Question about The Home Security
What are the pros of using safe?
Safe
    New Friend:
    Problem Solver:
  • 5 Answers
When you are planning for getting a new safe for your home. You must have a look for the possible benefits that it may provide you. Thus, here are some of the benefits that a properly constructed safe must contain.
PROS OF A PROPERLY CONSTRUCTED HOME SAFE -
1. Fire Protection.
2. Burglar Resistance.
3. Water Proof.
4. And last but not the least, it must fit your budget.
Also, one can get more information on it from Home Safes. As this is one of the best place to get the best deals on branded safes.
What are the pros of using safe? - home-safes-1-1m0mtllptg2li5tudm33ejaf-2-0_0.png
Posted on Apr 25, 2017
What are different pros and cons of using contact lenses?
    Pros: It is easier for athletes or other work.
    Cons: It may cause allergies. So, care should be taken before using it and also the prescribed eye doctor should be consulted before using contact lenses.
ACUVUE Brand Contact Lenses
Jan 19, 2015 | Coopervision Frequency 55 Multifocal...
Tip
I wish to STRONGLY reinforce the intent of what krbjump was saying in terms of...
Well, those of you who have no idea why a Screen Voltage (technically known as G2) adjustment may interest you, here is a photo of a bad adjustment (too high).
You may also experience smeared colors… this is caused by a low adjustment. To correct this, we need to get the back off of the TV. It would be a good time to unplug it if you have not already done so. Next we locate the FBT (Fly-Back Transformer).
This is a 20” model and it has 2 knobs. Your FBT may vary, as some slim designs and some large tube models may have 3 knobs.
You will need to look closely at the knobs; they will be labeled “Focus” or “Screen”. On units with 3 knobs, there will be 2 focus knobs and 1 screen. For now, we will be working with at the Screen knob only.
With the adjustments identified, we are ready to plug the TV in (including your standard cable connection) and turn it on… BECARFUL!!! For the rest of this adjustment, we will be working inside of an electrically charged TV. We also need to normalize the picture, so go into your TV menu and adjust the Picture and Brightness settings to the middle or center.
If your TV normally displays a black screen when you do not have a signal connected, ex: Video input 1, then this will be the quickest and easiest setup for you to use. However, if you are not so lucky, you may need to bust through your DVD video collection and find a “between scenes” shot that you can pause on to give you as black of a picture as possible. Eliminate as much light in the room as you can (just remember, you still need to see what your doing)… we want a good view of the screen without the interference of ambient lighting.
Once you have your black screen all set, we are now ready to proceed to the adjustment. If you have lines on the screen, see (HIGH)… if you have color smear, see (LOW).
HIGH: If you have some lines in the picture with a washed out appearance, your Screen voltage is too high. You will need to turn the Screen knob on the FBT counter-clockwise. Do this slowly, until the lines are no longer visible. If you still have a small amount of illumination coming from the screen, back it down a touch further until this just disappears.
LOW: If you have smeared colors in the picture that seem to trail of the edges, your Screen voltage is too low. You will need to turn the Screen knob on the FBT clockwise. Do this slowly, until you just see some lines zigzagging top to bottom on the screen. Now, you will need to turn the Screen knob on the FBT counter-clockwise. Do this slowly, until the lines are no longer visible. If you still have a small amount of illumination coming from the screen, back it down a touch further until this just disappears.
The final set, switch the TV input over to your cable input and check out the picture. Take a good look at some bright scenes and dark scenes. Do they look ok? Adjust the Picture and Brightness in your menu… can you set the picture to your liking? If so, you are all set. If not, double check your work (remember to normalize the Picture and Brightness setting).
If you are unable to adjust the Screen voltage as described above, you may have a High Voltage problem with your TV. This will require a repair and is not covered by this tutorial.
If you are all set and the adjustment is good, we should have a quick look at the focus adjustment. Return the TV to your Black screen setup. Press the TV menu button to give you nice fixed display to focus. Adjust the focus knob(s) until you have the clearest picture. It’s important to balance the center of the picture with the corners of the picture. If the center is too sharp and the edges and corners are blurry, it is not a good adjustment. Do your best, you are the final judge of your work here.
