Question about Hardware & Accessories
How do I set the timer for 4 hours daily? - Hardware & Accessories
My stereo keeps turning off when I listen to a station 101.5 in New Jersey
The only thing that can be is that you have set a timer "sleep" function for that station. I have looked at the manual and it states you can programme a sleep setting for a radio station.
The instructions are on page 12. But I have extracted them below:
1 Press the ON/STAND-BY button to turn the power on.
2 Press and hold the CLOCK/TIMER button.
3 Within 10 seconds, press the or button
to select "ONCE" or "DAILY", and press the MEMORY
button. Set the clock to the correct time if "ONCE" or
"DAILY" does not appear.
4 Within 10 seconds, press the or button to select
"ONCE SET" or "DAILY SET", and press the MEMORY
button.
5 To adjust the hour, press the or button and then
press the MEMORY button.
6 To adjust the minutes, press the or button and
then press the MEMORY button.
7 Set the time to fi nish as in steps 5 and 6 above.
8 To select the timer playback source (CD, TUNER, USB,
iPhone/iPod, TAPE or AUDIO IN), press the or
button. Press the MEMORY button.
When you select the tuner, select a station by pressing
the or button, and then press the MEMORY
button. If a station has not been programmed, "NO
PRESET" will be displayed and timer setting will be
canceled.
9 Adjust the volume using the VOLUME control, and then
press the MEMORY button. Do not turn the volume up
too high.
10 Press the ON/STAND-BY button to enter the power
stand-by mode. The "TIMER" indicator lights up and
the unit is ready for timer playback.
11 When the preset time is reached, playback will start.
The volume will increase gradually until it reaches the
preset volume. The "?" or "DAILY" indicator will blink
during timer playback.
12 When the timer end time is reached, the system will
enter the power stand-by mode automatically.
Once timer:
The timer will be canceled.
Daily timer:
The timer operates at the same time every day. It
will continue until the daily timer setting is canceled.
Cancel the daily timer when it is not in use.
Jan 06, 2016 | Sharp CD-DH950 5-Disc Compact Stereo...
How ahould i set my timer on my 110volt spa?
It should run at least 4 hours in every twelve. (eight hours total daily)
Feb 14, 2014 | Pool & Spa
Setting clock
Hello
To set clock:
1. Press "Timer/clock button". The hour digit begins to flash.
2. Press (<< P.DOWN or >> P.UP) on the multicontrol to set Hours.
3. Press SET button. The minute digits begins to flash.
4. Press (<, P.DOWN or >> P.UP) on the multicontrol to set Minutes.
5. Press "Set" button."CLOCK OK" appears on the display. The clock stops flashing, and the clock timer starts from "0" seconds. If the clock is not set "AM 12:00" will flash instead of the clock indication. When the time has been set, TIMER/CLOCK can be used to operate the daily timer recording timer.
If you haven't the user manaul to your set with you now, send your email address to me by Fixya comment bos. I've the downloaded user manual to your set, and I'll send a copy of it to you by return mail. OK.
Jan 21, 2012 | JVC MX-D402T Shelf System
How do you set up a nomatd1000 daily digital timer
You posted under TD1000 timer.
Open following link to identify timer and download manual:
http://waterheatertimer.org/Woods-timers-and-manuals.html#Oval
Mar 19, 2011 | Woods Indoor 24 Hour Digital Timer (59203)
How do i set this time to come on and go off daily
I believe the First Alert timer is same as GE 15151 vacation timer.
http://waterheatertimer.org/GE-timers-and-manuals.html#vacation
If this is not your timer, then add a comment.
Also look at Woods timers on link below to help identify timer.
A vacation timer turns on-and-off randomly to give the appearance that somebody is home
This timer cannot be set for daily on-off schedule.
GE markets a number of timers for daily repeat programming:
When buying a timer, note that some are for 2-prong plugs and some for 3-prong plugs
http://www.amazon.com/dp/B0015GKI96/?tag=picc-20
http://www.amazon.com/dp/B002HEY300/?tag=picc-20
Woods makes daily timers and a weekly timer
http://www.amazon.com/59419-Appliance-2-Prong-Outlet-24-Hour/dp/B002Y1KZHQ
http://www.amazon.com/Woods-59202-Vacation-Security-Appliance/dp/B001Q9EFT6
Dec 20, 2010 | First Alert Tm261 7Day Vacation Timer
How do i set this timer to come on and go off daily?
A vacation timer turns on-and-off randomly to give the appearance that somebody is home.
How does this timer work? I lost pkg with info.
Rotate dial until current day and time line up with arrowhead located on inner dial.
The timer will turn on-off according to preset schedule
Dec 19, 2010 | First Alert Tm261 7Day Vacation Timer
The instructions indicate to push the outer segments down with pen, etc to set timer. I can't get the segment to go down.
Generally the segments are already pushed down when you buy timer.
Instruction usually say, pull up all the segments, and after pulling up all the segments, then push down the segments for the hours you want the timer turned OFF or ON depending on timer
51ec3fc.jpgSegments on GE 15207 timer
Oct 12, 2010 | Hardware & Accessories
How to set Cannon NP6050 to shut off at 5
those daily timers are for shutoff
Nov 18, 2008 | Canon NP 6050 Copier
Hardware & Accessories Logo
50 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
