Question about Sewing Machines
Bobbin threading - Sewing Machines
  • Sewing Machines Master
  • 11,769 Answers
Consult your owner's manual
or
Search for:
Make Model manual
or
Make Model threading
Posted on Apr 25, 2017
How to wind a bobbin for a 250 electronic Viking Husqvarna machine
Make sure that the presser foot is raised if you are winding a bobbin with the top thread threaded through the needle. Place the bobbin on the spool spindle with the mark (a stylized H) outwards. Bring the bobbin spindle down. Next pull the thread from the needle under the presser foot to the thread guide on the right. Bring the thread above the bobbin and wrap the thread around the bobbin several times. Cut off the excess thread on the thread knife and step on the foot control to wind the bobbin. When the bobbin winding is finished, remove the bobbin from the spindle. Cut the thread to separate the bobbin thread from the needle thread. Move the bobbin spindle up.
Sewingpartsonline.com has a link to the manual for the Husqvarna Viking 250 on the machine specific parts page (under Manuals), http://www.sewingpartsonline.com/viking-250-sewing-machine-parts.aspx . The direct link to the manual is http://manuals.husqvarnaviking.com/VSM/Husqvarna%20Viking/HVManual.nsf/5bc6115484660075c12575d2003f80e3/ecf97dd171581582852575ed00755e7a/$FILE/Viking%20210,%20230,%20250%20%20x.PDF . The bobbin winding steps are on page 12. There is also a method for winding a bobbin with a different thread from the top thread. See the manual.
I hope this helps.
May 28, 2017 | Husqvarna Sewing Machines
My bobbin thread breaks too much. How do I fix it.
Be sure you are using the correct bobbin for your machine. Even though it appears to fit the bobbin case, if it is the wrong bobbin, it could cause major headaches.
Try a different bobbin. Try different thread.
Also check that the bobbin thread is wound smoothly and turning the correct direction in the bobbin case. Make sure the thread is threaded through the bobbin tension properly.
AVOID old and inexpensive, bargain bin thread!
There could be a nick or burr somewhere that is catching the bobbin thread and breaking it.
Try loosening the bobbin tension a bit. It could be too tight, especially if the bobbin thread is pulling the upper thread down to the underside of the fabric.
There could also be something wrong with the bobbin case itself that may be resolved by trying a new bobbin case (or borrow one from a friend, etc.)
Dealing with Lower Thread Breaking Sewing
Bobbin Thread Breaking How to Loosen Bobbin Tension
Nov 10, 2016 | Sewing Machines
Bobbin not working.
The symptoms sound like it could be the incorrect bobbin. Even if it is tiny bit different, it may not work properly. If it is not an authentic bobbin for your machine, but rather a clone from another source, it may not be suitable. Some machines are very finicky.
If it is in fact the correct bobbin, then there may be a problem with how the thread is wound on the bobbin or how the bobbin has been inserted and threaded in the bobbin case. Be sure the thread is wound very smoothly on the bobbin and that the thread does not extend beyond the outer edge of the bobbin or that no loose threads are poking out from the bobbin. Also verify that it is inserted (and turns the right direction) in the bobbin case and that the bobbin case is threaded properly.
Feb 24, 2016 | Sewing Machines
Thread a bobbin on a 5825c
If you mean the Singer 5285C, the manual is available from Singer here: http://www.singerco.com/uploads/download/449_5_6_8_10_slide.pdf . The diagram for winding the bobbin is on page 14 and inserting the bobbin is on page 15.
I'll attempt to walk through the steps. Push in on the indent on the hand wheel to lock the needle in the current position (note rotate the needle up first). Then with a spool on the spool pin and the cap securely holding the spool on the pin, snap the thread through the thread guide post (near the center back of the top of the machine). Then wind the thread clockwise through the bobbin tension guide (towards the center front of the top of the machine). Next run the thread through the hole in the bobbin (inside to outside). Place the bobbin on the bobbin spindle on the front of the machine near the right hand side of the machine. Hold onto the thread end at the bobbin and start pushing down of the foot controller. Fill the bobbin to the amount of thread that you need, or until it stops. Cut the thread going from the spool to the bobbin.. Remove the bobbin from the spindle and trim the thread end that is sticking through the hole in the bobbin. Press the hand wheel disc on the side opposite from the indent.
Inserting the bobbin requires you to lift the presser foot and have the needle in the highest position. Slide open the face plate and remove the empty or wrong color bobbin. With the hole in the bobbin up, pull about 4" of thread off the bobbin. Place the bobbin in the bobbin case and hold it down lightly with a finger. Guide the thread through the notch near the front of the bobbin case. Then lead the thread down into the slot on the left and then around the second notch. The thread should be heading towards the center of the bobbin (left to right). Pull the thread diagonally back to the back of the machine and slide the bobbin cover closed. The thread should be coming up through the opening between the cover and the needle faceplate. To pull up the bobbin thread, thread the needle and then hold onto this top thread. Rotate the hand-wheel towards you until the needle rises above the needle plate. Gently tug on the top thread to bring up the loop of thread. Separate the needle thread from the bobbin thread with your fingers. Bring the top thread through the left side opening in the presser foot and then pull both threads to the back of the machine.
I hope this helps.
May 24, 2013 | Sewing Machines
I have a faithful 730 Bernina and currently the bobbin thread keeps breaking. Please advise what may be causing this. Thanking you.
