Question about Tools & Hardware - Others
How to open the Mastercraft Sure Shot Staple Gun 57-7943-0
  • 275 Answers
  • 2712 Answers
SOURCE: staple gun support
Know the types of staple guns available. They can be manual, electric, battery operated or run by compressed air with an air compressor. Some staple guns have guide wires because they’re used by electricians that can’t pierce wires. Others have long noses to work well in corners and tight spaces. There’s also a reverse built ergonomic staple gun called a "forward action" because the handle and the staple’s exit point are on the same end of the staple gun. Some staple guns can shoot brads instead of staples. Know how each type of staple gun works. This one is so simple because it works just like a stapler. You press and hold the silver latch on the back of the stapler to open the body. Take the tray out and fill it with staples. Then it’s ready to use. Just put the staple ejecting end on your piece to be stapled and squeeze it. There is also the forward action manual gun which is used by pushing the handle down, too. The handle is just located near the staple ejection site. Use an electric staple gun for effortless stapling. There’s no need to squeeze or apply any pressure on these guns. They come with a very short cord so you will always need to have an extension cord with your staple gun. You can also go with a rechargeable battery operated cordless staple gun. They are great but they do run out of steam so for long use one with a cord is better. They’re also pretty easy on the wallet these days, so there’s no reason to go without this in your home tool kit as it’s something that does a lot of jobs. Know the versatility of the staple gun. Whether you have a manual or an electric model, these are some of the most versatile tools out there. You can use them to recover furniture, to build a birdhouse, to staple lattice to a patio, to build lightweight projects like a small knick knack shelf and to do wiring work.
Posted on Aug 27, 2008
SOURCE: staple gun
Open the chamber and drop the staples upright in to the chamber do not try to load the staples by placing them on the strip that pulls out as you do with most staple guns.
Posted on Nov 25, 2008
  • 232 Answers
SOURCE: how to open arrow p22 staple gun
there is a spring follower in the base with a hook that latches into the body of the stapler. press in then down to unlatch the follower.
Posted on Oct 21, 2009
Testimonial: "yes thanks very much!"
  • 6 Answers
SOURCE: Where can I download a manual for Bostitch T5 Staple Gun
If you want to know how to load the staples, lift the wee flap at the end with the inscription " lift to insert staples".....
Posted on Feb 01, 2010
SOURCE: Stanley TR 250 Staple Gun Staple cartridge problem
very simple to fix it 1 pull the trigger all the way out 2 there is a little piece of metal, pull it all the way out (detach the piece out from the gun) an connect one side of the spring 3 push the piece back on the gun. 4 on the other side of the spring tide a little fishing line 5 pass the fishing line over a small rounded piece and pull it hard 6 finally connect the side of the spring onto a little hock on the base of the trigger
Posted on Apr 21, 2011
How to reload the easy shot stapler gun
While I am not familiar with your brand of gun, almost all of them load in a similar manner!!!!!
At the bottom REAR of the gun there is usually a couple of small tabs [connected together, but one on each side of the stapler body].
With my old Bosch T five tacker and my Swingline machine i push inward toward the front and simultaneously downward releasing th catch and then pull backward on the tab TO OPEN THE MAGAZINE CHAMBER>
Jan 09, 2015 | Tools & Hardware - Others
I have a staple gun and when I pushed the trigger the staple it metal so now it's bent in the gun and part of the way out. How do I get it out?
When this happens, you have to release spring pressure against the staple strip then invert the staple gun and BEING ABSOLUTELY SURE THAT THE STAPLE OPENING IS NOT POINTED TOWARD YOU use pliers or a similar tool to remove all of the damaged staple. Reinsert the staple strip, point the gun away from you and test operation.
Jun 05, 2014 | Tools & Hardware - Others
I have rebuilt my staple gun all new seals new piston and driver blade new bumper cushen when gun shoots the blade wont retract up all the way you have to open the staple mag. fire the gun then the blade...
Inside the cap, there's a plastic circular insert. It's a common mistake to reassemble the gun with this cap spacer upside down, resulting in the top of the cylinder not sealing in the air that returns the piston. Simply undo the cap, turn the spacer over and screw it back on again. Done.
Feb 27, 2011 | Fasco Tools & Hardware - Others
How do I refill a n Arrow heavy-duty staple gun?
Fixed the old-fashioned way. Went down to the hardware store and got the demonstration. Thanks.
Nov 13, 2009 | Arrow 8000 Power Shot Pro Staple & Nail...
Power shot stalel gun
there should be a silver clip thing thats over the mag that holds the staples try sliding that down and then it should open 4 you
Jul 18, 2009 | Ace Hardware Ace Staple Gun
Can't remember how to load staples in my power shot stapler.
power shot guns have dif crown widths bring the gun to home depot or lowes and match them up or get the model # off the gun
Dec 08, 2008 | Ace Hardware Ace Staple Gun
Tools & Hardware - Others Logo
827 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