Once you have finished the adjustments and verified the picture with your cable picture, you are ready to close it up and return the TV to normal service. Unplug the TV, replace the back cover… enjoy!
I hope this was helpful. If you benefit from this tutorial, please leave some feedback.
on Jul 05, 2010 | Televison & Video
Tip
PS3 models, and what they can do
The 20 Gig
Pros
Full PS2 Compatibility
HDMI Port
Pretty good Cooling System
4 USB Ports
£220
Cons
Super Small HDD
No Wireless Card
Discontinued (They don't make them any more)
The 40 Gig
Pros
£250
HDMI Port
Built in Wireless
Medium HDD
Amazing, New Cooling System
Cons
2 USB Ports
Cannot play PS2 Games
The 60 Gig
Pros
SD Card Slots
4 USB Ports
Built In Wireless
Big HDD
HDMI Port
£280
Cons
The *OLD* 80 Gig
Pros
Massive HDD
4 USB Ports
Limited PS2 Compatibility
SD Card Slots
HDMI Port
£280
Cons
The *NEW* 80 Gig
Pros
Massive HDD
£250
HDMI Port
Built in Wireless
Cons
NO PS2 Compatibility
The 160 Gig
Pros
Mammoth HDD
HDMI Port
Built in Wireless
Cons
£350
on Jan 18, 2010 | Video Game Consoles & Games
The interior is cracked in my freezer. What do I do? Is it safe to still use?
dont do anything, you would need to replace the liner and it is not even done by pros. It wont hurt a thing to use it with a cracker liner
Oct 12, 2012 | Refrigerators
How to safely remove moldey sheet rock from ceiling?
If there is a lot of it, it's best left to the pros. As removing moldy anything can cause the spores to become air born and spread. Special equipment and respirators are required to safely remove it and properly dispose of it. There are EPA requirements regarding this. It is not something to be toyed with.
I hope this helps you & thanks for choosing FixYa.
Jul 26, 2011 | Heating & Cooling
Why won't my Samsung PL80 upload my pictures to my computer? It will connect and make that funny noise but then nothing happens ? Yesterday it was perfect just popped up with 'upload you photos and videos'...
Yesterday, did you use the "safely remove hardware" function when you disconnected? If not, that's your problem. It's also why pros never use the camera for downloads....they always use a separate card reader. 23a90a0.jpg
Oct 11, 2010 | Cameras
While connecting the camera to the PC , the image is being locked atomatcally. and I tried it with switching it on/off, now it is not allowing me to power it on, even after I disconnected it from Pc now.
Always use the "safely remove hardware" icon at the bottom right of your computer screen. Try this...remove the card and battery...press all the buttons...leave it alone for 20 minutes...insert the card and then the battery...turn it on. If that works, in the future, do what the pros do...use a card reader to download your pics.
Jan 14, 2010 | Olympus SP-350 Digital Camera
Cleaning Conair Simple Cut haircutter
Go to a Sally Beauty supply and purchase a can of the blade wash. It is relativly inexpensive. You dip your blades into ths special wash and it cleans the blades and keep them sharp and is safe. DO NOT take the heads apart, Let the pros do that but blade cleaner you immerse them in and trust me it is what we pros use.
Jan 20, 2009 | Conair HC91CS 10 Pc. Haircut Kit Hair...
Pros and Cons
Sansa e200 is increasingly not supported by the manufacturer, it may require you to manually switch between USB modes, and generally has a lot of problems. I can't think of any pros, actually.
The iPod has great support from the manufacturer and rarely has a problem that can't be solved. It is hard to use an iPod on Windows Media Player, but definitely not impossible. The probelm arises when you try to sync with Windows Media Player AND use iTunes.
I would definitely go with the iPod. Sansa sucks.
-Tha Mp3 Doctor
Dec 22, 2008 | SanDisk Sansa e250 MP3 Player
Fuel octane use
I use 87 just like the designers of the bike call for. pros=you'll go faster due to a lighter wallet cons=your bike may blow up
Nov 10, 2008 | 1989 Suzuki GSX-R 750 K
Home Security Logo
35 people viewed this question
Top The Home Security Experts
vince
 MikeWang
MikeWang
Level 1 Expert
Are you a The Home Security Expert? Answer questions, earn points and help others
