Question about Briggs Garden
3.5 Briggs ,new coil ,ground wire unhooked,no spark
    Habit-Forming:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 35 Answers
Re loosen the magneto place business card between mag. And flywheel retighten mag mounting screws remove business card shine up flywheel with sand paper with the mag off the motor clean rust off flywheel before remounting mag with business card.
Posted on Apr 25, 2017
My lawnboy silver series is not getting any spark
If you are getting no fire it is going to either be your coil is grounding out through the kill wire somewhere or your coil has gone bad. Try unhooking your kill / ground wire directly from the coil then check for fire. If you still have no fire then you will need to replace the coil. Hope this helps.
Aug 26, 2014 | Briggs & Stratton LawnBoy 20Inch 65 HP Gas...
Why don't I get spark on my briggs and stratton 3.75 model 98902
Did you check the ignition shutoff wire? Make sure it isn't grounding. It is a common Briggs problem. Take the wire off of the switch contact and check for spark again.
Aug 19, 2014 | Garden
Were is low oil sensor 13-hp.briggs
check gap on coil the gap on the points and also make sure the magnets are free of rust, the capacitor could be weak also.
Jun 11, 2014 | Briggs & Stratton Ignition Kit 2-8 HP...
What year did briggs come out with the low oil safety?
bad ignition, it is probably grounding internally.....
Apr 13, 2013 | Briggs & Stratton Garden
8hp briggs no spark
There has to be a ground on one side of the magneto coil. Make sure that wire is not the ground
Mar 23, 2013 | Hammering
Engine wont shut off
the wires going to the coils are shutoff wires you can run both to a switch and then a wire from the switch goes to ground when you flip switch it grounds the coils shutting off the motor
May 20, 2012 | Briggs & Stratton Briggs Stratton Intek V...
No spark-magnets ok on flywheel-new coil-good spark plug
unhook the wire that comes from coil to shut off switch and see if spark then
May 16, 2011 | Briggs & Stratton 190cc 875 Series OHV...
No spark and will not start
remove blower shroud off top of engine.Remove grass screen first.disconnect ignition kill wire from coils,retest for spark,if no spark check kill wire,wire that was disconnected from coils for short to ground.If wire checks ok,replace coils.Forty years in small engine repair.
Sep 17, 2010 | Briggs & Stratton Briggs Stratton Intek V...
8 hp briggs no spark,new coil ,new electronic
make sure the plug wireisn't grounding on sheet metal. Verify current to ignition module and that module is securely mounted for grounding. Negative side of coil to module, pos to ignition switch or starter button . Chk for current at coil +. . Coil -- should pulsate when cranking. Ensure there are no inline fuses, fuse box fuses, or fusible links incorporated into wires lesding to module. Good Luck_Ned_
Oct 31, 2009 | Briggs & Stratton Ignition Kit 2-8 HP...
Garden Logo
Top Briggs Garden Experts
Mike
Matt Olenzek
Matt Olenzek
Are you a Briggs Garden Expert? Answer questions, earn points and help others
