Question about Kenmore Refrigerators
Kenmore elite French door bottom Freezer door surface is sticky and has huge spots
  • 4 Answers
SOURCE: Kenmore elite french door freezer on bottom
Odds are due to the fact the ice maker was left on for an extended time with a full tray of ice the mechanisms froze. You can take a hand held hair dryer and defrost the parts, just be careful not to get too over zealous and melt the plastic parts. It should only take a few minutes to defrost.
To avoid this problem from occurring again, I turn the ice maker off when the ice tray is full.
Regards,
Ann
Posted on Nov 22, 2008
SOURCE: Kenmore Elite French Door w/
Shows an error on display ER IF. The ice maker has stopped working.
Posted on Dec 03, 2008
  • 3600 Answers
SOURCE: kenmore elite bottom freezer icing up
if it has an ice maker fix or adjust the over flow for the ice try.
Posted on Jun 18, 2009
SOURCE: sears trio elite ...french doors with bottom freezer
I have the same refrig. After taking the freezer basket hinges off, thinking I had to take the whole door a part to access the screws for the handle...my husband figured that the handle probably slides off...and yes that is just what it does!
Push the handle in a bit and then slide to the right. It takes a little bit of effort but that handle will come right off. Then you can tighten the screw that holds the clip in place. Then you line the handle back up to the clips, and slide to the left. Good Luck!
Posted on Feb 19, 2010
SOURCE: kenmore elite french doors bottom freezer Model #
Well you got a kenmore that i believe is actually made by either Samsung, or LG, since Kenmore does not make any refrigerators, they are ALL taken from other name brands with the name kenmore put on the front. I would start by looking at your owners manual for troublshooting codes, but chances are you have a faulty evaporator fan motor, either the motor itsself is out of balance, or possibly ice is obstructing fan blade, and you'll need to find the source of that problem instead. hope this helps
www.FixMyFridge.net
Posted on Mar 08, 2010
How do I take KENMORE ELITE TRIO 596.75533400 out of demo mode?
Try pressing ultra ice and home while the refrigerator door is opened,or ultra ice and the refrigerator pad with the freezer opened. Hold for five seconds. Hope that works.
Jun 12, 2014 | Kenmore 22 cu. ft. TRIO French Door Bottom...
I have a 2006 kenmore elite trio refridgerator wirh french doors and bottom freezer. on of the door handles is loose. what tool do i use to tighten handle. each handle has a screw at top and bottom. The...
There is two allen set screws for each hand at both end and they are facing each other on the handles.. Remove the allen screw and put a very minute speck of jelly on each screw---small-small amount. This will kept the set screws from loosen up. GB...stewbison
Aug 31, 2011 | Kenmore Elite TRIO® 7854 (25 cu ft) Bottom...
Our Kenmore Elite french door bottom freezer, automatic icemaker, no water/ice dispenser on the door - is leaking quite a bit - had to mop up the floor three times today. first time it's happened since...
Check for cracks in the water supply tube from the house plumbing valve to the ice maker. Could also be the valve itself.
Turn off valve for a day to diagnose which.
Oct 21, 2017 | Kenmore Elite TRIO® 7854 (25 cu ft) Bottom...
Kenmore/Elite Model 795.7756,7757 Trio: Bottom Freezer Door won't close. The latch or hook at the bottom corner of each side will not hook in.
We have a kenmore elite refrigerator modle number- 795 7756,7757 and it has been making a humming noise very constant now after two weeks, what could it be?
Sep 18, 2010 | Kenmore 77554 / 77543 Bottom Freezer...
Kenmore elite fridge, french doors, bottom freezer: water does not come out cold. What should the temperature settings be at (for fridge and freezer)?
Fridge 34-38 degres
Freezer below 29
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 17, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
My Kenmore Elite french doors bottom freezer drawer fridge has condinsation in the top of my fridge what is causing this?
bad/dirty door seals allowing fresh moist air in.
Sep 24, 2009 | Kenmore 24.8 cu. ft. Trio French Door...
Kenmore elite bottom freezer icing up
Jun 18, 2009 | Zanussi ZEBF250W Bottom Freezer...
Kenmore Elite Stainless French Door Not getting cold
This unit may be frozen up.  Defrost completely to allow the passages to get a free flow of cold air.
Nov 16, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerators Logo
24 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
