Question about Section Car Audio & Video
What causes one boom valve not to work have plugged motor into other section to determine motor ok also tried new motor without attaching to valve with no respose
Green wire to boom valve doesnt have current when valve is turned off working valves do have current have traced back through connecters red wire 12v black wire 7v where does green feed from ?
  • 5 Answers
SOURCE: starter motor will not work unless 12v feed put through relay
Have you checked the solenoid across the main posts i.e.connection from battery to starter,you may be hearing the solenoid clicking when you operate the starter button,but it might not be completing the circuit.
Posted on Apr 11, 2009
Editor925
  • 285 Answers
SOURCE: To wireup 160c Garmin fishfinder, there are seven
You only need the red and black wires to supply power to the unit. The red positive wire goes to a positive terminal on your battery or positive side of a bus bar or switch, the black negative wire goes to the negative terminal on the battery or negative common bus bar. Do not try to earth the black wire to an aluminum boat hull... You are asking for trouble! Best to run the black wire straight back to the negative battery terminal or negative bus bar that is wired to the negative battery terminal. The other colored wires on the 160C plug are used for interfacing with NMEA2000 compatible devices, like a compatible GPS.
Posted on Jun 15, 2009
rockitman187
  • 2559 Answers
SOURCE: will not feed wire when trigger is pulled. feed
1. Wire jammed
2. Out of wire
3. Not enough tension
4. Wire liner worn
5. Wire disconnected internally
6. Contact tip clogged
Posted on Aug 06, 2009
  • 3238 Answers
SOURCE: replace honeywell V8034F1051 zone valve
why not just but the head or come to that the motor in side , cheaper option
Posted on Jul 13, 2010
Testimonial: "Prompted by your suggestion, I bought only the replacement head for the honeywell valve, saved me money and was so easy to install. Thanks!"
canwoodjc
  • 3301 Answers
SOURCE: Purchased: Carriage House II
check this link for a diagram, http://www.wiringhelp.com/electrical/electrical-how-to/how-to-wire-a-ceiling-fan.html go down to the diagram with 2 switches,, click it, it will enlarge,
Posted on Jul 10, 2011
07 420trx gets hot back fires will not take throttle stalls valves adj ok fan works
How did you determine valves are ok? Checked lash when dead cold (off overnight)? Insured valves are not sticking? BTW, is this posted in the correct section?
Oct 24, 2016 | Cars & Trucks
Replace cylinder in bottom boom on hiranger bucket truck
ive heard of folks doing it without a crane but i would not try it , alignment is too critical with getting guides and stops back in and with nothing to move boom that would be too difficult
anyways: suspend boom end with double straps from crane , disconnect hydraulic/electric swivels/plugs at truck end lift end of boom slightly with boom all the way extended straight out , remove acess panel (both sides) at jct of upper/lower boom section . remove C clip one side drive out pin oppisite side (wiggle boom to clear pin) locate stops in lower section boom end unbolt , slowly pull upper boom with crane away take care of hydraulic lines and electric wires set on floor on wood cribbing , locate bottom of cylinder truck end find C clip and pin Might be behind a trim cover that might need to be remove drive out pin also remove bottom cylinder hyd hose connect crane to cylinder end move out a foot or so remove top cyliinder hydraulic hose then carefully slide out cylinider with crane , Note if your valves are not tight and new oil will leak back and cause boom base to sag when you unhook hydraulic hoses , your gonna need to block this up with wood cribbing just in case
reverse removal process to install new one , also i would not just install a new seal (you can) with out having cylinder recromed I'll bet it's rusty thats what tears the seals up
and allways replace entire oil volume in hydraulics your old seal is in old oil not good for the new one
Apr 26, 2014 | 1985 Chevrolet Chevy
Geo storm wont start after putting in new battery,altornatior,plugs and wires,and cap and rotor
storms, those are very rare. and Isuzu is very dead here.USA.
which size engine?
wont crank/?
or cranks ok, but wont start.
its old.
1:check compression, yet, over 150PSI (w.o.t)
2: check for spark at all 4 cylinders?
3: try test fuel if spark is good (spray fuel)
watch scotty
http://www.youtube.com/watch?v=064Ilsz8Fzg&NR=1&feature=fvwp
tell us how far you get.......
btw , it really a:
manufactured by Isuzu and sold in the United States by General Motors from 1990 through 1993 as part of GM's Geo line
btw2
1.6L DOHC (Storm) Interference
both DOHC engins are interfernance
if you skip belt changes, the valve bend and bye-bye engine.
BOOM
and a new motor is more that car is worth.
Feb 18, 2014 | 1992 Geo Storm
Flymo 46s won't start. Starts to fire when turned
Possible blocked air filter, try as a test running the engine with filter removed, if ok replace with new filter.
May 02, 2012 | Briggs & Stratton Garden
My Craftsman 15 Gal Air Compressor trips the electric breaker at start up no mater where I plug it in.
