Question about Bosch Coffee Makers & Espresso Machines
My pods won't puncher a hold in and let the coffee out it is Bosch tassamo
3 Suggested Answers
  • 30 Answers
SOURCE: my pod won't hold a charge!
Try plugging it into a wall charger, and make sure you are using a genuine apple cable and wall plug.
Posted on Jul 30, 2011
  • 78010 Answers
SOURCE: Can I replace the small black cup that holds Keurig coffee pods in my Mr. Coffee single serving coffee maker
You would need to contact KEURIG with that question
Posted on Dec 04, 2016
Bosch tassimo coffee maker What is the yellow disc for where you place the coffee pod? Also what is the digital piece on the lid for? If for size of coffee cup fill , how do you adjust it?????
Hi The yellow disk is used when cleaning the coffee machine and the size for cups is usually on the tassimo pack at the back.
The "digital piece" is a bar code for the discs.Hope that helps? ps,
Go to Tassimo site for info
Feb 05, 2017 | Bosch Coffee Makers & Espresso Machines
The lid won't open to get the used coffee pod out. It seems to be stuck.
Customer questions and answers for Bosch TASSIMO T10
The TASSIMO T10 Single Cup Brewing System by Bosch brings the artistry ... the machine made some funny noises and now I cant open the lid to remove pod. ... When I went to remove the T-disc, the tassimo won't open so I cannot get it out.Missing: tas5542gb
Bosch Tassimo TAS4511UC Coffee Maker Open ... - Fixya > ... > Bosch Tassimo TAS4511UC Coffee Maker
Question about Bosch TASSIMO Coffee Makers & Espresso Machines ... colors, openthe lid, put disc with the cream in the machine and the green light won't come on, only the . ... Bosch Tassimo Tas5542gb Multi Hot Drinks Machine, Black.
Why has my Tassimo brewer stopped working?
QUESTION: I have a problem with my Bosch Tassimo brewer. ... Now when I close the machine, I open it and remove that litte tin foil circle. ... Opened my new Tassimobrewer and won't brew and water dispenser leaking all over... an ... I have a problem with my tassimo coffee maker the lid wont lift up seems stuck any ideas ...Missing: tas5542gb
Jan 19, 2016 | Bosch Tassimo Tas5542gb Multi Hot Drinks...
When pod is put into machine green light doesn't always come on therefor no coffee & a wasted pod
I know, don't you hate when that happens? Did you check to see that the needle port where the hot water exits from is free of debris? If plugged, no water can escape, thus I suggest using a pin or small paper clip end and stick it up the tube to free it up. See if that helps.
Feb 03, 2015 | Bosch TASSIMO Coffee Makers & Espresso...
When i put new pod in the plus service comes on
I had a similar problem , no amount of flushing descaling worked , had to buy a new one.
Jul 05, 2012 | Bosch Tassimo TAS4511UC Coffee Maker
Water won't heat up in my bosch tassimo coffee maker, what do I do?
I unfortunately got my vivy emesred in water. When I switch it on it stars brewing cold water splashing all over the place and does not stop!
Any idea how I can salvage the machine?
Oct 22, 2011 | Bosch Tassimo TAS4511UC Coffee Maker
My Lavazza Blue coffee machine does not press enough to punch the holes. The coffee comes out water. What should I do.
After 1700 shots it is recommended that both upper and lower punchers as well as all seals in the brew unit be replaced. These punchers are only plastic so they do get worn down after much use. You may also be experiencing more water in your drawer as water is leaking from around the capsule seal. This is also an indication that the seals and punchers should be replaced. Given where you go to have this fixed, the parts may cost less than $15.00.
Jul 08, 2011 | Lavazza 2210
Coffee Makers & Espresso Machines Logo
Top Bosch Coffee Makers & Espresso Machines Experts
Tre Elkins
Oloyede Monsuru
ray gallant
Are you a Bosch Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
