HOW DO YOU GET TO THE LID SWITCH ON A ROPER RAS6233KQO TOP LOAD WASHER? HOW DO YOU GET THE TOP OF THE WASHER OFF?
  • Washing Mach... Master
  • 1,606 Answers
On the back of each END piece , there is a phillips head screw . Remove both screws and the console will slide foreward and tilt back . Remove the 2 clamps by prying out from the front of the clamps . Remove the lid switch connector and the whole cabinet will tilt foreward . Remove the 2 screws holding the switch and the plug for the switch wiring can be removed . Reassemble in reverse . BE SURE TO UNPLUG MACHINE FIRST .
Posted on Jul 25, 2009
I have a roper rax4232rq3 washer. The washer will
If this is a Whirlpool manufactured top loader (such as your Roper), the most common cause of the symptoms you describe is a lid switch malfunction. Symptoms may include, no spinning, no agitation, stopping at the rinse cycle and no draining.
The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r3557193-replacing_a_lid_switch
On some models, the lid switch is located under the top casing by one of the lid hinges. You will know if you if you have this type of switch, because It does not have a lid strike and the small hole on the right hand side of the wash tub will not be present. This switch is actuated (toggled) by a rod on the lid hinge. With this type of switch, if you locate it and it can be toggled by hand, you may only need to adjust the actuator by bending it slightly.
A replacement lid switch (if required) can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The average price is about $20 - $30. Prices differ between sites so shop and compare.
If you have questions, or need additional assistance, please post back and let me know. I hope you find this information helpful.
Jan 21, 2010 | Roper RAS8445KQ Top Load Washer
The washer tub on my Roper washer does not spin during rinse cycle. The motor coupling seems to be OK.
SOUNDS LIKE A LID SWITCH OR A BAD MOTOR OR TRANNY. I WOULD CHECK THE LID SWITCH FIRST
Nov 03, 2009 | Roper RAS8445KQ Top Load Washer
I have a Roper Washer Model RTW4340SQD that
The lid switch is on the top left side of the top cover. If it is bad the machine will fill and stop. The lid switch must be good for the machine to agitate and spin.
Nov 01, 2009 | Roper RTW4300SQ Top Load Washer
My top load kenmore washer filled with water and just stopped
Try tightening the screws on the lid hinges. This should re-engage your lid switch. If it doesn't then you may need to replace the lid switch.. Hope this helps... Bill
Jun 04, 2009 | Roper RAS6233KQ Top Load Washer
How do I replace the lid switch on my waher it's a Roper
buy a replacement switch and the top lifts off from the front.  It could be the switch has only come loose or the probe on the lid has broken off.
Feb 27, 2009 | Roper RAX4233PQ Top Load Washer
Roper rax4232pqo wont spin
Still replace the lid switch. Most have multiple contacts.
Nov 08, 2008 | Roper RAS8445KQ Top Load Washer
Roper top load washer
jumped across the lid switch and everything worked so replaced switch
Aug 12, 2008 | Roper RAB2121KW Top Load Washer
ROPER RAS6233KQO T.L.W.-Won't fill/rinse with cold water
Most washers have a small screen at the water inlet valve. They can be accessed simply by revoving the hose from the back side of the washer, using a small screw driver you can carefully remove the screens and clean them out under a faucet.That may be all that is wrong.
Oct 27, 2007 | Roper RAS8445KQ Top Load Washer
Washing Machines Logo
64 people viewed this question
Top Washing Machines Experts
