Question about LG Washing Machines
I have an LG Top Load washer WT1101CW. It will not drain out and water remains in the tub after rinse and spin cycle
OK, I check the drain hose last night and it was fine. What I did find out is that the water was still flowing in through the tube holes in the tub even though the machine was not running. The place in the tub was at about 7 o'clock if youwere looking at a clock face. I turned the water supply off and it stopped seeping into the tub. So, it sounds like this is some sort of water valve issue or a faulty valve?
  • 296 Answers
Check your discharge hose for obstructions, the beginning of the elimination process
Posted on Apr 25, 2017
Spinning cycle
Keeping in mind that the soap & bleach gets dispensed into your wash on the second to last rinse cycle and that most all rinse cycles are in cold water. Is your cold water valve screen plugged causing your washer to rinse poorly? Are you using the HE detergent? If not maybe the washer is sudsing up to much and having a hard time rinsing all the suds and bleach out and leaving the clothes soapy.
Fill the washer up with no clothes in it on a cold/cold wash setting does it take a long time to fill the washer up? Also when it is full and agitating is there suds in the washer?
Last suggestion is if the drain is hose is a lot higher than the top of the washer it might have a hard time draining out all of the soap water before the next load
Mar 23, 2008 | LG WM-2277HW Front Load Washer
Will not spin regularly
The water should be pumped out in a short time just before the spin cycle begins. Do you hear the pump motor running? Check the drain hoses to and from the water pump for kinking. If ok, check for a stray sock or something that blocks the drain port in the bottom of the outer tub. If also ok, check the plastic pump impeller itself for sheared splines which couple it to the motor shaft. If the motor turns, but impeller doesn't, replace the pump mechanism. If still under warranty, take advantage. Hope this helps!
Apr 12, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Stops before rinse cycle... won't drain or spin.
The REGULAR CYCLE button turns the drain pump on or off. The REGULAR LED will turn
on when the pump is on. This feature can be used to drain the tub. You could get a bucket and lay the hose on the fllor. Gravity will drain it down.
Sep 07, 2009 | Fisher and Paykel GWL11 Top Load Washer
Washers fine but doesnt drain water and go to rinse cycle
Check the drain hose may be kinked. Washers have been known to eat socks, they go in to the the tub during the spin cycle and down in the pump. If you are so inclined to look dome pumps are clear and you can see the sock. There is a hose clamp to remove and you may be able to remove the sock. Reassemble and test. Remember as always to unplug the washer first before doing any work. This exploded view has a washer and if you hover over the bottom right it will show what the pump looks like. Good luck
Aug 21, 2009 | Kenmore 22422 Top Load Washer
Washer will not finish its rinse or spin cycle
Check that water can drain out of the machine
1/ Check that the filter is not blocked
2/ Check drain motor is working (ie. not blocked with coins or hairpins etc)
3/ Check that pipe from tub to filter is not blocked (I had a sock blocking mine)
4/ If there is water in the filter and the drain motor runs then check that waste water hose is not blocked.
Aug 09, 2009 | Whirlpool LSR5132PQ Top Load Washer
Kicking out water during wash cycle - spin instead of agitation
Try these
  1. Check the drain hose, it should be at least as high as the top of the wash tub, about 38 inches.
  2. The drain hose must sit loosely in the house drain. Do not seal the air gap around the drain hose or a siphon will occur.
  3. Check the drain control lever
  4. Test the drain control coils
  5. Check the cam bar
pls rate my suggestion..
Jul 19, 2009 | Maytag LSE7806A Top Load Stacked...
Washer does nothing during rinse then leaks during spin cycle
hi thanks for the question i would check the drain hose your problem is the washer is not draining check the drain hose thanks the appliance doc
Sep 27, 2008 | Maytag Atlantis MAV6000 Top Load Washer
LG Top loader not draining water to rinse and spin
Jun 09, 2008 | LG WFT1071TP Top Load Washer
Leaking when entering the Rinse/spin cycle
what is happening is the pump is not pumping the water fast enough. your washer sounds like its a frididaire built washer. there should be a pause where the washer just stops and drains, then go into the spin cycle. so if there is water in the tub and the washer spins it will splash out from the top of the wash tub. you need to make sure the drain is clear, the drain hose is not blocked or kinked, and that the pump is functioning properly. your unit has a electric pump and even though you might hear it running the impellor my be damaged and able to pump the water fast could be as simple as removing the hose from the bottom of the tub that go's to the pump and removing a sock that found its way in. or just a bad pump. its a simple job to replace get to the pump remove the 2 screws on the bottom of the front panel tilt the washer back a little and slide the panel down. you wil see the pump on the lower left. so check all the things i listed and you should find the problem..Id check the pump first it most likley the problem. good luck
Aug 04, 2007 | Kenmore 88732 Top Load Stacked Washer /...
Washing Machines Logo
385 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
