Question about Armada Car Audio & Video
Hello world , i have a 2010 nissan armada platinum i need the location of the v.s.s and parking brake wire going to my radio/gps head unit to splice in my bypass switch, i have CONT-ASSY-IT-MASTER MODEL (NAU3221KUS) SERIAL # 90901326 (HJZ0093)
SOURCE: video while driving; Lanzar sdmu head unit
Just ground the "brake" wire from the unit.
Posted on Dec 24, 2007
  • 10 Answers
SOURCE: how do i bypass the parking brake switch in order for my video to play
To bypass the parking brake you should connect the parking brake wire from the unit to ground. It is better to do it via a switch because is illegal to watch video while you're driving. :)
Posted on May 19, 2008
  • 109 Answers
SOURCE: bypass parking brake wire
Boss Audio is the easiest in-dash DVD on the market to bypass; all you do is ground the ebrake wire. I recently installed 12 Boss Audio in-dash BV-7300's and did this to all of the decks problem solved. By the way I did this because they were in the back of limousines where the driver couldn't ever even see one of them while he was driving. I don't think there will be a problem, try it.
Posted on Jun 06, 2008
SOURCE: need to bypass ignition switch on nissan sentra
it should be underneath your car in between the firewall and the engine. Now you don't want to supply direct power to your starter because you'll end up frying it. However to just start the car once you've located the starter, get a long screwdriver with a plastic handle and connect the two wires with the screwdriver.
As for a long term fix, without investing the money to replace the necessary parts. You will need to attach a wire that can handle 12v to both wires on your starter separately. Then connect the other ends of both wires to a switch that can handle 12v, and mount that in your car somewhere. Then whenever you need to start your car just flip the switch on until the car starts then once it is started flip it back off.
I know this sounds like a lot but it is very doable with about $5 and a little bit of time.
Posted on Jan 30, 2009
Shadowmaru
  • 33 Answers
SOURCE: parking brake bypass
Tie the Parking break sensor to the ground wire, or ground it to a piece of the frame and your done ;)
Posted on Feb 11, 2009
My Nissan armada 2010 platinum lift gate want open
2010 Nissan Armada Service Repair Manual INSTANT DOWNLOAD Get yourself a operation and maintenance manual form here. If it's the first time you had this problem
Otherwise get a service repair manual. It's a very good site for this
Dec 14, 2017 | Nissan Cars & Trucks
2006 armada won't shift out of park. I installed a trailer brake controller just prior
Did you attach any electrical wiring to an existing wiring harness ?
Nov 08, 2016 | 2006 Nissan Armada
My armada is stuck in park. Starts with no problem but won't shift. Not Even to neutral
Most cars have a shifter solenoid that actuates when you depress the brake pedal. That ensures you can't shift into gear without having the brake on.
Either that switch is bad or the solenoid is bad - or the wiring is bad.
See a mechanic.
Feb 13, 2015 | 2004 Nissan Armada SE
2005 Nissan Armada won't shift into reverse or park
IM A TECH AT A NISSAN DEALER I HAVE ONE RIGHT NOW WITH THE SAME PROBLEM IT TURNED OUT TO BE A SHIFT LOCK CONTROL UNIT PART IS $131.00 THE UNIT SHORTS OUT AND DOESNT SEND A GROUND SIGNAL TO THE SHIFT LOCK SELONOID
THANKS ZAKK
Feb 07, 2010 | 2005 Nissan Armada
Locating the parking brake system on a 2002 Dodge Ram 1500
i believe they want you to wire it through the parking brake for safety purpose only. so you dont drive and watch a d.v.d. @ the same time. try wiring it to a ground directly,you should be o.k.
Jun 19, 2009 | 2001 Dodge Ram 1500 Truck 2WD
Car Audio & Video Logo
29 people viewed this question
Top Armada Car Audio & Video Experts
xxxxxx xxx
Are you an Armada Car Audio and Video Expert? Answer questions, earn points and help others
