Question about Danby DPAC8020 Air Conditioner
The air onditioner leaks water, can't remember if
I know this sounds lame but my air onditioner leaks water, can't remember if I needed to empty something or is it a hose? I have lost my manual, help! It is an Everstar Portable Air Conditioner mpm-10cr-bb6
  • 25 Answers
Mine is a different brand, but it has a "bucket" in the back I have to empty every day.
Posted on Jul 24, 2009
Water condensate tanks keep filling up. Never needed to empty them before with many years of use.
Rick, check the hoses are not clogged or plugged. There is probably a small pump which may have quit and will need replaced. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Air conditioner leaking in your basement Condensate pump Reliable Heating...
How to repair check Condesate Pump Little Gaint VCMA 15UL
How To Unclog Condensate Pump Tube
Jun 04, 2016 | Heating & Cooling
Tip
Cabin heater not working or not working good enough in BMW 3 series.
A common problem in the BMW 3 series of the 99 - 2002 year is that when there is a leak in the cooling system for what ever reason ( perished hoses leak in the 3 series a lot along with expansions bottles, radiators ) air leaks in as tiny amounts of water leave through the leak.
This air rises to the highest point in the cooling system which is the internal cabin heater matrix radiator in the 3 series models of the pre-said years.
As it fills with air over time the water pump can no longer circulate the coolant ( A pump designed for liquid will not move air only liquid ) leaving the internal cabin heater matrix radiator empty ,the coolant now takes the alternative route hence no heat.
A temporary solution is to put in more water or coolant remembering to ;
1 Loosen the air bleed screw or remove it when doing so.
2 Do it while the engine is running and cold and the pump is rotating.
3 Make sure the heating in the car is on full tempeture so as to allow the water to flow up and into the internal radiator.
4 Leave the bleed screw open for five minutes so to be sure all the air has purged.
After that tighten it and replace the filler cap and you should be good to go. if it does not fix the problem bring it to a garage to have the system pressure checked for leaks. they may also do a sniffer test to see if there is any combustion gases in there that should not be, this may indicate major machanical failure of the engine block head gasket or more common in the 2000 318 's is a cracked engine block head which needs total replacement.
So remember! practice and enjoy :)
on Sep 14, 2010 | BMW 318 Cars & Trucks
Scotsman prodigy leaking water
How to work on Scotsman Prodigy Ice Machine
Jan 16, 2014 | Scotsman Kitchen Appliances - Others
Mr. Slim is dripping from movable doors.
Try to get at the drain hose from outside. It sounds gross but try to blow some air int the drain hose. Do not blow to hard but hard enough to tell if the hose is clogged or not. If the hose is not plugged hou may have to tear into the unit a bit. The drain hose is either on the left or right hand side of the unit. You should be able to take out the filters in the unit to see down in the drain pan. It is under the coil and you should be able to see water in it. It may be better to have a technician come over and tear into the unit to get the drain pan out and cleaned. Sometimes if water gets trapped in the drain pan it will slime up and cause it not to drain properly. They do sell a tablet that you can use in the drain pan to treat the water to keep it from sliming up and getting moldy. We sell the bottle of 100 tablets for around 25 dollars. Your local HVAC Wholesaler or contractor should have these on hand. Let me know how it goes.
Jun 06, 2010 | Mitsubishi MS-A12WA Air Conditioner
After one year of working well it now leaks
check the base of the unit for cracks or holes...you might need a sealant to seal the leak
Aug 11, 2009 | Heating & Cooling
This is soooo lame but I cant remember how to put the correction tape in.... :~)
As you face the machine, the full spool goes on the left side of the printwheel carriage and the takeup (empty) spool goes on the right. Be sure that the shiny side of the lift off tape faces AWAY for the paper. The matte side is what does the lifting.
Hope this helps.
Apr 17, 2009 | Brother Office Equipment & Supplies
Ice in the unit
Welcome to fixya.
I'm Huuum and happy to assist you,
You said, Left house for a while with unit running and when I returned little or no air was emmiited from unit, and when I removed back cover, solid sheet of ice!
Sounds like you have a coolant leak or the thermostat is malfunctioning.
You need to have the freon checked first to see it is not low.
This one reason that will make it freeze up .
let me know how much freon it took.
Please remember to leave a rating before you go!
Thank you
Sep 29, 2008 | DeLonghi Pinguino PACL90 Portable Air...
COPIER
its self adding toner, besure your cartridge is not empty, take it out and shake it side to side. youll feel if its got toner, Remember kids, when you shake up toner, it gathers air and will leak or pour just like water. you may have to turn off & on so it completes its stir cycle a couple times. By they way, i,m not an apprentice or rookie. long time service co owner.
Dec 07, 2007 | Kyocera CS-2050 Black and White Copier
Leaking water
You AC should drip water from the rear this is normal it should be tilted to the rear. I don't know about the odd sound..what does it sound like? let me know
Aug 23, 2007 | Kenmore 75050 Wall/Window Air Conditioner
Danby DPAC8020 Air Conditioner Logo
622 people viewed this question
Top Danby Heating & Cooling Experts
coolfelix
Level 1 Expert
Dan Webster
Dan Webster
Dennis Boxerman
Are you a Danby Heating and Cooling Expert? Answer questions, earn points and help others
