Question about Coffee Makers & Espresso Machines
I need 2 drip trays for the large units - Coffee Makers & Espresso Machines
5 Suggested Answers
  • 27 Answers
SOURCE: Water leaks into storage bin
open the machine control panel side and cube adjustable thermostat available in side,adjusted in the thermostat screw
Posted on Jun 24, 2008
mirran
  • 515 Answers
SOURCE: Water hissing at back of brew unit after coffee made
I think you have to replace the steam valve.
Have you descale your machine regulary?
How old is your machine?
Maybe your boiler have to be replaced:-(
Posted on Jul 26, 2008
  • 78 Answers
SOURCE: LOVE the product, but the unit is leaking water
HWRHRJHJGHUIOYW
Posted on Mar 08, 2010
danowilliams
  • 104 Answers
SOURCE: Water dripping from unit need
It sounds like you have a central a/c that has part of the system, the compressor, condenser coil and fan outside on the ground, and the rest inside. The inside part, the evap coil, normally uses the same circulating fan as the heater. If this is the case, then locate your heater access and you should find the evap coil and its drip pan in the duct work.
Posted on Jul 13, 2011
Why is my Kuerig B60 coffee maker not filling the correct amount of water. ie. a cup instead of a mug or 2 instead of 3rd level?
Your b60 may need to be descaled. There might be scale built up on the water level probes in you machine. I have listed the directions below:
Brewer De-Scaling Instructions
Brewer Model: Elite B40 ' Classic B44
Special Edition B60 ' Platinum B70
To begin, you will need the following:
• 48 ounces of undiluted white vinegar
• Large ceramic mug (do not use a paper cup)
• Access to an empty sink
PREPARE
Step 1:
Empty the water in the Water Reservoir.
Step 2:
Disable "Auto Off features."
FILL AND CLEAN
Step 1:
Pour approximately 48 ounces of the vinegar
into the Water Reservoir.
Step 2:
Place a large mug on the Drip Tray Plate and run a brew cycle.
DO NOT USE A K-CUP
, just press the BREW Button. Pour the contents of
the large mug into the sink.
Step 3:
Repeat the brew process without a K-Cup until"ADD WATER"
is indicated.
Step 4:
Now let the Brewer stand for at least 4 hours while still on.
Step 5:
Discard any residual vinegar and rinse the
Water Reservoir thoroughly.
RINSE
Step 1:
Ensure the Water Reservoir is filled with fresh water.
Step 2:
water brew cycle. Pour the contents of the
Step 3:
Repeat brew process until "ADD WATER is indicated.
Step 4:
You may need to perform additional water brew
cycles if you notice any residual taste.
NOTE:
If "DE-SCALE" is still displayed after
completing the procedure, repeat the
descaling procedure above.
Apr 14, 2013 | Coffee Makers & Espresso Machines
Keurig b60 won't dispense water
PREPARE
Step 1:
Step 2:
FILL AND CLEAN
Step 1:
Step 2:
DO NOT USE A K-CUP
Step 3:
is indicated.
Step 4:
Step 5:
RINSE
Step 1:
Step 2:
Step 3:
Step 4:
NOTE:
Dec 14, 2012 | Keurig B60 Coffee Maker
Cva 4070 drip tray issue
Miele CVA 4066 -Empty drip tray warning would not go off even after draining the drip tray, cleaning contacts, and resetting power. Water was coming out from under the empty tray.
I pulled unit out and removed sheet metal in rear around water inlet. when I attached water line and power cord & turned on power, I could see water dripping out of one of the 2 solonoids on the water inlet valve. $168.00 from Miele and no expensive service call.
May 27, 2012 | Miele CVA4070 Coffee Maker
I lost my manual. How do I de-scale? Does this not allow you to brew a cup until it has been de-scaled?
From http://www.keurig.com/customer-service/brewer-registration-and-support/~/media/Files/Keurig%20Brewer%20Manuals/De-scaling_instructions.ashx
PREPARE Step 1: Empty the water in the Water Reservoir. Step 2: Disable "Auto Off" features.
