Question about Electrolux Vacuums
To reverse decal on Electrolux dryer do you peel off the upright one or stick reverse cecal over it?
How to replace el8602a power cord
Electrolux Vacuum Cleaner EL 8602A How to replace the ...
Question About Electrolux Vacuum Cleaner EL 8602A. How to replace the ... How toreplace the power cord on Electrolux EL8602A. Asked by gerry nickel on ...
Rewiring the Power Cord for the Electrolux Model G ...
? 4:27
Jan 30, 2012 - Uploaded by Jayson1940D14
Rewiring the Power Cord for the Electrolux Model G ... How tochange the Electrolux 725 Suspension Plate - And Get Access To The Motor ... Brown Vintage ELectrolux Canister Vacuum Cleaner 1401-b - Duration: 0:17.
Electrolux Nimble Upright Vacuum, EL8602A - YouTube
? 3:49
Nov 11, 2014 - Uploaded by Michael Callender
Electrolux Nimble Upright Vacuum, EL8602A Best Price ... Dirt Devil UD70095 Power Reach Multi Cyclonic Pet Bagless Upright - Duration: ...
Jan 30, 2016 | Vacuums
How to fix expelling dirt from electrolux versatility?
sounds like the vacuum is blocked.Turn vac on its back and check the area where the dirt goes in,there is probably something stuck in there....
Jun 23, 2014 | Electrolux EL8502 Versatility Bagless...
Electrolux Epic series 3500 model Upright Vacuum cleaner motor(replace old one)?
I don't know what your question is, but replacing a motor for Electrolux, now Aerus, should be done by an authorized Aerus Electrolux service tech. The uprights are especially tricky to take apart and reassemble correctly. The address and phone number of the Aerus store/service center nearest you can be found at the site below.
Mar 13, 2011 | Electrolux Vacuums
The brush on my Electrolux Versatility will not spin. You can spin it by hand, but the motor will not spin it.
Hello, W/D here.
Since the brush will not spin, but the motor works, either the belt has come off of the motor shaft, the belt is worn past it's useful life, or the beater bar has seized.
1. Turn off the power (unplug).
2. Remove the bottom plate. With the plate off, use your finger to test the tension of the belt. It should be tight, and roll when you roll the beater bar by hand.
3. Remove the beater bar and belt. Inspect the beater bar, particularly by the bearings. Remove any twine, hair, etc.
4. Inspect the belt for abnormal wear. If there is any significant wear in the belt, replace it.
5. Reassembly is in the reverse order. Place the belt on the beater bar. While holding the beater bar close to it's position, place the belt on the motor shaft. Rotate the beater bar bearings to their proper position and install the beater bar. Replace the cover plate.
Best regards, --W/D--
Jan 29, 2011 | Electrolux EL8502 Versatility Bagless...
How to replace the flexible hose between the upright and floor modules?
Turn the vacuum on it's side. Pull the power nozzle end out. Unscrew, in a clockwise direction, the hose from the body/tank.
Reverse to install new hose. Screw the hose into the tank, turning counter-clockwise. Place other end into power nozzle. Ensure it's set properly.
Dec 31, 2010 | Electrolux Epic 3500 Vacuum
How do we get a sock out of the hose
Put the other end of the hose into the wall so that it reverses the suction if you can..
If you can't reverse it you'll need to buy a new hose.
Jan 10, 2010 | Electrolux Central Vacuum
How to install a U8172-900 belt
your savvy bagless has a geared belt. remove the bottom plate and then remove the 2 back screws near the back wheels to remove the top cover also peel off the hoover decal to access the top cover screw. this will expose all components to replace the belt.
Sep 28, 2009 | Hoover U6630-900 WindTunnel Bagless...
Need replacement belt PN 43409 for Electrolux Commercial Upright
Just about any vac shop should have the belt. This belt is the same belt used in the upright vacs as well as the power nozzels. The new oem part number is 48359.
Sep 25, 2009 | Electrolux UltraLux 2000 Bagged Canister...
Beater Bar Belt Removal from Upright Electrolux Vacuum
Generic problem for all Vacuums
Beater bar Belt Removal from Upright Electrolux...
Posted by wrenn on Jul 14, 2008
I am trying to change the belt on an Electrolux Model 1717 Upright Vacuum and I am having difficulty disassembling the vacuum to remove the beater bar and belt.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. . Normally there are screws, clips or levers that would remove the bottom plate or if that does not work then the top cover will come off and that will expose the belt. Once that is off and the belt is exposed then cut off the old belt and then lift up the brushroll on the pulley end and install the new belt around the pulley end and re-install the brushroll. Then use a belt puller or a screwdriver with a bent right or left end to stretch the belt onto the motor pulley and then track the belt in a straight line and reverse you steps in the reinstall of the top cover or bottom plate. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions. Customer Service 1-800-896-9756
Electrolux Home Care Products – North America
P.O. Box 3900 Peoria, IL 61612
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 14, 2008 | Vacuums
Vacuums Logo
27 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
