Question about Dishwashers
How can I pull out heating element for cleanning?
  • Tim Rickards
    Tim Rickards Apr 25, 2017
    Hi Keith Blanchard, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
  • Keith Blanchard
    Keith Blanchard Apr 25, 2017
    I tried to remove the heating element to clean a spill, I removed 2 screws and cannnot get them back in !
Ge ds4500eboww
Pull off exhaust vent. Clean. Remove back cover. Clean all airways free of lint and debris. Is this electric or gas dryer? If electric, plug back in and run dryer. Is the heating element glow red? Yes, check and make sure that air is now flowing freely out the back of the exhaust vent. No, replace heating element.
Jan 11, 2014 | Dryers
Whirlpool Gold Electric convection oven does not heat up.
Check for a broken wire or even broken element on top and bottom of unit. To do this, the unit must be unplugged or otherwise removed from power completely, then remove the screws that hold each heating element in place and gently pull out and inspect the wire connections. You should have just enough slack to check them. There should also be just enough slack to strip the wire clean to make the new connection to the heating element.
If the repair has been done before, you may need to fish a new lingth of high temp wire into the location.
Jul 13, 2012 | Whirlpool Ovens
When you run the dishwasher it sounds fine, cleans most things ok but leaves food particles on other things everytime. I pulled it out took of the supply line, pulled that screen out thinking that maybe it...
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
heatman101
Dec 20, 2010 | Dishwashers
Dryer starts (heat on) after 5-8 minutes heating cycle stops and only cool air run through.
your heating element need to be cleaned.......
1. pull the unit out from the wall
2. Remove the screws holding on the larger rear panel.
3. Using a vacume cleaner extension, remove as much debris as possible from all accessible components.
4. Clean out the dryer vent and the connection to the wall, making sure that air can pass easily.
THAT SHOULD DO YA. If the heat continues to cut off, you are dealing with a faulty heating element in which case you will be best off to purchase a new dryer. (replacing a heating element is typically the beginning of a failing unit)
GOOD LUCK AND PLS RATE THIS POST!!!
Jun 03, 2010 | Kenmore Dryers
Kenmore elite elec dryer, 110.64972300. runs no heat
Pull one wire off the element and start the dryer in a heat cycle . Check power from that wire to the cabinet . Touch the meter to the terminal you pulled that wire off of , and check that voltage . You cannot get correct voltage by checking across the element . Trace the wire NOT getting 120 volts . It will either go to the timer or motor . It will lead you to the problem .
Apr 28, 2010 | Kenmore Elite HE4 Electric Dryer
Is not getting hot.have cleaned the lint basket and pulled the basket holder and cleaned behind it. still not getting hot. could it be the heating element?
Deffinitely the next thing I would test. If it is tumbling and the timer is working, save having a wiring issue, which is highly unlikely, it probably does need a heating element.
Dec 07, 2009 | Fisher and Paykel DEGX1 Electric Dryer
Dry not heating
Have you cleaned the exit hose thoroughly? Pulled the exhaust line and cleaned?
Thermostat controls heat. There is also a motor centrifugal switch, in the element circuit, that the motor closes to insure the motor is turning. Try another heat setting. There is more than one thermostat. You may have blown the 'thermal fuse' too, which requires replacement. The element has a contact in the 'timer' circuit too.
It is possible that your element has failed also.
Tripped high limit. Must clean the lint filter and the exhaust vent tube and all the way in to the dryer. Hot air exit is restricted.
Sep 01, 2009 | Estate Dryers
Crosley CEDS774JQ0 electric dryer. It wasn't drying well so I pulled the vent line and cleaned it out well, ran the brush down the filter area too. Good venting now. But no heat, none at all. Ideas?
Do not know the model in particular, but by "not drying well" you mean not much heat, and then after cleaning there was no heat---would suspect the heating element (220Volts divides to 110 to make lower heat, like on a range burner) or operating on only 110v. The jostling could have completed the burn-out point of the heating element. Could check for continuity of the element (unplugged) using VOM (volt ohm) meter or flashlight bulb, wire, and battery--bulb metal to one end and wire to bulb tip and other end of wire to other end of element. If careful and safe access could check that voltage to heating unit is in fact 220 volts with VOM set to AC 600v setting (greater than 220v) unless automatic range setting VOM. (or check voltage to element first).
Also, remember when finished to check that vent hose is to inner vent pipe, not just to cabinet; lint build up in cabinet is a common reason for heating elements to burn out.
Aug 08, 2009 | Dryers
Miele G572 is not cleaning dishes correctly, I have pulled all arms off and cleaned, cleaned filters. Powder is not been flushed completely from door. Does the machine require servicing?
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
Dishwasher Problems The Heating Element not Working
heatman101
aqggffb
Jul 04, 2009 | Miele Premier-Plus Built-in Dishwasher
Dryer has no heat.
the heating element has probably burned open.
pull the element out and you'll probably find the break in the heating coil.
or possibly one of the leads going to the element has burned open.
good luck.......jay
Mar 21, 2009 | Whirlpool Kenmore 5.9 cu. ft. Extra-Large...
Dishwashers Logo
24 people viewed this question
Top Dishwashers Experts
