Question about The Computers & Internet
My stylus makes no clicking sound when I touch the tablet---can you help me ??
    Sergeant:
    Champion:
  • 296 Answers
Did it just stop or never did? Look in settings, sounds for display maybe or a reboot?
Posted on Apr 25, 2017
Cant hear volume too low
this could be a codec problem or video was record on low sound settings .try checking that your sound is up full right click on sound icon....open volume mixer make sure all slides are up full.
hope this helps
Apr 19, 2014 | Nextbook Premium 7 Capacitive Touch...
Lifebook tablet stylus doesnt work
Hello, Lori -
If you received a user's guide for your laptop when you purchased it, check the manual, starting on page 30 for instructions on using the stylus (called a pen) in the guide.
If you do not have a user's guide for your laptop, you can find and download one here (free):
http://solutions.us.fujitsu.com/www/content/pdf/SupportGuides/T4220_UG_B5FJ-4091-01EN-00.pdf
You will need Adobe Reader software (free) loaded on your laptop. After you download the guide, save it with a file name you can find easily - something like: Fujitsu Lifebook T4220 Manual. If your laptop is connected to a printer, you can print the guide for easy reference.
The information on using the stylus / pen begins on image 40 (page 30) of the PDF document.
Information from page 31 (image 41 in the PDF document) regarding the pen:
CALIBRATING THE PEN
In order to ensure accurate tracking between the pen
and cursor, you must run the Touch Screen Calibration
Utility before you use the active digitizer for the first
time, or after you change the display resolution.
To run the calibration utility:
1. Go to Start -> Control Panel and double-click on
the Tablet and Pen Settings icon.
2. Click Calibrate.
3. Adjust the display of your Tablet PC to a comfort-
able angle.
4. Using the pen, firmly touch the screen directly on
the (+) symbol; the (+) symbol will move to the
next location.
5. Repeat step 4 in the four corners, then click OK.
Best wishes.
Feb 09, 2018 | Fujitsu Computers & Internet
Stylus clicks each time it enters registering proximity to tablet
uninstall the driver and reinstall it, make sure you are using the correct OS for your computer
Jan 19, 2010 | Wacom Stylus Pen for Graphire4
Pin does not work when touched to screen.
The stylus has a AAAA (yes, QUAD-A) battery in the body of the stylus - if this is dead, then the digitizer won't recognize the pen. That sounds like what is happening - the batteries can be found at bigger Radio Shacks or ordered online.
Oct 22, 2009 | Motion Computing LE1600 Tablet PC
Single click registering as double click
Most likely your stylus is double-picking. It is difficult to determine in your software.
Download a test program and test the stylus and make sure the stylus does not give you two points with only one pick from the tip switch.
Jun 08, 2009 | Wacom Intuos3 Graphic Tablet
Problem with the touch screen an stylus
Press the Up + Down buttons at the same time. This will turn off the "Digitizer" function on the tablet and allow the user to use their finger, the stylus, or blunt end of a pen.
Aug 21, 2008 | Itronix Duo-Touch Tablet PC
Problems
The stylus pen works by pressure on the tip. Since the tc1100 uses an active digitizer, as soon as you come within range of the screen, the mouse should move (this is called pen-hover), however, if the tip is stuck upwards it will write or click instead just as if you were touching the screen.
Try carefully pulling out the tip using a needle nose pliers or your fingernails if they're strong, and then reinsert the tip gently. This should un-stick it. If this doesnt work, there may be an internal problem with the stylus.
Jul 26, 2008 | HP DG937A - HP Tablet PC TC1100 Tethered...
'Lag' or Trailing Line
I just did some more experimenting and it seems that if I replace the tip of the pen, it starts to react better, not great, but definitely better.
Again, I'm using an Intuos 3. On the Intuos 2 I was using, if I replaced the tip, it would improve, but I was going through tips every two months or so. That's why I bought the 3, thinking it would be better because I've never experienced this problem with my 3 at home (these problems are all happening at work). I'm not sure which tablet your have or if you have the spare tips that come with it, but that might be your solution.
Also, check your Wacom settings and make sure the "tip double click distance" is set to "Off". That should help a little.
Another forum post suggested not using the stylus stand or holder. It could...not sure that it actually does...damage the stylus tip so that it reacts as if pressure is being applied. My stylus at home is always in the stand and, since it does have this problem, makes me wonder if this is valid....but why chance it...different stands and different stylus.
Good luck and hope this helps!!!
Jun 11, 2008 | Wacom ET-45A STEEL Graphire2...
Marks..ugh
My Bluetooth tablet does that occationally. Perhaps there is a wireless signal inturptig the wacom signal. I find cycling the tablet off then on will fix this. A bit annoying but the only solution I have found so far.
Dec 22, 2007 | Wacom (PTZ930AC) Graphic Tablet
Computers & Internet Logo
27 people viewed this question
Top The Computers & Internet Experts
Perry Ralston
Level 1 Expert
ashu k...........
Level 1 Expert
ted dux
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
