the photo conductor drum.
•Dispose the drum fixing plate which was removed.
3) Check the cleaning blade and the red felt for damage.
•If there is damage, go to step 5
•If there is no damage, go to step 12
4) Remove the main charger. (Cleaning the screen grid and the sawteeth.)
5) Remove the cleaning blade.
•Dispose the cleaning blade which was removed.
6) Clean the cleaning section and the waste toner pipe to remove waste toner completely with a vacuum cleaner.
7) Remove the felt and duplex tape completely.
•Be careful not to scratch or bend the sub blade.
8) Attach the cleaning blade.
•Securely insert the plate section of the cleaning blade into the unit and fix it with a screw.
•Do not touch the cleaning blade rubber with your hand.
•When attaching the cleaning blade, press the cleaning blade in the arrow direction and attach.
9) Attach the felt.
•Attach the mocket with slightly pressing section A of the cleaning blade.
•Do not touch the tip of the cleaning blade.
•Do not put the mocket under the cleaning blade.
•Do not put the mocket on the sub blade.
•Do not press the sub blade with the mocket.
10) Attach the main charger.
•Securely set the MC holder on the projection of the process frame.
•Securely insert two projections of the MC holder into the groove in the process frame.
•When attaching the MC holder assembly, be careful not to make contact with the cleaning blade.
11) attach the drum fixing plate and the photoconductor drum. Apply grease to the inside of the photoconductor drum. (Diagram 2)
•Attach the drum from (b). (Prevention against the sub blade edge breakage)
•Attach the drum so that its position with the sub blade shown
12) Attach the detection gear.
•The detection gear is not installed to the drum cartridge package with the main body. Add a new one.
13) Attach the drum cover.
•After attaching the drum cover, do no make a copy
•When attaching the drum cover, engage the detection gear 20T rib with the 30T gear rib, and attach the drum to the process frame.)
14) Important.
•Insure proper drum rotation by rotating the drum counter-clockwise (as viewed from the front)
•If the drum does not rotate with reasonable effort the drum blade may need to be re-positioned or lubricated with a small amount of toner.
Dec 16, 2010 | Sharp Office Equipment & Supplies
Outside door under water and ice tray is rusting--what to do??? admirial side by side
hi there,
most common ice tray is made of hard plastic materials that hold any defrosted water from evaporator,if rust occured this due residual water dried produced rust,it easy to remove rust,have it wipe bu anti rust remover mc compound,and wash carefully by detergent and water,on have rub it by sand paper w/ smooth size #
if your tray is made of metal,have it anti rust,wipe it out and paint it by epoxy aclyric spray paint,after dry washed by detergent and water in order to remove paint odor.have a nice day.
Apr 30, 2009 | Admiral 26 cu. ft. Side-By-Side...
Washing Machines Logo
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
