KENMORE ELITE WASHER BACKING UP AND LEAKING ON THE FLOOR DUE TO LOWER BLEACH DESPENSOR CATCH BACKING UP WITH WATER AND OVER FLOWING.
    Sniper:
  • 57 Answers
From what you describe here, it sounds like the water level valve has gone bad. This is a common problem.
The water valve is located under the faceplate on most washers and has a clear hose that runs down to the washer tank. First inspect it to be certain the hose is connected and has no damage therein.
If the hose is in good condition, turn the washer on and watch it, see if the water shuts off when the tank is full. If not, replace the water valve.
Posted on Jul 25, 2009
Why does it leak all over floor after last spin cycle?
my washing machine leaks water onto the floor during each spin ...
https://answers.yahoo.com/question/index?qid...
Feb 3, 2010 - During drain and spin only A washer that leaks only during the spin cycle often has a leak in the main drain hose. ... It happened to us due to over loading. ...something can get betwen the two tubs it this all fails your tub seal is ...
Sep 30, 2015 | Kenmore Elite Oasis 27052 Top Load Washer
Why does the code F35 keep showing on the machine
Have you pulled the drain filter out? It is located beneath the door behind the lower panel. Remove the lower panel to access it. Once you see it put a bucket on the floor to catch the water if any comes out. The filter just unscrews. We want to make certain there is nothing trapped in there preventing the water from draining.
Aug 07, 2014 | Kenmore Elite 45986 Front Load Washer
Water leaks out of the soap dispenser of my kenmore elite front loader and all the soap or bleach us not out
The 1st thing to try is to take out the dispenser ,there is a little piece that you will push down and then pull the entire assembly out, rinse it out with hot water ,most likely there is a build up in the dispenser,there after use only powder detergent, and no more then 1 tbs ,and any other stuff IE bleach ,fabric softener,use 1/2 the amount and dilute it with water.
Jul 20, 2014 | Kenmore Elite 45986 Front Load Washer
Water flows out the hot tap in the back instead of flowing inside
You need a repairman the back are tricky to remove but you have something broken back there. You water valves are functioning properly but the route for the water is non-existent due to some sort of brake.
Mar 18, 2009 | Kenmore Elite HE4 Electric Dryer
KENMORE ELITE HE3 WASHER
2 things you may try if you haven't already ..let washer fill with hot water ..pause and open door pour in about 2 cups chlorine bleach before starting back up..with rag soaked in bleach/water clean inside front door boot ..be sure to roll boot toward front and clean out accumilation under it wash as much as possible off door seal..allow to finish cycle (normal wash should be fine)..may also try removing lower panel remove pump acess plug and clean pump out thoroughly..you are not alone ALL front washer have same issue and if some sort of routine cleaning isn't done problem reoccurs also leaving door slightly open between usues will help ..by the way that is a german made washer
Sep 12, 2008 | Kenmore Elite 45986 Front Load Washer
Leaks water onto floor in front of washer after spin cycle, help
open the door though, put your hand around the rubber boot assy, run *** all around looking for small tears, and or holes, if so replace it. only other thing to do is remove the lower access panel and watch it spin a load and youll be able to detect where te waters coming from
Mar 22, 2008 | Kenmore Elite 45986 Front Load Washer
Top Load Kenmore Elite Bleach Dispenser Leaking
I have this same problem today and did not need to take off the top panel or remove the front panel/housing. The bleach and frabric softener dispenser snaps right out and you can check the tubing and clamp from there. You will need to remove the top panel if you need to replace the tubing. In my case, there is a crack in the dispenser itself which has ruined several loads of laundry over the past year...now I realize it wasn't the clamp and hose, but the dispenser itself. Check them all while you are at it.
Nov 18, 2007 | Tecnik TKL9260 Front Load Washer
Kenmore elite top load about 3 years old
Check the boot for tears, also remove the lower axcess panel (Three torx screws or 7mm) and see where the water is coming from.
Sep 24, 2007 | Kenmore Elite 45986 Front Load Washer
Leaking // bleach/fabric softener dispener isnt emptying
Stara, sounds like you have a couple of issues going on here. On the model you posted there was a service flash on the dispensor. They redesigned it to provide an additional air gap for release. There was also a flash on the bleach hose splitting and leaking. The service flash numbers are 26-747 for the despensor and 26-746 for the hose leak. It almost sounds like your transmission is not going into it's nuetral drain. After completeing the agitation, it should drain for about 90 seconds before spinning. This would be a gearcase problem. The gearcase is covered for a period of 5 years, part only. You might want to check where you bought this unit and see if the parts are covered under warranty. Including the dispensor and hose. You would have to pay the labor..Hope this info helps
Jun 13, 2006 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
