Question about Briggs Garden
Need to know a model number on a briggs and stratton engine family ABSXS.3422HT SERIAL NUMBER 10 0113 YD 75696
  • 130 Answers
SOURCE: I need a diagram for the carburetor linkage on a
go to partstree.com and get a diagram for this.
hope this helps you.let me know.if you cant find it ill get you one ok.let me know
Posted on Jul 22, 2009
  • 57 Answers
SOURCE: Generator with Briggs & Stratton,no gas is getting in carburetor
The needle valve may be stuck which would not let gas into the carb. I don;t think rebuild kits are too expensive. Pull the carb and take it to a lawnmower repair shop and they should have the parts. Before that though pull the bowl and make sure it has gas in it. If no then remove the fuel line and make sure gas flows from it. If no then could be the fuel shutoff valve is not operating properly or junk in the gas tank is obstructing the line.
Posted on Jul 31, 2009
  • 138 Answers
SOURCE: Craftsman LT 1000 with Briggs and Stratton 20 OHV
lift your seat and look at the label that you got your model number from. to the right of the model number is the serial number. the first six digits of the serial number is the date your tractor was made - for example: serial no. 060802D002756 would make the unit made June 8, 2002
Posted on Aug 18, 2009
ROMOAS
  • 97 Answers
SOURCE: Genarac Briggs and Stratton Engine Family
http://www.partstree.com/parts/
hope this helps
Posted on Aug 30, 2010
hunter19_46m
  • 7482 Answers
SOURCE: Briggs & Stratton Model 92502 3.5 HP Engine with
Hi hjconn...
Sounds like you have dirt/debris in your carburetor jets,fuel passages or a diaphgram that is becoming non-flexible.
NOTE: Before you dissemble the carburetor:
Make sure you mark each piece with a awl, or some kind of instrument that will make an alignment scratch before you dissemble the carburetor into separate pieces.
That way you will know which way it goes back together when you reassemble it.
Be sure to check your fuel tank for water and dirt/debris, if there is water/debris then you need to clean your tank.
Also check you fuel line condition after a while they will degrade and need replacment.
Make sure you are getting spark at the spark plug, to do this:
Remove your spark plug and check to be sure you are getting fire at the spark plug.
You do this by grounding the plug on the head of the engine and pulling the crank rope, if you are getting spark then:
Check/Clean/Replace your fuel filter if you have one, normally they are located in the fuel tank of weedeaters.
When you remove your fuel lines from the carburetor be sure to make a drawing to how the lines are connected to the carburetor.
Normally the big line will be the line the fuel filter is connected to inside of the tank.The smaller of the two lines is the return to the fuel tank from the carburetor after it is pumped thru the carburetor by the primer bulb.
Also make sure you are using fresh fuel...and oil mix if your using a two cycle mower or weedeater with the oil to the right mixture and not too much oil as it can cause hard starting.
If the mower/weedeater is over a couple of years old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
Sounds like you will need to clean the carburetor or replace your carburetor internal rubber parts like the diaphgram and O rings.
I recommend that you use a laquer thinner type cleaner to clean and dissolve the laquer build-up in the float and needle jet passages.
Be sure to remove all plastic and rubber parts before using the laquer thinner because it can dissolve the plastic parts and render them unuseable.
Be sure to use compressed air to blow out all the fuel and air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Sometimes you can get by with priming the carburetor or using starting fluid and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Keep in mind that the float (if you have one) for the carburetor must be level when you go to reassemble the carburetor or follow the instructions you get with the carburetor kit.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their original position before you started.
Once you have your carburetor rebuilt that should solve your problem.
This is a FREE answer,Please take time to rate me
Posted on Jun 25, 2011
Briggs and Stratton 17 HP Riding Mower
Hi Lawrence.
There should be a few more numbers/ letters to your model number. I added a link to a website for you to check out. Click the link or copy and paste it. Hope this helps.
https://www.repairclinic.com/Shop-For-Parts/a22b303d782009/Model-42A7072653E1-Briggs-Stratton-Small-Engine-Parts
May 30, 2017 | Briggs & Stratton Garden
I have a Briggs and Stratton/Bolens 20" lawn mower which needs a primer button. Where can I get that part(s)? Thanks
It looks like the number you are giving are from the mower deck, and would work great for anything but the engine. On a flat head engine above the spark plug on the tin air shroud there will be some more number and they go to the Briggs and stratton engine you have.On a overhead valve engine you should look on the valve cover. There will be model, serial , and spec numbers, all three would be great and would make it easy to look up the primer bulb and post a link to it for you.
Mar 25, 2016 | Garden
Hi, I have just been given a rotavator with a briggs and Stratton engine, don't no anything about it, how old, how to start it, it has pull cord but nothing?? model number is 140202, serial is 37634 and...
Look at the: Model, Type and Code numbers. The first two numbers of the code should be the year the engine was made. What problems are you having?
Jul 30, 2013 | Briggs & Stratton Garden
I have just aquired a Briggs and Stratton 450 series self propelled mower but need an owners manual.
The Briggs and Stratton 450 series is the engine (4.5 Hp). Is there a model number on the mower deck anywhere? I can probably find you a manual but need that model number. Unless you just want an engine manual.
Murray makes a 20 inch MX450 that has the Briggs and Stratton 450 engine on it but there are numerous makes and models (self propelled) that use this engine.
MX450 parts manual is here:
http://bsintek.basco.com/BriggsDocumentDisplay/default.aspx?filename=lminvFXBnfBhU7y
If you can come up with a good model number I will search avidly for a manual.
Thanks for choosing FixYa,
Kelly
Jun 09, 2011 | Garden
I have a murray lawn mower powered by briggs and stratton, i'm trying to fing a manual on the internet but it says to put my model number, and on my engine it says that my model number is lev100 but...
The model numbers on a briggs engine are stamped into the metal cover above the spark plug and are the first 6 digits the rest are engine codes and type.
Oct 29, 2009 | Briggs Stratton 020273 Elite Series...
Craftsman LT 1000 with Briggs and Stratton 20 OHV V-Twin Engine 42 inch cut model number 917271910 What year model tractor do I have?
Aug 16, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Garden Logo
66 people viewed this question
Top Briggs Garden Experts
Mike
Renee Knafel-Bullock
Are you a Briggs Garden Expert? Answer questions, earn points and help others
