Question about Crock Pots & Slow Cookers
Hi Di I need to put the valve on when I'm using the slow cook option
Can you use crock pot liners in a pressure cooker
hi Carol.
this is all i could find out.
Can you use a slow cooker liner that Reynolds offer for the 6Quart pressure cookers? I'm not sure since the lid is a twist on/off. I successfully put a Reynolds Slow Cooker Liner in the instant pot and use the slow cook function. The liner seems to work equally well as it does in my slow cooker. Customer Questions & Answers
Can you use the liner of a crockpot in the oven?All Crock-Pot® Slow Cooker removable crockery inserts (without lid) may be used safely in the microwave and the oven set up to 400°F. If you own another slow cookerbrand, please refer to your owner's manual for specific crockery cooking medium tolerances.Oven & Microwave Safety - Crock-Pot® for: Can you use the liner of a crockpot in the oven?
or go to this link.
Can you use crock pot liners in pressure cooker Google Search
Nov 29, 2017 | Crock Pots & Slow Cookers
Della 12 Quart 1600-Watt Electric Pressure Cooker Multi-Functional Timer Slow Cook XL Part number: 048-GM-48261 Unable to get this cooker to slow cook.
it is possible that you have misunderstood the instructions
for a slow cooker you have low medium and high
press slow cook and on low and in 8 hours the food is cooked
I see from your statements that you expect the cooker to be set on slow cook but cook at a high temperature fast
if it says slow cook --9 hours and the temp is 125 degrees , have you waited 9 hours to see if it is cooked as the slow cooking process is by the gradual build up of heat in the container that is not expelled by radiation to the air
in a pressure cooker , that build up of heat also builds up pressure and so it cooks better
other solution--- if it is not right return it for a warranty refund or if out of warranty , junk it and get a different make
Mar 25, 2017 | Crock Pots & Slow Cookers
Paula deen pressure cooker. Can I use it for slow cooking? What is temp of keep warm? Could put lid on loose. Also, timing notches are mixed into keep warm button. I overcooked my first batch
A pressure cooker is NOT anything close to a slow cooker. The cooking philosophy are practically totally opposites. A pressure cooker basically cooks your food in a fraction of time because it is under pressure. A slow cooker takes hours.
The whole idea of using a pressure cooker is that it is sealed and applies pressure to cook the food faster. The lid needs to be sealed for the pressure cooker to operate properly. It is frequently referred to as "infusion" cooking now days.
You need to read the instruction book that came with the pressure cooker. Pressure cookers usually cook for less than an hour--my homemade pressure cooker spaghetti sauce is cooked in less than 30 minutes. They are nice and were very popular long before anyone thought of microwaves and slow cookers. However, there are some precautions to be taken. There must be water or liquid in a pressure cooker. The rubber seal needs to be cleaned frequently and, when the rubber seal warps/stretches and no longer seals, it needs to be replaced. There are also certain foods that CANNOT be cooked in a pressure cooker like rice, dry beans, etc. The pressure control valve operates to regulate the amount of pressure and releases extra pressure otherwise the unit would blow up (very dangerous!). Most pressure cookers (required on all new ones) have a small rubber emergency stopper that will "blow off" in case the pressure is too high. I've seen this happen and my mother cleaning potatoes & meat from the ceiling!
Mar 03, 2017 | Crock Pots & Slow Cookers
Where can i find a manual for ultrex pressure cooker?
The company had a major recall and went out of business. No manuals appear to be available on the web.
Here are some general instructions you can use:
1 Set up your cooker. Place your Ultrex Pressure Cooker on the stove. Remove the lid and pour in no more than 2 inches of water. Depending on what you are cooking the amount of water will vary. More water will ultimately cook larger amounts of food, but you will need to refer to your specific model's instructions on this matter.
  • 2 Put in the food you wish to cook. Close and lock the lid firm to the pot. Make sure it is locked securely so none of contents boil out of the top.
  • 3 Turn on your burner to high heat for approximately ten minutes. Allow the water to boil.
  • 4 Turn the stove down to a low setting after the water is boiling in the cooker. Flip the pressure valve closed and allow your food to simmer.
  • Set the pressure valve to ten pounds. For vegetables, cook 30 to 45 minutes. For meats, cook 45 to 60 minutes.5
  • 6 Open the pressure valve and allow the pressure to discharge. Unlock and remove the lid to find your fully cooked meal.
