Who to make a proget for school about volcanos
How was mauna loa formed
OK, the whole Hawaiian Island chain is volcanic, formed from volcanoes which rose in turn from the ocean floor, erupted, formed an island around, then became less and less active in turn as the whole island chain moves away to the NW at 2 - 4 in per year.
Mauna Loa is one of 5 volcanoes which have formed the main island Hawaii. It is still active, and is a wide flattish volcano 4169 metres above sea level (13 679 ft).
It probably started erupting under the sea about 700 000 yrs ago, and rose above the surface about 400 000 yrs ago. It is a young volcano in geological terms as the oldest rocks found on its surface are 200 000 yrs old.
There is heaps more info here, but take care as some teachers do not like you to quote Wikipedia as a reference.
Sep 19, 2014 | The Learning Company ClueFinders 5th Grade...
How do volcano work and explode?
The purpose of the project is for your group to do the research, sift through the documents, select material, write and rewrite. All we can help you with is to give you some links you could explore.
Volcano Wikipedia the free encyclopedia
Volcanoes 101
Annenberg Learner Interactives Volcanoes Introduction
Sep 12, 2014 | The Learning Company ClueFinders 5th Grade...
Are there any other volcanoes by mount pelee?
If you follow the link pasted below it will take you to the Wiki page for Mt. Pelee. If you read the first paragraph at the top it tells about the other Volcanoes in the chain.
Mar 21, 2014 | Google Computers & Internet
How a volcanoes is formed?
volcanoes are formed by tectonic plate friction. Asplate rub against each other, they form cracks, gaps, and voids, that can fill with the magma in the earth's mantle. AThis magma is under extremely high pressure, and any crack or gap that it can find, it will use. As a volcano forms above the surface, there will be a ***** or cone that forms above the volcano, and as presure builds underneath, the volcano grows, sometimes to very high altitudes, before it ever eruprts. Sometimes, it will die out, losing it's pressure, and go dormant. Ther is NO SUCH THING as a DEAD vocalno, they just are dormant for longer periods of time. Some of the volcanoes here on earth have erupted alot, others have only erupted sporadically, but If it eprupts even once, then eventually it will erupt again.
Jan 04, 2011 | Computers & Internet
Driver for web cam model volcano ic100
iam using volcano ic 100 from where i can get complete driver
May 30, 2009 | QPS QSIPBL2 Network Camera
I have a toshiba 50inch rear progetion tv. I was
There is one mirror inside. It is easy to remove the front plastic screen by removing the bottom fabric grill (snaps off by pulling outward like a removable speaker grill). Remove several wood screws along bottom edge of screen. Lift up the whole plastic screen frame and pull it away from the TV; but be careful with the control wires that go to the center panel, which snaps off the big screen frame easily. The mirror is right there.
Apr 01, 2009 | Toshiba TP50G60 50" Rear Projection...
Driver is located here:
Jun 17, 2008 | Computers & Internet
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
