Question about Exercise & Fitness
Treadmill making a clicking noise on the right side while i'm exercising on it.It doesn't make any noise if I have the treadmill running by itself.
    Habit-Forming:
    New Friend:
  • 35 Answers
Bad bearings torn tread belt slapping under load?
Posted on Apr 25, 2017
My sole F63 treadmill squeaks when inclining from 0to5. It makes no noise after that, or coming back down.
Please LUBE very the shaft motor, with Grease.
and RUN again.
Otherwise the ball bearing inside is Defective and repair.
Blessing.
cuadra2016@yandex.com
cell+whatsAPP:+50588611441
Treadmill Repair Incline Motor Lubrication
Nov 25, 2017 | Exercise & Fitness
Can I fix a NB1500 treadmill belt that is bowing in the middle? I've tried adjusting the tighteners on the back and cannot eliminate the bowing in the middle.
No, you need a new belt as it is stretched because that is where it gets pounded all the time. $50 to $100 depending on the quality you choose.
New Balance 1500 Treadmill Walking Belt 20 x 119 - Treadmill Doctor
https://www.treadmilldoctor.com/new-balance-walking-belt-1500
Replacement Walking Belt For The New Balance 1500 Treadmill. Belt size 20" X 119".
New Balance 1500 Treadmill Walking Belt - eBay
www.ebay.com > ... > Fitness Equipment & Gear > Other Fitness Equipment & Gear US$94.99 - ‎In stock
New Balance 1500 Treadmill Walking Belt in Sporting Goods, Fitness, Running & Yoga, Fitness Equipment & Gear, Other Fitness Equipment & Gear ' eBay.
Amazon.com : New Balance Treadmill Running Belt Model 1500 ...
https://www.amazon.com/Balance-Treadmill-Running-Belt-Model/.../B00H4QKAOO Rating: 5 - ‎1 review
This is a 1-ply Residential walking belt, some sellers will try to sell you a 2-ply belt (claiming better quality) for your treadmill, which is not recommended for ...
Amazon.com : Treadmill Doctor Newbalance Treadmill Running Belt ...
https://www.amazon.com/Newbalance-Treadmill-Running-Belt-Model/.../B008EYOF... Amazon.com : Treadmill Doctor Newbalance Treadmill Running Belt Model 1500 : Exercise Treadmill Belts : Sports & Outdoors.
NB1500 treadmill belt Google Search
Aug 14, 2017 | Exercise & Fitness
My trotter supertrainer 540 treadmill reads error50
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
Error 50 means over speed. Check speed sensor and cable, SCR, cap, brake on XL models.
Nov 12, 2015 | Exercise & Fitness
Treadmill makes loud grinding sound when I run in the middle of the tread. it doesn't make the noise if I run on the left side.
1)you must LUBE the DECK BELT, inmediately, for to avoid the friction
2)LUBE the rollers bearing.too
3) See the main motor for bearing and repair the motor for bearint too.
4) If the problem persist you have worn deck belt, and replace.
God bless you
Nov 07, 2012 | Exercise & Fitness
Treadmill deck squeaking on left hand side
please do the following:
1) LUBE the deck belt , this happen because the lack of maintenance schedule.+adjust it each side see the diagram,worn deck probably.
2) Lube the rollers bearing too
3) test the motor for bearing need repair
4) test the drive belt for broken or worn.
5) test the puller for drive motor,can be worn, and replace.
God bless you
Jul 18, 2012 | Reebok Exercise & Fitness
We had the lift frame crack on our Nordic Track A2550 after very limited use (but 1mo. after warranty). We replaced it in February and after 500 additional miles, the lift frame has cracked again. I...
General Construction
  • The most basic breakdown of a treadmill: a continuously moving belt powered by a motor over a deck that is mounted on a sturdy metal frame. The variables are the size of the belt, the power of the motor, the thickness and composition of the platform as well as the range of options that increase both function and cost of the treadmill. Making the right choices on all these permutations will add to the enjoyment and benefits of using your treadmill.
Frame Composition
  • Frames are generally made from aluminum or steel. Even if there's no difference in the tensile strength in the frames, steel is better because it will produce a heavier treadmill. That increases the machine's stability and lessens the vibrations generated by your exercise, especially running. Frames can be either bolted or welded together. Welded frames are stronger, and there is no risk of a bolt working loose during long periods of operating the treadmill.
