SOURCE: Intermittent loss of mobility, get beep beep sound
I sounds like the switch is not making contact relieably. Make sure your key is clean and if that does not work, than the switch inside the console will need to be replaced. Contact Pride Mobility for a technician local to you.
SOURCE: oil lamp goes off. full of oil. lamp will go out
The oil light may be defective, but make sure that you have enough oil pressure @ idle. It will not matter how much oil is in there if there is no pressure. If the pressure is low, it is either the oil pump, or the oil system is clogged up somewhere like at the pick up tube at the bottom of the engine block.
There is a solution that you can add to your oil to clean the system. You have to run it a few miles and change it.
Pressure increases with RPMs.
Good Luck.