  • Aug 25, 2014 | Ultrex Crock Pots & Slow Cookers
    Presssure valve to be turned off or on when using pressure cooker
    pressure cooker cooks by the pressure inside the cooker.
    So you need to put those on when cooking.
    The excess pressure will automatically drain off.
    Jun 12, 2012 | Nesco Electric Pressure Cooker
    I need the user instructions for use
    Hi and welcome to FixYa, I am Kelly
    I see I am nearly a month late in replying to your post. I just answered another post and when I finished I saw your question.
    This is driectly from the user's manual that you can find here with some difficulty:
    (Avoid answering questions by looking for the blue text that says "security code" and clicking that) Then enter the 4 digit code to download the manual that is 209k)
    1. Place food in stoneware according to recipe.
    2. Plug in Smart-Pot slow cooker. The Power light will begin to flash indicating that the unit is plugged in, but not turned on.
    3. Push the Cook Time button to scroll through the timed cooking options. Push once and the 4 hour light will illuminate, twice and the 6 hour light will come on, etc. Select the time based on the length of time indicated in the recipe. Two time options are usually given. The 4 and 6 hour settings are the HIGH temperature setting and may be used when you want your food done quicker. The 8 and 10 hour settings correspond to the LOW temperature setting and is used for all day cooking. In addition your Smart-Pot can be set to the Warm Setting by scrolling through the timed cooking options until the warm
    light illuminates.
    NOTE: The Warm setting is for keeping already hot food warm. Do not use the warm setting to cook or reheat food.
    4. When the cooking time is completed, the Smart-Pot slow cooker will automatically shift to the Warm setting and the Warm light will come on. NOTE: We do not recommend using the Warm setting for more than 4 hours.
    5. To turn the Smart-Pot off push the OFF button. Unplug unit from the wall outlet.
    6. For other recipes that give a range of times, select the time closest to the setting on your Smart-Pot. For instance a recipe calling for cooking time of 7 to 9 hours on LOW, set your Smart-Pot to 8 hours.
    NOTE: If power goes off then power light will blink and settings must be reset. If cook time is changed before the cycle is complete the time will reset to the new setting.
    That is pretty much the entire user instructions. Everything else is warnings, cautions, and oh yes; don't submerge it in water yadda yadda....
    Thanks for choosing FixYa,
    Feb 05, 2011 | Rival 38601 Smart Pot 6-Quart
    Please tell me how this appliance works. Thank you. Mary Jane Howroyd Kitchen Aid Crock Pot
    Make sure that what you are cooking is something that can be cooked in a slow cooker. Put all the ingrediants into the pot, plug it in and set it to either Low -This setting is the most used setting. Usually takes 8 hours or so depending on what you are cooking. High -This setting is faster and usually cooks in half the time as Low, but meats aren't as as tender cooked on this setting. Also make sure you put in enough liquid. You usually want the pot filled 2/3 with whatever liquid you are using to cook with.
    Dec 27, 2010 | KitchenAid Crock Pots & Slow Cookers
    Lost Manual - not sure which is high or low
    Hi. I'm a Ronson Service Centre.
    I grabbled this blurb from a Ronson Slow Cooker Manual. Not the same model, but it has the same settings:
    On Setting 1 (Low) the Slow Cooker can operate all day and night if required.
    When set to 2 (High) it is very much like a covered pot on the stove. Foods will cook in ½ the time required for 1 (Low)
    When set to Auto, the Slow Cooker will cook on 2 until the food reaches a pre-set temperature, then switches to 1 and maintains a constant slow cooking temperature.
    “Auto” is the ideal setting for someone leaving the house for the whole day as most food will cook for 8-9 hours and be ready to serve when they return.
    Mar 15, 2009 | Crock Pots & Slow Cookers
    To add water or not to add water????
    Slow cookers do not need water in the base unit to cook the food in the ceramic insert. The ceramic insert gets hot from the base and cooks the food. Here is a good guide to cooking with a slow cooker. enjoy
    Dec 06, 2007 | Select Brands SC-25 2.5-Quart
    Crock Pots & Slow Cookers Logo
    77 people viewed this question
    Top Crock Pots & Slow Cookers Experts
    Irene Tulloch
    Are you a Crock Pot and Slow Cooker Expert? Answer questions, earn points and help others
