Question about Dishwashers
Hi, I have EUROART DS9800 D/W & am having trouble with the gasket at the bottom of the door, not sure which way it goes. Cheers.
3 Suggested Answers
  • 154 Answers
SOURCE: Hi just finished today my new kitchen, ds9800 new euro art
Don't know Euroart. However I would bet it is a Chinese manufactured product with European aspirations.
Anyhow, if the machine keeps filling up there could be a problem with either your inlet valve/solenoide. Sometimes the solenoide sticks and does not shut the water off.
Or alternatively your pressure switch or pressure hose has a problem. If the pressure hose has come loose then the pressure switch does not detect water level.
Hope this helps.
Regards
Ash
Posted on Nov 11, 2009
Testimonial: "ash helped but i need some hands on solution...like how do i fix the solenoid issue?"
SOURCE: we have error 3 ......
I have just had the same issue, error 3. Were you able to find a fix?
Posted on Dec 29, 2010
How can I fix my Frigidaire PLD4375RFC Dishwasher that leaks from bottom door even after new door gaskets 154576501 and 154701001.
It sounds like you are fixing the wrong area. If water is coming down between the inner and outer door panel and following the wiring harness, the leak is inside the door. Either from the soap cup mounting or the rinse agent area which I think is the same unit on your model. There is a gasket behind that part. Also check the inner door if its plastic for any possible cracks.
Apr 22, 2015 | Frigidaire PLD4375RFC Dishwasher
Euroart dishwasher
Go to manufacturers website with complete model #. You should be able to find parts list there.
Nov 13, 2017 | Dishwashers
Manual for EUROART DS9800 dishwasher
Can someone tell me what E1 means in this dishwasher please?
Feb 19, 2012 | Dishwashers
We have error 3 ...... can we fix this? its a euroart DS9800
Aug 15, 2010 | Dishwashers
The refrigerator door side does not shut tightly. The gasket seems to be ok and we leveled the unit. Still not shutting tightly like the freezer side which seems to have a magnetic pull to assist close....
Check bottom hinge cam riser located on bottom hinge the pin that goes inside the door it's plastic it's a 2 piece part 1 part goes over hinge pin and the other goes inside door hole. They get worn and break. If you replace this make sure you get both parts until you do try adj. top door hing to get the door tighter.
May 22, 2010 | KitchenAid Superba Architect KSCS25INSS...
Hope this helps.
Regards
Ash
Nov 11, 2009 | Dishwashers
Trouble installing freezer track
Hi
Thanks for using FixYa. Please tell me if you want to replace the door gasket, or the Run screws back up against the metal holding strip snugly, not fully tight. Go to the bottom and do the bottom half. By doing the top half first and tightening, then doing the bottom half, you will minimize any warping of the door. If there is warping of the door, we have not yet fully tightened the screws. so you can realign the door easily and then tighten the screws. Check the alignment of the door and be sure the gasket is sealing properly before fully tightening the screws.
Also see these pictures for details--
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks Rylee
Sep 18, 2009 | Kenmore Refrigerators
My kenmore he2 plus washer door gasket is loose.
it goes on the groove in the gasket at the door , the side view of the gasket would be a V, it goes right in the middle. make sure the gasket is first snug on the metal frame groove. the spring is very tight, start at top then work down, use a flat screwdriver to pry it in at bottom. it may help to wet the gasket
Apr 27, 2009 | Kenmore HE2 Plus Front Load Washer
Bosch dishwasher door leaks
Hi have you adjusted the door striker on the top part of the dishwasher? This is the part that the main door latches onto and can be adjusted in or out!
Feb 11, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwashers Logo
35 people viewed this question
Top Dishwashers Experts
