Question about Magic Computers & Internet
My Next Book won't turn on with double click like the instructions say
I have tried quick, slow, hold foe one and hold for one, hold for one and hole for two? What's the magic combo? It seems to change each time I try,
  • Magic Master
  • 2,045 Answers
May be you've got a virus? try to factory reset it.
Posted on Apr 25, 2017
How do you work 2006 street glide push button key fob
1 long push on the remote turns it on and 2 quick clicks turn it off.
Disarming function may require practice. The key fob button must be pressed twice within 1.5 seconds to send the disarm command. The action is very similar to double-clicking a computer mouse. Light quick taps work best; very hard or very slow taps are less likely to work. The key fob sends a RF signal to activate all remote TSSM functions. The left front turn signal switch wire serves as the vehicle's antenna. If the TSSM does not respond (no confirmation at arming/disarming system) or responds weakly (limited range, won't consistently arm/disarm or synchronize),
Verify key fob battery voltage is at least 2.9 volts. Replace the key fob battery every 2 years.
Interference from physical surroundings may affect RF transmission. Place the fob next to left hand grip and disarm with two clicks or move the motorcycle to a new location and try again.
Check for damage to antenna wire. Does left turn signal work?
After a battery disconnect, the TSSM will not enter the configuration mode on the first attempt. All attempts to assign a fob or enter the configuration mode will require at least two attempts.
The TSSM system uses batteries in the key fob and siren. These are the only parts requiring periodic maintenance.
Battery Replacement
Open the key fob case, place a thin blade between the 2 halves of the case, slowly twist the blade remove and replace battery positive + side down, use a Panasonic 2032 or equivalent, align the case and circuit board, snap the case halves together, while standing next to the motorcycle, press and hold the key fob button for 10 to15 seconds until the security system responds with two turn signal flashes/siren chirps.
May 04, 2014 | Harley Davidson Motorcycles
Mac Book Pro repeats Start Up Instructions
what instructions come at startup? please be clear
Mar 21, 2008 | Apple MacBook Pro Notebook
Sandisk ultra sdhc card won't record in my canon digital camera. i get a memory card error
All you have to do is
Step One
To save data, use EASEUS Data Recovery software (free version - 1GB of data recovery). how:
1. Download and install EASEUS Data Recovery
2. Insert micro SD
3. Open EASEUS Data Recovery, choose Complete Recovery - Next
4. Select the drive micro SD - Next
5. Save the data to the hard disk (max. 1GB)
6. Because of your micro SD 2GB, repeat the process of recovery (repeat step 2, 3, 4, 5)
After all data is secure, do the process repair micro SD
Step Two
The first alternative - use the software HP Drive Key Boot Utility
Using the HP Drive Key Boot Utility, for Win XP
1. Download and install the software HP Drive Key Boot Utility
2. Then, double click the file cp006049.exe - select Install.
3. Insert micro SD
4. Then, open the program "HP Drive Key Boot Utility" - Next - select drive - Next - Create new or replace exiting configuration - Next - Hard drive - Next - Create new file system - Next - wait until the process is completed - Next - Create firmware flash package - Next - Finish.
5. Remove the micro SD from the USB port, then insert it again.
6. Quick format micro SD (FAT file system)
7. Restore all data, to the micro SD.
Using the HP Drive Key Boot Utility, for Win Vista or Seven
2. Then, double click the file cp006049.exe - select Extract
3. Insert micro SD
4. Then, double click file hpdkbu.exe - Next - select drive - Next - Create new or replace exiting configuration - Next - Hard drive - Next - Create new file system - Next - wait until the process is completed - Next - Create firmware flash package - Next - Finish.
The second alternative - use software HDD Low Level Format Tool
1. Download and install HDD Low Level Format Tool
2. Insert micro SD
3. Open program HDD Low Level Format Tool, select micro SD - continue
4. Click S.M.A.R.T - click Get Smart Attributes
5. Click LOW LEVEL FORMAT - click Format this device
6. Wait until the process is complete - press OK
7. Remove the micro SD from the USB port, then insert it again.
8. Quick format micro SD (FAT file system)
9. Restore all data, to the micro SD.
I hope this information helps.
Oct 15, 2011 | SanDisk 2GB microSD Memory Card
Web pages down loadingway to slow. Sometimes I have to double click on a page to get the hole page to download
Try restarting the pre by holding down the power button until a window pops up and selecting restart. If this doesn't help, check the top right corner of the phone, where your signal reception is shown. If the box next to is says EV, you should be connected to the right data signal. If it says 1x or R, you are either in an area where data has low or no reception, or your phone is having trouble locking onto the correct data network. If is says EV, then I would say that it is just the phone. To be honest, the pre has never been the snappiest or the most responsive of phones, and I often have to double tap on mine.
