Question about Cell Phones
Error endicate C5 what are problem - Cell Phones
I have a Toshiba Model 1350 copier and get an error message C5. What does that mean?
hi friend ,your machine motor drive gear Broken or game or motor problem
Oct 07, 2014 | Toshiba Office Equipment & Supplies
C5 error on toshiba 1370
Have you tried resetting the copier by unplugging it and waiting a few moments? If you problems persist check us out online for all your copier repair or Copier Rental needs.
Feb 04, 2014 | Toshiba 1370 Black and White Copier
Nokia C5-00 problem:camera not work(unexpected error occurred restart phone)
I have an error in my Nokia c5 camera that is not opening WebRepOverall ratingThis site has no rating(not enough votes)
May 20, 2012 | Nokia C5 Cell Phone
To flash your phone without spending any penny Click here1.Follow the instruction carefully other wise your phone will die.And here is the link to get you c5 flash file All nokia bb5 flash file and Nokia flash file.Good luck
Mar 23, 2012 | Nokia C5 Cell Phone
On our Ep3170 we get a C5 error code and the wrench symbol
Hello sir;You must remove the left side panel to access the service switch(s1) on PWB A you press this switch to chose the "C" then enter 0 press "#" ,then press "CLEAR" to terminated.
Jan 17, 2010 | Minolta Office Equipment & Supplies
C5 error on GE Profile dishwasher
C5 - Low Water Fill - This error usually indicates bad water inlet valve. Check for low water pressure to unit.
Dec 21, 2008 | GE Profile PDW8400J Built-in Dishwasher
GE profile Dishwasher gives an error: C5
Dec 21, 2008 | GE Dishwashers
Error code on a T-A TA215Z copier.
C5 is a Main Charge Wire Error. Either the main charge wire is broken or the plastic blocks are arching out.
Open the front door, and look for a gray handle that will slide out towards you. This is usually located above the drum.
The main charge wire is a very very thin wire that charges the drum in the copy process. If the wire is broken, no copies can be made. To make sure that this is the problem, leave the charge stick out, and close the front door and let the machine warm up. If it does, then you have located the problem.
If it still show a C5 error, the the problem is in the Transfer Charge coronas which is located under the drum.
Let me know what happens, and I can try to help you further.
Good luck.
Mar 16, 2008 | Office Equipment & Supplies
Cell Phones Logo
35 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