FILL AND CLEAN Step 1: Pour approximately 48 ounces of the vinegar into the Water Reservoir. Step 2: Place a large mug on the Drip Tray Plate and run a brew cycle. DO NOT USE A K-CUP, just press the BREW Button. Pour the contents of the large mug into the sink. Step 3: Repeat the brew process without a K-Cup until "ADD WATER" is indicated. Step 4: Now let the Brewer stand for at least 4 hours while still on. Step 5: Discard any residual vinegar and rinse the Water Reservoir thoroughly.
RINSE Step 1: Ensure the Water Reservoir is filled with fresh water. Step 2: Place a large mug on the Drip Tray Plate and water brew cycle. Pour the contents of the large mug into the sink. Step 3: Repeat brew process until "ADD WATER" is indicated. Step 4: You may need to perform additional water brew cycles if you notice any residual taste. NOTE: If "DE-SCALE" is still displayed after completing the procedure, repeat the de-scaling procedure above.
Mar 17, 2011 | Keurig Special Edition B60 Coffee Maker
I have a franke flair coffee machine when you switch it on it reads on the panel please wait and will not complete the switch on. Any help thanks
DESCALING The Saphira has an integrated descaling program. The procedure takes about 60 minutes. Once started, the descaling procedure may not be stopped. • When acid-containing descalers are used, immediately remove any splashes or drops on sensitive surfaces, particularly from natural stone and wood surfaces. Also, take the appropriate safety precautions. • Turn off the Saphira by pressing the "ON/OFF" button. • Press the button "Descale" until an acoustic signal is heard. • Display: EMPTY DRIP TRAY (Fig.1) • Display: INSERT AGENT IN TANK • Display: PRESS DECALCIFYING Dissolve 2 DESCALING tablets completely in 2.5 cups of water in a vessel and pour the mixture into the empty water tank. Place a sufficiently large container under the steam tube and the coffee delivery outlet. • Press the Descale button • Display: UNIT DECALCIFYING • Display: PLEASE WAIT • An acoustic signal is heard. • Display: EMPTY DRIP TRAY (Fig.1) • Display: FILL WATER TANK • Display: PRESS DECALCIFYING • Press the Descale button • Display: UNIT DECALCIFYING • Display: PLEASE WAIT • An acoustic signal is heard. • Display: EMPTY DRIP TRAY • Display: CLEAN CONTACTS
Good Luck Mikey@espressomachineexperts.com
Dec 22, 2010 | Franke Saphira Espresso & Coffee Maker
I have a George Forman GRP46R. I'm having a drip tray problem where the grease is going under the unit and then dripping from the bottom. Some of it goes in the tray but the majority of it goes under the...
Since I accidentally left my drip pan inside the unit and preheated the unit without checking, I am now without a drip pan. The unit really heats up fast and likes to melt plastic. Anyhow, I used a cookie sheet underneath that has a lip around it to catch the drippings. I would suggest that you place your whole unit on a cookie tray so no matter where the grease runs out it will go on the cookie sheet and not your counter.
Oct 14, 2008 | George Foreman GRP4P Indoor Grill
Jul 25, 2008 | Saeco Incanto Classic Espresso Machine
Saeco Espresso machine - Empty drip tray (all the time)
aye that is true if you click the coffe making button directly after you have had it out you will be able to make a cup, as the machine has a 2 second response time.
Ok here is what i think:
As it registers the driptray I dont think its the sensor to it.
More i would think that its the CPU card that is not responding to that its clean.
I am sry but I have to ask this:
When it says emptie the driptray are you actually taking out the container that is located under the brewing unit, and not the "drip tray" were you put the coffe mugs?
Also when i think i have a sensor problem I allways take out everything. Brewing unit, dripwater container, dregbox, and the watercontainer. and have it out for atleast 2 minutes ( clean it under the mean time) and put it back again.
As I dont have the machine infront of me i cant be certain:)
Jul 11, 2008 | Saeco Talea Ring Plus Espresso Maker with...
Jun 22, 2008 | U-Line Icemaker
Coffee Makers & Espresso Machines Logo
23 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
