On the left side interference that looks like static. also there's a deciding line down the center of the screen
SOURCE: Black Lines
My Hitachi TV Flat screen 42 EDT 4 1A has a one inch black line from the top to the bottom of the
screen on the left side. What or how do I fix it. I did blow it out with a air compressor as suggested by a local repairman.
Posted on Nov 16, 2008
  • 3459 Answers
SOURCE: Convergence lines are SLANTED. Red line is above
Your TV most likely a convergence failure. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Posted on Jun 20, 2009
  • 147 Answers
SOURCE: getting green interference on lcd tv especially on
unplug your lvds cable going into the control pcb reconnect cable into the control pcb.if this does not work replace control pcb first,then also could be a defective panel.
Posted on Jul 15, 2009
SOURCE: line down middle of the screen-resolution is different on sides
Have a black running veritcal down the middle of my screen with a white bar on each side..almost looking like a white ribbon going down the middle of the screen. I can see through the white ribbon though
Posted on Jul 29, 2009
SOURCE: Polaroid 40 inch tv (TLX-04011C) Picture is
its the ribon cables from the lcd patern bords on top there is 2 of them normaly its the right side that goes bad but in your case its the left there is only 1 way to fix it
you have to replace the lcd screen panel with the 2 pattern bords on top
Posted on Nov 12, 2011
Vizio vw42lfhdtv10a static lines
Sounds like AC line interference. Use an external line filter.
Jun 05, 2013 | Televison & Video
Vertical white line in the middle of rca tv
Check and replace all the electrolytic capacitors at its vertical output section circuit.
Mar 17, 2013 | Televison & Video
Touchpad pointer moves by itself. Moves slowly to either the top right hand corner or the bottom left hand corner.
Sounds like their might be some dirt underneath the surface of the trackpad exerting pressure causing it to move. Try turning down the sensitivity, do this under mouse in Control Panel.
Jul 29, 2009 | CMS Products - 160GB 5400RPM HD DELL...
Red static in black background ~ thin line running down center
Did you find a solution to your "red dot" problem? I'm having the same issue :(
Thanks John
Jun 17, 2009 | Hitachi 50HDA39 50 in. Plasma HDTV
Flaws, Speckles and smal white & black lines on the screen
might be a ground issue. plug it into other outlets and make sure the ground prong is still attached to the plug.
Mar 25, 2009 | Office Equipment & Supplies
Phillips Plasma Picture Way Off Center & A Static Line Appears
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size
Jun 03, 2017 | Televison & Video
Lines across view screen & on pictures; looks like interferance.
If your camera is Canon A85, then it has problem of bad CCD Imager Sensor this part will be replaced.
Please go to Canon CCD Advisory and see details if you want to have free of cost repair from Canon.
Oct 01, 2008 | Canon PowerShot A85 Digital Camera
Green line down left side and geen snow
Horizontal or vertical bars on the screen could be from an ac line interference, adjacent magnetic field, bad input wire connections.....especially HDMI connector cables. A bad HDMI cable causes all kinds of unwanted picture interference. Check the conditon of all connection wires for proper fit and function. Keep in mind the method in which you connect your tv will result how the tv performs. As well this line problem could be a circuit issue too, requiring a technician to look at it.
Jul 23, 2008 | Samsung LE32R73BD 32 in. HD-Ready LCD...
Horizontal ines---original post got wiped. Sorry.
leaky cap(s) in vertical circuit. shouldn't be more than $125 (plus taxes) parts and labour
May 14, 2008 | JVC AV-27230 27" TV
High Pitched Sound
I am to believe that your static sensor on the playing head is touching the the head and it sould not. just bend it up "slightly" and the noise should disappear
Dec 14, 2006 | JVC HR-S5902U / HR-S5912U VHS/S-VHS...
Televison & Video Logo
22 people viewed this question
Top Televison & Video Experts
