Question about Garden
Hi, need to replace cord on handle, where do I get one from?
    Top Expert:
  • Garden Master
  • 50,514 Answers
Not enough information
post again and include details like make, model year, type of equipment
posts are not linked
Posted on Apr 25, 2017
How do u fix a loose starter cord people?
Hi Rick:
Most starter cords rely on a recoil spring to make them retract.
Sometimes when the cord is replaced it is longer than the original so just needs to be shortened. Pull the cord all the way out and if you have way more than you use for a pull start, then shortening it is a fast fix.
To do that, pull out the cord a couple of feet. flip a slip knot in it to keep it from retracting, then take the start handle apart and shorten the cord about 6 inches. Should work fine.
If the cord is talready too short to make it shorter, you'll need to put another wind on the spring.
Reply as a COMMENT to this post af you need coaching through that.
Hint. Don't dismantle the spring assembly so it can get out. They are related to rattlesnakes.
Cheers.
Feb 08, 2016 | Garden
Need handle replacement and power cord for sunbeam mixmaster mmb
NelsonEZY.com stocks the power cords. The handle should be available on eBay. NelsonEZY com home page
Mar 22, 2014 | Sunbeam Vintage Chrome Mixmaster Mixer Mmb
Pull cord wont recoil homelite xl 12
You will need to take the cover off to get to the recoil, then remove the pull handle do not let go of the cord! Now ease the cord into the reciol but do not let the cord go, now while holding the cord and the recoil spool rotate the spool 1 revelution clockwise, send the cord back up through the case hole and through the pull handle tie the knot in the cord and replace the case if this still isn't enough repeat the process.Dennis
Oct 31, 2012 | Homelite Garden
How do i fix the pull start and re tension it so cord retracts?
You take the top of the motor off with the starter, then rewind the spring,then is a good idea to replace the rope with a new one they sell rope at a lawnmower store, get 5 feet or more if the rope is up on the handle, take a piece of rope with you to get the correct size.
Aug 20, 2012 | Electric Earthwise Corded Lawn Mower...
Toro 6.5 recoil handle cord loose
yes you will need to remove the top cover to replace the starter cord
Apr 22, 2012 | Toro Garden
Hilti te 22 no power
Most common for the TE22 was the switch and or cord. To get to handle off take a 5mm allen wrench and take the two screws off the bottem of the handle and then stick the wrench in through the hole in the top of the handle and remove the screw on the inside. Then take the two phillip screws off the side of the handle to seperate the two halves. You will need to take a continuity tester and read each cord from the plug to the switch. If that reads out continue to read the contacts on the switch. The cord you can replace but if the switch is bad there is not a replacment for it.
Hope this helps.
Nov 24, 2011 | Hilti TE 7-C 120V Rotary Hammer Drill
The starter cord has snapped. Can it be replaced?
Yes.Go to a harware store they or at least most sell the cord you need in bulk.Keep the handle as you will need it.Remove the fly wheel cover and the cord attaches to the fly wheel.Tie a knot in one end of the cord and slip it through the handle.Thread it through the hole in the fly wheel cover.Then just wrap it around the fly wheel.Reattach the cover,and you are done.
Jul 09, 2011 | Briggs & Stratton Garden
Rope needs rewound, got tangled up , had to remove the 4 nuts, now need to get in back on wound tight
I assume that you are speaking of a pull start mechanism.
I can not imagine how to put a put pull starter back on "wound tight". Your pulling on the cord tightens a spring which pulls the cord back in. They go back together with the cord fully wound onto the spool.
Usually, I only take these apart to replace the cord. Wind the new cord onto the spool without handle. Reassemble, then pull out on the cord a little when attaching the handle to the cord. This is the only way to get tension onto the spring at the fully retracted position because the catch for the spring is on the machine and the spring itself is on the underside what you are assembling.
If you do not wish to shorten the cord or replace it, then remove the handle, assemble enough to catch the spring, wind one turn tighter then feed rope through hole and reattach handle. Easier said than done.
If your spring is broken, then you will be needing a new one.
:o)
Jun 03, 2011 | Craftsman Garden
REplacing the pulling cord on a gas trimmer
those are usaully under your pull start cover and if its broke you can buy a new rope but if its broke near handle i would open it and retie it to save ya money. but remember to wind spring a little to keep tension on it before pushing it through the hole for handle.
Apr 17, 2009 | Craftsman Convertible 25cc. Gas Line...
Broken starter cord lawn mower #944.368300/craftsman
Please note ! patients is required with this one !
Hi, remove the recoil top cover with the recoil attached. ( DO NOT TAKE OUT THE SPOOL OR YOU COULD HAVE THE SPRING GET YOU IN THE FACE)
Remove old cord.
With your new cord lace it through the recoil spool centre hole with a knott on the end.
now depending if the recoil winds in clockwise when spool is facing you wind the cord around it a few times by turning the spool clockwise,
Then put the cord in the notch at the side of the spool & wind the spool & cord anticlockwise about twice the number of turns of cord (this should tension the spring).
Take your end of the cord & lace it through the hole outside of the casing & fit you pull handle.
But hold the spool firmly untill the cord has a good knott on the end of it.
(Sometimes I see the guys here putting a loop in the cord to stop it sliping in while they tie a knott on the end of the handle.)
Sep 09, 2008 | Garden
Garden Logo
27 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