Just fixed my compressor. It would start ok when the tank was empty but trip the breaker if it tried to start with pressure. Searched and read about weak caps, or problem with check valve or pressure switch leaving pressure in the pump head, etc. Turned out that the black plastic box which holds the 2 start up caps and is attached to the end of the motor with 2 screws had cracked on the bottom. The black box had tilted out enough that the start up caps switch was not engaging. Pushed on the lower part of the box and it started perfectly. Fixed it for the cost of some 2 part epoxy. Maybe not your fail, but definitely worth checking out first.
Apr 12, 2012 | Craftsman 15 gal Air Compressor 3 hp UMC...
How do you unlock a sony ericsson f305?
Can't find how to send you a message so thought I would post on your question sorry about this I have gained a karcher hd6/13c Resealed cylinder head only the 3 plungers And the 3 seals on thrust guidance Runs ok when reassembled but when you stop and try to restart washing motor won't turn pump. If you turn motor fan on top it's eay to turn then it will work again until you stop again Had motor running fine without pump attached Got a drawing of pump assy 01060320 Can't remove No 24 over flow valve 45910380 No 11 drain plug. 41320070 Thanks for any help John
Feb 28, 2012 | Cell Phones
Washer doesn't reach enought output pressure. motor starts and stops at rendom.
First you have to do is try the machine without load. Attach everything as usual but do not attach the lance. Put on machine with water supply already on. If you close the gun the machine should stop. If you open the gun ( always with out lance)....the machine should start sending the water a bit far. If this is OK....then you have a lnance with a faulty, blocked NOZZEL.
NOrmally the machine stops when gun is released because there is a valve (Spill Valve) that actuates a electrical micro switch. This in turn closes off te elecreic supply...stopping the machine.
If with out lance your problem is still there....then the spill valve is faulty. AS I first said you must be sure that the nozzel is OK, so that you can blame the Spill Valve.
I raely service Spill Valves (Control Valves). I change with a new one. When open the cover using a TORX T15 screw driver....you locate the spill valve where there are 2 wires coming out. Some machines have the spill valve incorporated with the head and the intake and delivery valves unit. This I advize to change with new parts. These all in one heads are very good because at one go you change the spill valve and the other valves in one go.
Therefore in a few words you either have a blocked nozzel...or you have the spill valve faulty.
Also the delivery valves could be blocked...thus creating pressure inside and activating the spill valve to close off the electricity. You can also try to start the machine without gun and hose attached...but always with water being fed. NEVER put on a power washer without water being fed. And never store a power Washwer withpressure in it.
Fulltech.
Apr 25, 2011 | Karcher K2.26 Electric Power Washer
On start up, the motor ran slow then popped the circuit. plugged it into a 20 amp circuit, it ran a little stronger then shut off without popping the circuit. Motor was hot, and after a short period the...
It sounds like the compressor is trying to start under load because there is a tightness in the pump itself or there is high pressure air in the line between the pump and tank There is a small valve that releases the pressure out of the main pipe that runs between the compressor and tank once the tank is full and the motor automatically cuts off. You know this valve is working by the sound of a short spurt if air being released when the motor cuts off. Releasing this pressure means that the motor is able to restart easily because there is no load. If the valve is not releasing this air, the compressor is trying to start under full load which the motor is not capable of doing, hence the slow running, overheating and popping of breakers due to a current overload as the motor tries to run up to normal peed. Motor burnout is possible if it keeps recurring.
This small release valve is attached to the Pressure control switch that switches the motor On & Off and usually has a small pipe going to it or is incorporated inside the Pressure Control Switch. If the valve appears to be working then it means that the Non-return valve on the input to the tank is not sealing properly and letting air back into the main pipe causing the compressor to start under load. Check both valves for correct operation and replace as necessary.
If all the air side checks out OK the check for low oil level and / or binding in the air pump main drive shaft.
Dec 11, 2010 | Craftsman 33 gal Air Compressor 6 hp...
Engine vibrates when idiling in drive only does not vibrate in park or neutral or reverse has new motor supports (all) recent tuneup cant determine cause (the motor runs so smooth except while idiling then...
Check your throttle body gasket, if it's leaking unmetered air it will idle high, this coupled with a bad ignition coil, plugs not properly gapped or old/worn as well as old/worn spark plug wires will cause a misfire that may not trip the CEL light. Also check your idle air control valve to ensure it's working and clean on the inside of the throttle body.
Nov 28, 2010 | 2002 Kia Spectra
Have new proper batt.Have new starter celenoid,new
Remove spark plug and attempt to crank. If it turns faster (without compression) it may be valve adjustment. If it still turns over slowly with plug out check battery ground for tightness to mower body. If the ground is good check the starter by removing battery and atttaching jumper cables to pos and neg battery terminals first, then the pos jumper to starter terminal (where red wire attaches). Then touch the neg jumper to a good engine ground (I use shroud bolt). Be careful as this last connection will cause some arcing. If it still cranks slowly with the plug out, it is probably the starter.
Apr 11, 2009 | Craftsman Garden
Car Audio & Video Logo
Top Section Car Audio & Video Experts
xxxxxx xxx
Are you a Section Car Audio and Video Expert? Answer questions, earn points and help others