Jun 23, 2011 | Palm Pre Cell Phone
I purchased my 7" netbook a month ago and it
When you have the net book on for a few minutes, the screen foes go black as the machine goes to sleep to conserve battery power. If you touch the pad in the next few minutes, it will come back on, but if you leave it too long it cuts itself off and you have to turn it back on by pressing the on and off button. Turn it over on it's back and look for a small hole about 1in from the diagonal right corner of the data plate. Stick a tooth pick in that small hole and gently depress the micro switch and hold for a few seconds while the AC power is connected to the net book. This will re-load a fresh copy of the operating system from the on board chip where it is stored. Forother operations read the suggestions below attached.
It is looking for apassword (WiFi Network Key) You have to double click on the little computericon down in the right tool bar area, the one with the two side radiating arcs,and possibly has a small red X under it. The red X indicates that it is NOTconnected. When you double click on that icon a window called RT28701 opens up,then you click on Wireless Information tab, then you cursor down to the name ofyour WiFi and high light it and click the connect box. Then another windowopens up called Network Properties. Uncheck "The key is providedautomatically" box. This will allow you to type in your "NetworkKey", the password that protects your network from outsiders. This"KEY" was set up when you installed the router on your servercomputer. If this does not work at first, turn the machine over on it's backand using a toothpick, insert it into the little hole about an inch diagonallyfrom the right corner of the data plate, this will re-load a new copy ofeverything including the WiFi RT28701 driver. sometimes thisdriver gets confused. See my TIP at: http://www.fixya.com/support/r7350901-fix_synet07526_wifi_flashing AdditionalInformation When I try to signon with the red X showing, I get "The page cannot be displayed If I thendouble click on the icon down in the right corner I elucidated above, RT28701opens up to "Internet Protocol (TCP/IP) with all zeros in the IP addressfield, and Subnet Mask, with no entries in the default gateway. That is a clueto me that the auto sign on has not found a viable network or needs somethingelse. If I then click on Wireless Information tab, The list of availablenetworks appear in the box. The machine keeps trying to associate my previousentered name site with my prefered site and tells me the signal is good, but itcannot link up. This is a signal to me that it has lost my Network Key or thatthe software has failed or both. I then click on advance anddelete my prefered network and hit OK, this will force the software to ask mefor my network again, and notice that the prefered is missing. I click on thename of my network again and then hit connect., then the Wireless Networkproperties window opens up and I can insert my Network Key again after Iuncheck the "The key is provided automatically" box. I enter the keyand hit the OK button. I still do not get a connection, so I reboot themachine, and wait for about 30 seconds and the machine synchs up because thelittle RED X under the icon has disappeared. Now the machine will hook to theinternet as long as I want to, but sometimes when I turn the machine on it willnot synch, so I go through the above sequence again. The secret is once youhave entered your key and ask for the machine to synch up you have to reboot.Why? I do not exactly know, but I suspect that the WiFi driver looses it
Jan 04, 2011 | Sylvania G-Netbook
Player won`t read
turn console onto standby and leave a min
then hold button in till it beeps 3 times and release
then do this again it will beep 3 times last one being double quick beep
a menu should appear
click on the one that says files this will restore your lens reader
Nov 23, 2009 | Sony Playstation 3 (PS3) Console
Trying to slow cook
Well let me tell ya that's one of my favorite things to do
Just pop that yummy piece of meat right into the pot. add 3 cups of water. Add some salt and pepper, and turn it on low before you go to bed and in the morning you will have something awesome, with nice broth. But you need to ck, the water leval, dont let it go dry, you may need to add more water. .You don't need to cover the hole roast with water 1/3 up is good.You will have nice broth . I can make awsome gravie but thats next time.Bonapatite DFD please rate me.TK U
Apr 11, 2009 | Nesco 4816-47-30 6-Quart
General Electric 6-Quart Slow Cooker double bowl
According to instruction book: To use Double bowls in the crock water must be used. Otherwise crock may overheat and crack.
1-Pour one quart of water into the crock. Prepare recipe according to instructions. Place food in the bowls.
2-Place both bowls into crock. Cover & cook.
To Use Double bowls in the base (without crock)
1-Prepare recipe according to instructions. Place food in bowls.
2-Place both bowls into the slow cooker base. Cover and set control knob to desired setting.
Hope this helps.
JL in CA
Jul 03, 2008 | GE 106851 6-Quart
Wont turn on
Get this. The instruction manual, at least the one that came with my MP3 player, has INCORRECT instructions for how to charge it. It says you just plug it in, but you actually have to plug it in and double-click the power button. Don't click and hold, and you DO have to press it twice, quickly. You'll see the charge bar start to fill.
You may also want to try resetting it, use a paper clip and poke it into the little tiny hole on the top next to the headphone plug in. That should reset it and be good to go. If that doesn't work, try reformatting.
Cheers!
Dec 17, 2007 | Memorex MMP8565 MP3 Player
Computers & Internet Logo
Top Magic Computers & Internet Experts
Computer Links
john h
Are you a Magic Computer and Internet Expert? Answer questions, earn points and help others
