Question about Emerson Audio Players & Recorders
Need help on how to set my Emerson clock to pm
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Emerson Master
  • 1,745 Answers
Check with your OM
Posted on Apr 25, 2017
Model #MWG9111SL
am/pm may not be a separate control. Try setting the hours 12 hours ahead to change from am to pm.
Apr 20, 2015 | Emerson Microwave Ovens
How set the clock ?
Look for the key on the key pad on the right side. Push the one that says clock on it. Then push 3:35, and leave alone until it stops blinking, and then it should be set. The only other thing you want to check is if they have an am/pm setting in the upper left hand corner of the digital display window. Most don't, but its always good to check. If you have any further questions, feel free to contact me and I'll help you figure it out. Good Luck!
Mar 30, 2010 | Emerson MW8106W Microwave Oven
How do i set clock for time of day
You can download your owner's manual free here.
From the manual:
SETTING THE CLOCK - When the microwave oven is plugged into an outlet, the oven will display " 0:00 "
1. Press the CLOCK button; the hour digit will blink
and the clock indicator will light.
2. Press the number keys to set current hour.
3. Press the number keys to set current minute.
4. Press AM/PM to choose AM or PM.
5. Press the CLOCK button again; the display will
show the present time. After the clock has been
set, the time will appear with blinking colon,
unless the oven is cooking or defrosting.
NOTES:
- To reset the present time in the display window when the oven is off, press the CLOCK button and
reset.
- If you make a mistake when setting the time, press the STOP/CLEAR button.
- To recall the actual time while the oven is cooking or defrosting, simply press the CLOCK button
and the display will show the actual time for three seconds.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 03, 2008 | Emerson MW8107WA Microwave Oven
Emerson Radio CKD9906
I hope this will help you, I just found the Users Manual to this Model online myself, as I needed info on setting the Alarm.
I am also going to upload the full Manual, just incase anyone else needs it.
Cheers!
Peachess
Setting The Time Of Day
• Connect the power cord to your AC outlet. Make sure to use an outlet that is
always ‘live’. Do not use an outlet that is controlled by a wall switch.
• When the unit is plugged in for the first time the
display will show flashing “12:00” (AM).
1.) While the display is flashing, press the HR. button to set the hour. Be sure
to observe the PM indicator to set the hour correctly. If the PM indicator is ‘On’
the hour displayed is PM.
2.) Press MIN. button to set the minute correctly.
3.) Press the TIME button once. The time is set.
The display remains ‘On’.
Note: You may proceed to re-set the time again by pressing the TIME button
once during Power-off or CD, FM, AM, Buzzer modes.
Important Notes !!
If you press and hold the TIME button any time, the clock will change to
European 24-Hour format, and 12-Hour USA format.
May 10, 2008 | Emerson (CKD9906) Clock Radio
Setting the clock on Emerson MW 8115SS
Press Clock, press the numbers for hours & minutes, select with AM/PM pad, then press Clock again to set it.
Yours Emerson microwave owner's manual is available for free download here.
Mar 10, 2008 | Emerson MW8102SS 1100 Watts Microwave Oven
I have an Emerson Microwave Oven MW8997W and cannot change the hour (time) on my clock. How do I change the clock? Debbie
If your keys do not work at all, you probably have a bad keypad, in which case I'd ask you to reply back. In the meantime:
SETTING THE CLOCK
show the present time. After the clock has been set,
the time will appear with blinking colon, unless
You can actually download your owner's manual here
Mar 10, 2008 | Microwave Ovens
Alarm 1 won't go off when set to AM
Sorry it took so long to answer your question about the Clock/Radio. This look like a problem with the Clock/Radio's Microprocessor. You will need to reset the microprocessor by removing all power sources to the microprocessor. This means removing the Clock/Radio from the A/C power source and removing the internal battery (CR2430). After removing all the power sources from the Clock/Radio, let the Clock/Radio set for a period of about 3 hours. This will let the power completely drain from the microprocessor and reset it to the factory settings. You can then reinsert the internal battery and plug the Clock/Radio into the A/C power source. The Clock/Radio should have reset and the functions returned to normal operations. If The Clock/Radio functions have not returned to normal. You will need to let the Clock/Radio's microprocessor drain off the power again and put a new internal battery (CR2430). Then test the Clock/Radio's functions again. The Clock/Radio functions should have returned to normal operation. If you are still having problems getting the Clock/Radio to return to normal operation. You can call the Emerson customer support at this telephone number 1-800-909-1240- Call them between the hours of 8am to 4:30pm central time USA. Give them the make and model number of your Clock/Radio and ask them for their assistance. I hope this information helps you with your problem. Thank you for using FixYa and have a nice day!
Nov 19, 2007 | Emerson Smartset Clock Radio
Clock loses time
Take daylight savings time in the clock setting. if not, it might be a clock defect in the unit.
Nov 01, 2007 | Emerson EWR20V4 DVD Recorder/VCR
24 hour clock
It should be in your users manual but if you cant find it try this # 905-940-5089 and tell them what you need .. Good Luck
Jun 22, 2006 | Emerson CKD9901 Clock Radio
Top Emerson Audio Players & Recorders Experts
Greg Cann
Greg Cann
Are you an Emerson Audio Player and Recorder Expert? Answer questions, earn points and help others
