Question about Samsung Gravity SGH-T459 Cell Phone
My keyboard is STUCK
The keyboard on my Samsung Gravity keeps getting stuck. There is a piece of metal that sticks out - I think it is a part of the sliding mechanism. What should I do?
I have a 1997 Isuzu Hombre. The shift will not come out of park. We have tried putting it into neutral, moving the metal piece and it worked, but it's stuck again. What could be the problem?
sounds like your starter is stuck or sticking to your transmission not allowing you to get out of park,,this is what your problem is
Oct 23, 2013 | 1997 Isuzu Hombre
Tip
Repair ACER Keyboard
Many a times, laptop's keys fell off the keyboard or it gets damaged. Don't fret on buying a whole new keyboard when you can repair the keys yourself.
This is an installation guide to repair keys of Acer’s laptop keyboard.
You should have a key cap and 2 or more retainer clips (plastic pieces), that goes underneath the key cap.
To install the key on your laptop keyboard, start out by observing the metal plates on the keyboard.
Always be sure to look at the metal keys because they differ in every keyboard. The larger metal hooks can be at the top, bottom, right or left side. The position of the metal hooks determines the position of plastic pieces.
Here you can see that it has one large metal hook at the bottom and two metal hooks at the top.
Take the larger plastic piece and observe that it has two holes at the top corners, two sticks at the bottom and two holes in the middle. The top holes are going to go into the top metal hooks on the keyboard. The smooth part of the plastic piece faces away from the keyboard.
Take the smaller plastic piece and observe that it has two holes at the top, two sticks at the middle and a bar with larger hole at the bottom. The sticks in the middle are going to go into the middle holes of the larger plastic piece. The bottom bar is going to click onto the bottom metal hook on the keyboard. The smooth part of the plastic piece faces away from the keyboard.
Place the smaller plastic piece onto the larger plastic piece and insert its sticks to the holes of larger piece. It’s one piece now.
Insert the top plastic sticks into the top metal holes and the bottom bar into the bottom metal hook on the keyboard. Get a thin object or a blade and stretch the plastic pieces downwards to insert completely.
Take your letter key cap, put it in the middle of the plastic pieces and push down evenly from all four sides.
That's all to repair ACER keyboard key.
Source: Acer Key Repair
on Dec 17, 2009 | Computers & Internet
Tip
Replace DELL Laptop Keyboard Key
Sometimes with Dell laptops, the keys on the keyboard gets stuck or damaged or fells off the keyboard. There are many different ways to repair your broken keys. Just put your mind to it and you will be able to repair it yourself.
You can place an order to replace your broken key or you can repair it you have all the parts intact.
You should have a key cap, 2 or more retainer clips (plastic pieces), which goes under the key cap.
Following is the installation guide to replace and repair Dell laptop key.
To install your key on your laptop keyboard, start out by observing your metal plates on the keyboard.
Always be sure to look at the metal keys because they differ in every keyboard.The larger metal hooks can be at the top, bottom, right or left side. The position of the metal hooks determines the position of plastic pieces.
Here you can see that it has one large metal hook at the top and two metal hooks at the bottom.
Take the larger plastic piece and observe that it has two larger sticks at the bottom, two holes at the middle and two shorter sticks at the top. The bottom sticks are going to go into the bottom metal hooks. The smooth part faces away from the keyboard.
Take the smaller plastic piece and observe that it has a small bar at the bottom, two sticks at the top and two sticks at the middle. The sticks in the middle are going to go into the middle holes of the larger piece and the bar is going to click on to the top metal hook. The smooth part faces away from the keyboard.
Place the smaller piece on the larger piece and insert its sticks to the holes of larger piece.
Push it evenly to insert completely. Get a thin object or blade and stretch the plastic pieces upwards so that it clicks together.
Take your letter key, put it in the middle and push down evenly from all four sides.
You’ve just repaired your Dell laptop keyboard.
Source: LaptopKey
on Dec 16, 2009 | Computers & Internet
Delete button keys not working laptop
Unlikely, good diagnosis though. You don't have much option there: Try a keyboard attached to it to see if that same key on the external keyboard works. If yes it means you will neeed to replace your laptop keyboard.
If it doesn't try to uninstall the keyboard driver and restart. keep your spare usb keyboard just in case, reinstall the driver from samsung support and download website if necessary.
Cheers
Oct 16, 2013 | Samsung Computers & Internet
Hi, it seems that my some buttons on my keyboard aren't working... they keep getting stuck.
If they are keep getting stick this means the Keyboard membrain will need replacing. Good luck
Aug 21, 2011 | Microsoft KIN One Cell Phone
Tip
How to repair laptop key
If your keys fell off from your keyboard, you can easily repair it by following the installation guide below.
You should have a key cap, one large and one small plastic pieces (retainer clips).
Take the larger plastic piece, it must have two larger sticks at either sides that are going to click onto the larger metal hooks on the keyboard.
Take the small plastic piece. It must have a small bar on one side that is going to click onto the smaller single metal hook on the keyboard.
Place the smaller piece on the larger piece and insert its sticks to the holes of larger piece. Make it one piece.
Put the plastic piece into the metal holes on the keyboard. Push it evenly to insert completely. Get a thin object or blade and stretch the plastic pieces so that it clicks together.
That's all.
Source: http://www.laptopkey.com
on Dec 01, 2009 | Computers & Internet
WHY IS THE KEYBOARD STICKING ON A MOBILE PHONE
You might have gotten something sticky stuck in the keys. But if you just press the buttons consistently for a few minutes they should start coming un stuck. Hope I helped.
Jun 24, 2011 | Samsung 60242601Sm SamsungĀ® IntensityTM...
3 weeks ago, I purchased a mi, wireless mousse, serial # 0005105. For the past couple of days the curser has been getting stuck. I changed the batteries in the mousse thinking that maybe that was the...
OH MY DEAR!! TAKE A PIECE OF PAPER .....AND RUB UR MOUSE OVER IT AND START..............U WILL ENJOY!! ACTUALLY WIRELESS MOUSE CAN ONL DONE ON MOUSE PADS AND PAPER!!
Nov 04, 2009 | Computers & Internet
Keyboard key issue in laptop
The metal bar needs to be clipped on to the plastic shift key. Look under the plastic shift key and you can see recess where the metal bar fits. Place the shift key over these recess and push down until it clicks into place.
Jun 12, 2008 | Gateway 2520915 Keyboard
Samsung Gravity SGH-T459 Cell Phone Logo
218 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
