Question about GE Lands Phones
My GE model 30544 base suddenly started making a beeping sound every ten seconds. I found no solution to this problem in the manual. I need to know the cause and how to stop it.
  • GE Master
  • 2,045 Answers
Try to disconnect power then reconnect.
Posted on Apr 25, 2017
My GE cordless phone Model No. 28112ee3-a is not functioning and it keep beeping. I once found a code to stop it from beeping. can anyone help?
The GE 28112EE3-a was made by Thomson with the GE name. The manuals for most of these phones are available here: . The direct link to the manual is .
What type of beeping are you hearing? If you are hearing a beep every seven seconds from a handset, the solution is to recharge the battery. If the battery won't hold a charge, then replace the battery with a 5-2721 Nickel-metal Hydride battery.
The handsets can also beep for about 2 minutes if another handset or the base pages them. This is a locator tone. Just press the Talk/Call Back button or the Tone/Exit button on each handset.
I hope this helps.
Sep 21, 2014 | Thomson GE Cordless Telephone 27995GE1
Don't have a manual need to set announce message
Turn on auto answer mode by pressing ans on/off button on base. Message indicator should light. Now press and hold the announce button until you hear an audible beep. After the beep start recording your message. Release the button after you have finished dictating your message. To review your message press and release the announce button.
Also if you need it the manual for your phone can be downloaded from
Goto Telephone > More manuals for ge telephone
You will find it in the list there.
Apr 18, 2009 | GE 25952EE1 Cordless Phone
Battery won't charge
If you have a new battery, than you may have a bad connection between handset and base. Make sure contacts are clean. you can use cotton swab and rubbing alcohol.
Also while handset is on base, unplug base, wait 10 seconds are plug back in.
You may also want to double check phone cord.
Mar 31, 2009 | GE Lands Phones
GE Profile PDW7880G00SS Dishwasher will not Start
Re: My dishwasher start light flashes and the timer display is blank.
That is a fault condition, if the display is blank it is probably a faulty control board.
Unplug the appliace from main, or trip circuit braker to cut power for ten minutes.
If display is still blank on startup, then replace the timer control assembly.
Mar 13, 2009 | GE 24 in. Profile PDW7880G Built-in...
Model 25922 5.8 GHZ Cordless phone with one main phone and two extras
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Ge Telephone Solutions
Handset can not link.
• If any handsets become inoperable, place it on the main base cradle for 20 seconds to re-register.
No dial tone
• Check or repeat installation steps
• Make sure the base power cord is connected to a working electrical outlet.
• Make sure the telephone line cord is connected to the base unit and the modular phone jack?
• Disconnect the base from the wall phone jack and connect another phone to the same jack. If there is no dial tone on the second phone, the problem might be your wiring or local service.
• The handset might be out of range of the base. Move closer to the base.
• Make sure the battery is properly charged (for 16 hours).
• Ensure the battery pack is installed correctly.
• Did the handset beep when you pressed the TALK/CALL BACK button? Did the in use indicator come on? The battery may need to be charged.
Sep 02, 2008 | GE 26998GE1 Cordless Phone
GE DECT 6.0 Model 28111EE2 is not working, registration failed message
I had the same problem, and restoring to default settings did not seem to work either. I just opened the back, unplugged the battery, plugged it back in, and now it works again.
Aug 26, 2008 | Uniden Cordless Phone
GE Quiet Power II Dishwasher
My GE dishwasher will only flash the start button and when I try to change a cycle it flashes the regular cycle and beeps every ten seconds without starting. I have had success once turning off the breaker and it resets.
May 11, 2008 | Dishwashers
Ge edge model 25951ee3
I don't know where a manual can be found, but I know you need to place each handset in the main cradle / base station for at least 20 seconds for the handset to get Registered to that base station.
Dec 25, 2007 | Uniden Cordless Phone
Handset wont register
To register the handset:
1. make sure phone is charged
2. hold down the "mute/program button on the phone 10 seconds.
3. you should see a message on the screen that says you need to push the "pager button" on the handset.
4. Push the pager button
Apr 10, 2007 | Uniden Cordless Phone
Lands Phones Logo
Top GE Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
