Question about Joe Rodeo Watches
How to set second hand on a joe rodeo watch jjui0
3 Suggested Answers
SOURCE: Sweep 2nd hand operation & watch time setting on my Pulsar watch.
The larger second hand on the Pulsar PF8036 is part of the stopwatch feature. The upper button starts/stops the stopwatch feature, and the lower button operates the lap/reset function. Why they made the larger hand work only with the stopwatch instead of the smaller hand to the left is beyond me, but that's how it is designed.
Posted on Mar 25, 2010
abbysdesigns
SOURCE: how do I remove links from my Joe rodeo diamond watch band
If the watch is made out of gold the rivet will have to be drilled out and re-solder after a the sizing, Best to have it done by a jeweler. If it is a steel watch it is held together with screws or friction pins. With friction pins the inside of the band will have arrows indicating the direction you have to push the pin in. Use a nail or other object with the same thickness as the pin to push it out in the direction indicated by the arrow on the inside of the band. I hope this was helpfull.
Posted on Feb 18, 2012
Please can u show me how to change the time on this watch.
Set the time on your Baby G by switching to time mode. The button on the bottom left-hand side of the watch is the mode button. Pressing it once to will set the watch to time mode. The time digits will begin to flash.
  • 2Start by adjusting the seconds. Press the button on the top-right side of the watch once. The second digits will start to flash. Press the bottom right-hand button until the correct second time is displayed. Hold down the button to cycle through the digits. Once the correct time is displayed, press the bottom left-hand button and the digits will stop flashing. Press the bottom left-hand button again to set the hours.
  • Sponsored Links
  • 3Follow the same procedure to change the hours setting. Set the time and date by cycling through the digits in the following sequence: seconds, hours, minutes, year, month and date.
  • 4Press the bottom right-hand button to set the seconds to 00. When the second display is between 1 and 29, the digits will change to 00. If the display is between 30 and 59 seconds, the seconds will revert to 00 and one minute will be added to the minutes display.
  • 5Change from an a.m. to a p.m. setting by pressing the button in the middle of the bottom of the watch when any of the time display digits are flashing.
  • Nov 03, 2012 | Watches
    How do I remove links from my Joe rodeo diamond watch band
    Feb 18, 2012 | Joe Rodeo Pilot Collection Diamond Watch...
    The 24hr hand is meant to keep time in another
    I too was confused at first at setting the second hand after reading the directions. I read your post in searching for a solution, then I figured it out. Check the watch face, the second hand is operating using military time. (24 hr. time) You will see 24 hour time embedded on the face.
    For example: if you wanted to set both hands to be at the same time to test this. At say 10 p.m. set the second time hand to 22 for 2200 hrs. (10 p.m.) Let's say you woke up at 7 a.m. The second hand would be at 0700 (Embedded on watch face) then at noon it would say 1200 on the watch face... I now use the normal hands for local time and set the 24 hour hand for my home time.
    I hope this helps.
    Dec 30, 2009 | Invicta Watches
    Second hand moves every 4 seconds
    the battery need replacing this is what its supposed to do when batt low. if this helps please rate joe
    Nov 20, 2008 | Watches
    The second hand is loose on my wifes Fossil F2 ES-8677 watch
    the movement will have to be taken out and the second hand can be put back on its spindle fiddly but possible. if this helps please rate joe
    Sep 30, 2008 | Fossil Watches
    Oct 09, 2007 | Watches
    Watches Logo
    129 people viewed this question
    Top Joe Rodeo Watches Experts
    Ansel Alberto
    Ansel Alberto
    Are you a Joe Rodeo Watch Expert? Answer questions, earn points and help others
