Question about Star Health & Beauty
Sun star speed 175 bed shuts off before it time out
Need manual for a sun quest tanning bed super 32 xl?
http://www.tanning-bed-parts.com/files.php?cat_id=3
Jul 19, 2014 | Wolff Sunquest 16se Tanning Bed
The wiper blades are skipping on my 2013 ram 1500 sport
It is possible you need new wiper blade refills for your wipers, if they have been affected by your sun and climate. Also, try getting some windshield stripper and clean the windshield with it.
Apr 22, 2014 | 2012 R-A-M 1500 ST Crew Cab Pickup 4.7L V8...
How far is murcury away from the sun
Mercury is the closest planet to the Sun - it orbits at an average distance of 57,910,000 km, or 0.38 AU from Sun. (An AU is an Astronomical Unit; it is equal to the distance between the Sun and the Earth.) Mercury's diameter is 4,880 km and it has a mass of 3.3023 kg. Mercury has been known since at least the time of the Sumerians (3rd millennium BC). Although the Greeks had two names for it, Apollo for its apparition as a morning star and Hermes as an evening star, they knew that the two names referred to the same object. We know this planet as Mercury - the name of the Roman counterpart to Hermes.
Mar 31, 2014 | Zazzle Planet Mercury Blackberry Bold...
The distance from mercury to sun
Mercury, shown at left in a Mariner 10 image, is the closest planet to the Sun - it orbits at an average distance of 57,910,000 km, or 0.38 AU from Sun. (An AU is an Astronomical Unit; it is equal to the distance between the Sun and the Earth.) Mercury's diameter is 4,880 km and it has a mass of 3.3023 kg. Mercury has been known since at least the time of the Sumerians (3rd millennium BC). Although the Greeks had two names for it, Apollo for its apparition as a morning star and Hermes as an evening star, they knew that the two names referred to the same object. We know this planet as Mercury - the name of the Roman counterpart to Hermes.
Feb 12, 2014 | Zazzle Planet Mercury Blackberry Bold...
Are tanning beds safer than tanning in the sun?
Although tanning beds are more controlled than tanning outside in the sun, ultimately all exposure to UV rays is potentially dangerous to the skin and can put you at risk of skin cancer and premature aging. For a safer way of tanning - look for sunless tanning products rather than using tanning beds or laying on the beach for hours.
Feb 18, 2013 | Health & Beauty
What does SPF mean? I see it all the time on sun lotions etc but am not sure what it means.
SPF stands for sun protection factor and usually has a number next to it which defines its strength. The ingredients in it will prevent the sun rays from reaching your skin for a length of time (the higher the number, the longer it works). If you see a product that says it's sunblock, it won't have an SPF number on it as it blocks the sun altogether.
Is tanning on a tanning bed just like tanning outside in the sun?
No - it's very different as outside, various objects block the direct rays of the sun and allow you to be outside in the sun for a lot longer. Tanning beds are very instense. You should not be on the bed for longer than 10-12 minutes for your first sessions and be very careful about adding extra time.
Are there special tanning lotions for indoor sun beds, or can I use a regular tanning lotion?
There are special indoor tanning lotions that supposedly are packed with vitamins and minerals and help speed up the tanning on a sunbed, which also helps you get better value for money from your session. I don't know if they are significantly different from tanning lotions that you buy for outdoor use. You should ask your pharmacist for advice.
How long should you stay on a sun bed for each session? I am worried about getting burnt.
You should never be on a tanning bed for more than 20 minutes at a time and for no more than 3 times a week. Exceeding these amounts will really increase your risk of skin cancer.
I need to find out the electrical load in amps or KW for a zenith sun bed
Use OHM's law. wattage divided by voltage=amperage The bed should have an info sheet attached showing how many volts ( I am guessing 110 VAC) and it's wattage rating. I found that Zenith and Sunquest may be one in the same. Here is a link to the info sheet they have. Zenith/Sunquest Sun Bed Specs Link Looks like they draw a serious load, averaging 50 amps. Be sure to allow enough extra amperage in the circuit as to not overload and keep popping breakers.
Jan 15, 2013 | Baby Gear
Health & Beauty Logo
27 people viewed this question
Top Star Health & Beauty Experts
john h
ray gallant
 steve
steve
Are you a Star Health and Beauty Expert? Answer questions, earn points and help others
