Question about Sony Ericsson W380i Cellular Phone
Ringing/text/walkman Sound All of a sudden the volume has gone on my Sony Ericsson w380i. Its a year old. I miss calls now because I can't hear it, neither can I hear when texts arrive. Sometimes the sound works but mostly now it doesnt!
Hi it not ringing and cannot hear music from it
Water might have entered into the speaker.
Aug 11, 2012 | Sony Ericsson Xperia Arc S
Sony_ericsson_w380i_cellular_phone walkman not working.i am not getting sound or is very slow when i start my ericsson's walkman. Does it require any s/w update?
ur problem is related to hardware
just check the following
  • check the volume is in high level
  • check sounds through earphone
  • if the above works there is a problem with ur loudspeaker or sound engine
  • if ur mobile is new claim it
  • or it can solved by servicing
May 18, 2010 | Sony Ericsson W380i Cellular Phone
Sound problems with the W380i sony ericsson
my sony Ericsson T303 is asking me for puk code,how do i go about getting it,thanks.
Dec 25, 2009 | Sony Ericsson W380i Cellular Phone
Sony ericsson w380i
the ringtone yu are using of that file format would be different use the another format
Sep 14, 2009 | Sony Ericsson W380i Cellular Phone
Extremely low sound
had the same problem the hinge used in this model is causing this it get worn out quickly ,i had to replace it thrice within nine months......even pcb was replaced.now having problem with sys port ,i
Jul 13, 2009 | Sony Ericsson W380i Cellular Phone
How to increase ringing volume and hearing volume
When you are receiving a call use the up/down or left/right rocker (the squarish thingy around the circular button in the middle) to increase/decrease the volume. This also works for the speaker volume if you have the speaker on.
HTH
JB
Jun 27, 2009 | Sony Ericsson T303 Mobile Phone (Shadow...
Can't get speaker volume or audible ringtone
sir
dismantle your phone and clean the contacts of the speaker and buzzer or replace them... it will solve your problem
Feb 04, 2009 | Sony Ericsson W380i Cellular Phone
W890i wont ring, or play text alerts.
I cant hear it ringing while incoming call from any caller it just vibrate only.Any Idea how to solve this problem.my phone has the latest update from SEUS.
Nov 16, 2008 | Sony Ericsson W890i Cellular Phone
W880i not ringing or message alert
Ok, Might seem like a daft question but is it on silent?
I'm guessing you chekced this already but it's easy to miss.
The first thing to check is whether it will make any sound at all - this is a good guide as to whether the speaker is broke or just settings are wrong. Being a Walkman phone you might have some tunes on it so see if they play. Do this through the walkman/media player feature as apposed to the ringtone area.
If they play then you know it's still working and some settings need changing. If not your speaker might be broken.
If the speaker works then you need to check the ringer volume. this can be done from MENU/SETTINGS/SOUNDS&ALERTS/RING VOLUME - this then needs to be set using left and right to go up and down.
After this is set test call the handset to see. If still no luck change the ringtone to another tone - something built into the handset preferably - might be a faulty tune. If still no luck check the the number calling the handset has not got any sound preferences - i.e. no tune when call received. If still no luck it might be broke...
hope this helps some what...
Mar 15, 2008 | Sony Ericsson Walkman® W880i Cellular...
Mt phone wont work
u have a volume buton on the side try that
Aug 25, 2007 | Sony Ericsson Walkman W810i Cellular Phone
Sony Ericsson W380i Cellular Phone Logo
152 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
