How do i maintain my communication with my clients ?
There are lots of ways to communicate with your clients.
1) Email.
2) Telephone, text message.
3) Visit your clients and talk to them face to face.
4) Online Video Communication. Install a video conferencing app on your device (computer and mobile phone) and invite your clients to chat online.
Posted on May 19, 2017
    Top Expert:
  • Computers & ... Master
  • 45,620 Answers
It is called a phone , face to face , e-mail or messenger
Posted on Apr 25, 2017
Cisco expert
I think you're confused. IP Communicator is the unified communications client (IM and Phone) It is looking for a capatible headset so you can use your softphone. This software is not your VPN client. There are two different cisco product: one for your VPN and one for your phone. If you're trying to ocnnect to an old-style Cisco VPN, your IT dept will have to configure that with a certificate.
Solution from Cisco: http://www.cisco.com/en/US/products/sw/voicesw/ps5475/products_tech_note09186a00809b6c40.shtml
This behavior is observed when a user attempts to install or use the IP Communicator on a system that has different names for the Playback (wave out) and Recording (wave in) devices.
In order to overcome this problem, perform one of these tasks:
-Use a USB headset that is recognized by the IP Communicator.
-Upgrade to the latest version of the IP Communicator
Nov 07, 2013 | Arris SURFboard SBG900 Wireless Router...
I want to set up password on my router
Step 1 Open a web browser and type the IP address of the DIR series router into the address bar (default is http://192.168.0.1). Press Enter
Step 2 The default username is admin (all lower case) and the default password is blank (nothing). Click on OK.
Step 3 Click on the Setup tab at the top and then click on Wireless Settings on the lefthand side.
Step 4 From the Wireless Security Mode dropdown menu, select WPA-Personal encryption.
Step 5 From the WPA Mode dropdown, Under WPA, select the form of WPA you would like to use.
Use WPA or WPA2 mode to achieve a balance of strong security and best compatibility. This mode uses WPA for legacy clients while maintaining higher security with stations that are WPA2 capable. Also the strongest cipher that the client supports will be used.
For best security, use WPA2 Only mode. This mode uses AES(CCMP) cipher and legacy stations are not allowed access with WPA security.
For maximum compatibility, use WPA Only. This mode uses TKIP cipher. Some gaming and legacy devices work only in this mode. To achieve better wireless performance use WPA2 Only security mode (or in other words AES cipher).
Step 6 In the Pre-Shared Key box, enter the desired Pre-shared key.
This is the "password" that allows communication between you're encrypted client (e.g. the PSP or your wireless computer) and the encrypted wireless signal coming from the router. This password must contain at least 8 characters, the characters can be anything you can create from your keyboard.
Step 7 Click on Save Settings
May 07, 2011 | D-Link AirPlus Xtreme G DI-624 Wireless...
When I connect my router to my modem, I cannot surf the net, nor can I access my router homepage. I have my modem in bridge mode, but I appear to have no connection.
I would set it up in 'router' mode. Bridge mode is for a specific application for an intranet (not internet).
Bridge Mode Router Mode Does not block any broadcast or multicast Blocks and provide protection against broadcast storms Transparent bridge and can pass Non-IP protocols Only IP protocol is supported PPPOE protocol Pass-through No PPPOE protocol pass-through Able to transport VLAN tagging Doesn't supports VLAN No network segmentation. One broadcast domain Network segmentation (Clients can be on different IP subnet) Can only relay the DHCP client's request to the external DHCP server Can Act as DHCP server & relay which Prevents IP conflict & DHCP Injection Bridges maintains bridging table (Mac) & STP can be used to avoid loops No STP feature; maintains routing table External bandwidth Controller can be used to control the speed of the clients by Mac or IP address External bandwidth Controller can be used to control the speed of the clients by IP only In client device, it uses MAC address to associate which requires WDS compatible AP Use SSID to associate, work with any 802.11a/b/g AP
Dec 30, 2010 | Linksys BEFSX41 Router (DHBEFSX41)
Excellent signal low speed transfer
You can boost the signal range of a WiFi computer network in several ways: Answer:
  • reposition your router (or access point) to avoid obstructions and radio interference. Both reduce the range of WiFi network equipment. Common sources of interference in residences include brick or plaster walls, microwave ovens, and cordless phones. Additionally, consider changing the WiFi channel number on your equipment to avoid interference.
  • upgrade the antenna on your router (or access point). WiFi antennas on most wireless base stations can be removed and replaced with more powerful ones.
  • add another access point (or router). Large residences typically require no more than two APs, whereas businesses may employ dozens of APs. In a home, this option requires connecting your primary wireless router (access point) to the second one with Ethernet cable; home wireless routers and/or APs don't normally communicate with each other directly.
  • add a bi-directional WiFi signal amplifier to wireless devices as needed. A WiFi signal amplifier (sometimes called "signal booster") attaches to a router, access point or Wi-Fi client at the place where the antenna connects. Bi-directional antennas amplify the wireless signal in both transmit and receive directions. These should be used as WiFi transmissions are two-way radio communications.
  • add a WiFi repeater. A wireless repeater is a stand-alone unit positioned within range of a wireless router (access point). Repeaters (sometimes called "range expanders") serve as a two-way relay station for WiFi signals. Clients too far away from the original router / AP can instead associate with the WLAN through the repeater.
Nov 19, 2009 | Sony Computers & Internet
I am workiong from my home office but do not get throug to my firm ofice. I am connected with sonic wall global client, but when I try to ping the firm server but it doesnt answear.
It sounds like it might be an issue with the VPN client that is attempting to get to your server at the firm. If you are having issues, first contact the firm's IT department. If they still cannot get you connected then you will need to contact you ISP to make sure that they allow VPN connections.
Nov 11, 2009 | Citrix SonicWALL Internet and...
How to make my DWL-2000AP works like a wireles card and is there any driver for it?
It sounds as if you want to use your access point to connect into a wireless network. A typical, simple wireless network includes (1) access points and (2) clients such as a wireless card in your laptop. Access points can only communicate with clients and clients only communicate with APs. However, many access points can be configured to be clients. Usually you would find that in the basic wireless setup page. I don't know if the DWL-2000AP can be set up that way, but you can check in the manual. If it can, then you would select that mode, then specify the SSID of the network you want to join.
Apr 15, 2009 | D-Link AirPlus Xtreme G DWL-2000AP...
Im doing project in proxy server.i want to develop coding for proxy server using cache concept.
Hi
Use analog Proxy its too simple u can manage all thing what u want
Harry
Apr 14, 2009 | Computers & Internet
Can't open my e-mails
Must be some problem with the client on your machine, can you try reinstalling the client
Mar 15, 2009 | Microsoft Office Outlook 2003 for PC
Client no.?
client no nothing but a no which is given to u while downloading the software along with that u will get other wise type some num and start using it
Feb 26, 2009 | Panda ClientShield for PC
Computers & Internet Logo
David Payne
David Payne
