Question about Dishwashers
I have an omega dishwasher PL402XA and the rinseaide has to be filled every wash and still doesn't work
2 Suggested Answers
  • 423 Answers
SOURCE: Whirlpool APDW2 dishwasher not filling with water
The problem is probably a failed solenoid valve that opens/closes for water to come in and stop when the float says it is full.
If the solenoid is not the problem, the main controller could have failed.
Good Luck!
Posted on Apr 05, 2009
How to repair or fix a Dishwasher if it doesn't wash well
A common cause of poor washing results is improper loading—dishes that block or impede the spray arm(s) or prevent the soap dispenser from opening. On the other hand, if your dishwasher has chronic problems with good washing, the problem may not be your dishwasher. A good first step is vary the amount of dishwasher detergent you're using and try switching brands.
Other possibilities: Your home’s water pressure may be too low, your water may be too hard, or the water temperature may not be hot enough.
In order for your dishwasher to fill to the appropriate level, water pressure should be from 20–120 pounds per square inch. If you suspect that your water pressure may be low, turn off all faucets or other users of water (such as washing machines and sprinklers) and then put a half-gallon jug under the kitchen faucet. Turn on the hot water full-blast. If the jug doesn’t fill within 14 seconds, your water pressure may be too low for proper dishwasher operation. Call your city water utility to discuss your options, or avoid drawing water elsewhere in the house or yard during dishwasher cycles.
The right amount of detergent to use depends on how large your load of dishes is and how hard your water is. Hardness is measured in grains of minerals—the more grains per gallon you have, the more detergent you’ll need. If your water has 12 grains or more of hardness, fill both dishwasher soap cups completely with detergent. If that doesn’t work, consider installing a water softener.
To check water temperature, hold a meat thermometer under the hot water faucet for two minutes; if it doesn’t register a minimum of 140 degrees F., turn up the temperature dial on your hot water heater. (However, if you have a newer dishwasher that heats the water internally, it isn’t necessary to turn up your hot water heater.)
If your dishwasher has worked fine in the past but suddenly your dishes aren’t clean after the dishwasher completes all cycles, listen to the spray arm(s) spinning inside during the wash cycle. If spinning poorly, wait for the machine to cool down, remove the spray arm(s) by unscrewing the hubcap(s), lifting the arm(s) off, and then cleaning out the spray holes in the spray arm(s) with a stiff piece of wire.
on Sep 03, 2010 | Dishwashers
Keeps leaving dishes gritty after wash.... Have cleaned everything possible
Do you live in a region with hard water? Most detergents don't work very well with hard water because phosphate is now outlawed as an ingredient in dishwasher detergent. Weird but true. Here's a map to show the water hardness in the US.
Mar 19, 2013 | Indesit Dishwashers
Whirlpool dishwasher wont wash
if the bottom tub is filling with water but not washing the issues is with the wash motor, some of this model use a start capacitor that can fail, if it has a capacitor on the side of the motor it may have failed but are difficult to diagnose but are cheap to replace so worth trying, if this doesn't help or if it doesn't have a capacitor then the fault is with the wash motor.
Mar 08, 2012 | Whirlpool Gold 24 in. Built-In Dishwasher...
Where do I put rinseaid in for a classix dishwasher?
there should be either a screw cap or a door that opens and you can add the rinseaid
Nov 01, 2011 | Bosch 24 in. SGS43C12 Classixx...
My new omega washing mashine shows an E2 error code 5 miniutes into the wash how do I fix this?
Manufactured by omega washing mashine have an electronic controlpanel that must be unlocked in order to set or make changes to your washingcycle.
E2 indicates a water leak. When a leak occurs, it trips thefloat device by dumping water into the dishwasher's base. The incoming watervalve will be switched off, and the drain pump will turn on until the sump isempty
However, if an error light is blinking on your dishwasher'scontrol panel, the panel must be reset before you can gain access. Blinkinglights on your washer control panel may signal a mechanical problem that needsto be repaired. If the lights continue to blink after you've reset the controlpanel, contact Sears to service omega washing mashine or considertroubleshooting the appliance yourself carefully.Instructions
1 Press and hold the "Heated Dry" button onyour omega washing mashine for four seconds to unlock the dishwasher controlpanel.
2 Press the "Heated Dry," "Normal Wash,""Heated Dry" and "Normal Wash" buttons one after theother, in fairly quick succession.
3 Wait for the washer to run a short diagnostic test.
4 Press the "Cancel/Drain" button at the endof the diagnostic test cycle. This should reset the control panel on your omegawashing mashine. Thankfor using fixya.
Jul 30, 2011 | Washing Machines
My dishwasher uses a compartment of rinse aid each wash
The cheapest and easiest option is to stop using rinseaid and use an allinone tablet instead.
Jun 14, 2009 | Bosch Dishwashers
I want to change my rinse aid product
run it through a couple of empty washes or use it just to wash dishes without rinse aid. this should allow you to add rinse aid into the container after each wash there after just add more rinseaid. it could take a while to get full rinseaid coming out but eventually there should be only rinseaid in the container.
Apr 10, 2009 | Maytag 24 in. DWU7402 Built-in Dishwasher
Good Luck!
Apr 04, 2009 | Dishwashers
My glasses have started to get a cloudy film on them that I can't wash off
are you using rinseaid?
rather than using all-in-one tablets, better to use seperate powder detergent and rinse aid
Aug 05, 2008 | Bosch Dishwashers
Dishwashers Logo
53 people viewed this question
Top Dishwashers Experts