Bobbin thread breaks
1. There is a right way & wrong way to insert the bobbin in the case --when you insert the bobbin in if it doesn't stitch correctly turn the bobbin over see if that helps or bobbin case is not inserted correctly
2. Lint has collected in the bobbin holder
3. The bobbin is damaged & doesn't turn smoothly
4. Lower thread tension is two tight
here's a free manual
http://www.bernina.com/getdoc/48e8d09f-98f7-40ab-8663-a23663df4fae/Bernette_715_730_740E_manual
Sep 17, 2012 | Bernina Sewing Machines
The upper thread is too loose and the bobbin thread is taken up too much
It is the upper thread which pulls the bobbin thread up. If the bobbin thread is taken up to much, one solution is to loosen the upper thread -- but the upper thread is too loose. Therefore, the same problem needs to be combated from the bobbin side.
The thread from the bobbin should slide through a wedge. On that wedge should be a screw. It needs tightened. The bobbin thread should be tight as follows:
A fully loaded bobbin should tangle by the thread without falling. While dangling the bobbin by the thread, bounce the bobbin (yo-yo style). An easy tug should cause the bobbin to release an inch or two of thread and then the bobbin should stop falling on its own.
Once the bobbin tensioner is correct, you should be able to tighten the upper tensioner.
Jun 02, 2011 | Singer 5050 Mechanical Sewing Machine
I own a "Lena" machine
Hello
Make sure your feeddogs are up. That is the little jagged looking plate under the pressure foot. There should be a setting on your machine that will move it up and down.
If they are up then the bobbin is not in correctly. If it is a normal round bobbin that fits in a bobbin case, hold the bobbin in front of you so that the thread end is on top and the thread is going away from you, and slide it into the bobbin case. Feed the thread through the right openings in the bobbin case. When you pull the thread end the bobbin should turn clockwise.
Never hand-wind bobbins. Instead, use the accompanying bobbin winder which is attached to most machines,bobbin casings must be oiled regularly to prevent problems with the bobbin turning properly. The bobbin, when inserted properly into the bobbin casing, should spin counter-clockwise when thread is pulled.
Check the way your machine is threaded. Completely un-thread your sewing machine and re-thread it. Remember to always thread your machine with the presser foot up.
Check the bobbin and be sure the bobbin is threaded correctly and that the bobbin case is correctly threaded. Be sure the bobbin is in the bobbin case in the correct direction.
Always watch for bobbin wear, especially on the plastic type of bobbins. If the edges of the plastic are showing abrasions, the size of the bobbin has changed and may be the culprit. Although the size change is minute, it allows the bobbin to wobble in the case and changes the tension.
Dec 19, 2010 | Husqvarna Sewing Machines
How do you load the bobbin properly?
Well you may please follow the steps below -
1. Remove the bobbin from the sewing machine. Note: whether you have a drop-in, front or side-loading bobbin on your sewing machine. A drop in bobbin will load from the top, may be via a removable bobbin case cover near the machine-fed dogs. A side or front loading bobbin needs to be loaded into a removable bobbin case under the machine.
2. Choose the right size bobbin for the sewing machine.
3. Wind thread onto your bobbin. Your sewing machine should have a standard thread spool to hold the thread and a short, squat post wide enough for a bobbin.
4. Put the thread and empty bobbin into position on your sewing machine. Wrap the thread around the bobbin to start it. On most machines, disengage the needle by turning the smaller hand-wheel on the machine toward you. Push the bobbin post into position, securing the bobbin into place. Press gently down. Thread should begin to wind neatly onto your bobbin.
5. Break the thread, push the bobbin post back into an inactive position and remove the bobbin. Tighten the hand-wheel. Thread your sewing machine again if necessary before loading the bobbin.
6. Remove the bobbin case cover and put the bobbin into position. The thread should slide through a catch on the bobbin case and up through the cover.
7. Access the bobbin case for a front or side mount bobbin. Lift the catch and remove the removable bobbin holder. Put the bobbin into the holder and run the thread through the holder, bringing it to the front. Lift the catch and slide the bobbin holder back into the case. Hold your needle thread gently forward with your left hand and turn the hand-wheel. The needle thread will pass down into the machine and catch a loop of the bobbin thread. Pull this loop up and slide both threads to the back before beginning to sew.
Good Luck!!
Thanks for using FixYa!!
Sep 22, 2010 | Euro-Pro Shark 60 - 384
How to thread the bobbin on a singer simple sewing machine
Drop-in bobbin: Note: thread must change direction when entering bobbin shuttle notch. Usually bobbin will turn counter-clockwise when threaded properly.
1. hold bobbin so that the tail of thread is facing to left.
2. drop bobbin into bobbin shuttle.
3. pull thread toward you.
4. guide thread into notch and pull to left so that slot engages thread.
5. pull thread diagonally across shuttle toward back of machine.
6. draw bobbin thread up through needle plate with threaded needle.
Oct 31, 2009 | Singer 3116 Simple
Machine is threaded but thread not sewing into material, just holes!
Check bobbin thread....Insert the bobbin thread into the bobbin case in a clockwise direction...pull the thread through the **** on side of bobbin case and slide up into small opening...make sure you pull through about 2 inches of thread to enable upper thread to loop. Good Luck
May 10, 2009 | Sewing Machines
Sewing Machines Logo
21 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