Motor Size
  • Most treadmills have two electric motors. One raises and lowers the deck, allowing you to get a versatile workout. The more important motor is the one that moves the exercise belt under your feet. The drive motor turns a flywheel that is connected by a belt---similar to the belts for the engine of your car---to the front roller. The front roller pushes the exercise belt to the back of the treadmill where a free-moving rear roller serves as the exercise belt's turnaround point. Check for the continuous horsepower (CHP) and revolution per minute (RPM) rating on the motor. In fact, lift the motor cover and look for the ratings stamped directly on the motor. A motor that needs high RPMs (more than 5,000) to generate enough torque to drive the exercise belt is a candidate for overheating and is unlikely to last long. If your plan is only to walk---not run---on your treadmill, a 1.5-horsepower motor with less than 5,000 RPMs will suffice. But if you weigh more than 200 lbs. or you plan to run on your treadmill, you will need at least a 2-horsepower motor with an RPM rating of 4,000 or, preferably, less. Choosing one with 2.5 horsepower or more will be even better if you plan to run for long workouts. When in doubt, go up in horsepower. The motor not only moves the belt but it must overcome the resistance you provide with each stride. Smaller motors with high RPM ratings will allow the belt to hesitate slightly. In addition, you likely will be moving more slowly than the speed displayed on the treadmill's console if you are trying to run. Larger motors might be noisier, so look for a motor housing that absorbs some of the machine noise when the treadmill is in operation.
Belt Size
  • Your workout plans also will dictate what size belt and rollers you need. The treadmill's exercise belt will be made of a thin, multiply polyester/fabric mix with a PVC top coat, which produces the best combination for reducing friction and the heat it generates. This will extend the life of the belt and prevent slipping while you're in motion. Although the surface will be smooth against the deck, the PVC coating will be waffled underneath your feet for better traction. Even if you have short legs and you only plan to walk on the treadmill, you should get a belt at least 18 inches wide and 48 inches long. If you plan to run, a 20-inch belt width is better and 22 inches is best, and you shouldn't choose anything less than 54 inches in length. Longer---up to 60 inches---is better, especially for tall runners. The treadmill will run more smoothly with bigger rollers because the rollers will have more grip surface for the belt as it is propelled over the deck. If you plan to run on your treadmill, rollers with 2-inch diameter are the minimum. Some high-end treadmills come with 3.5-inch rollers. Larger rollers also result in less stress on the bearings; a 3.5-inch roller will need to rotate roughly 60 percent less than a 2-inch roller to cover the same distance.
Platform Surface
  • Treadmill decks are made of wood or, more specifically, composite wood substitutes, either particle board or medium density fiberboard (MDF). For runners, an MDF deck at least 1-inch thick is the minimum. A 3/4-inch surface might be OK for walking, but it will be too bouncy for running and will crack more easily. The deck surface will have a laminate coating---preferably on both sides---to allow the exercise belt to slide smoothly. Treadmills commonly have rubber grommets built into the frame to provide cushioning as you exercise. Some treadmills have shock absorption only in the front (landing area) so that you have a firmer push-off for your next stride. With the built-in shock absorption and the smooth surface, a workout on a treadmill is likely to be less stressful on your joints than running outdoors, unless you have access to a perfectly level wood-chip path.
Speed and Incline
  • Most treadmills now come equipped with easy-to-reach controls that allow you to change the belt speed and the incline of the deck while the belt is in motion. The lift motor generally uses a hydraulic lift to raise and lower the treadmill on its front legs. The elevation motor should have a thrust value of at least 400---more for runners---so the deck can be shoved up without any hesitation during exercise. Some treadmills use gears for elevation. That's neither as smooth nor as reliable as hydraulic lifts. The speed of the belt is controlled from the console of the treadmill. As you raise your speed by 1/10 mile per hour, the motor subtly increases the power it is generating to the rollers, much as a hair dryer does less subtly as you click from medium to high. For runners, look for a treadmill that provides a speed of at least 12 miles per hour and allows an elevation of at least 10 percent. That will give you the opportunity to include some speed work and hill training in your workouts.
More Features
  • Some treadmills come equipped with iPod ports, built-in TVs, drink holders, cooling fans, computer-generated workouts and heart-rate monitors. The computer workouts will build in elevation-change programs, and you can punch in the starting speed of your workout and change it manually. Treadmills also allow you to create programs in which you can choose both the speed and elevation changes. Heart-rate monitors calculate your heart beats per minute and can be operated continuously using chest or arm bands or intermittently using a finger clip or by gripping a sensor on the front rail with one hand. But none of these features outweighs the importance of choosing the right belt and motor for your workout.
Safety
  • Make sure the treadmill has a safety release---usually a magnetic key---so you can stop the exercise belt dead in the event of an injury or other emergency. The treadmill is wired so that the key must be in place on or near the console to complete the electronic circuit and allow the machine to operate. Yet the key can easily be yanked free, immediately stopping the drive motor and putting the brakes on the exercise belt.
Sep 21, 2011 | Nordic Track NordicTrack Treadmill, A2550
My Reebok 9500 ES Treadmill is making a very loud klunking sound from the rear roller - right side. The sound is not constant - it comes and goes. Doesn't seem to matter where I position myself on the...
Treadmill Maintenance How To Lubricate Treadmill Belt
Please lube very well Roller front and back with WD-40
if the problem persist replace Roller(s).
LUBE the deck belt as show in the video.
Blessing
cell+whatsApp: +50588611441
Jan 17, 2018 | Reebok Exercise & Fitness
Too noisy problem which is annoying during exercise.
The make and model of the treadmill would help. Your treadmill has 100's of moving parts so the noise can be coming from anywhere. Suggest starting the treadmill with no one on it. Does it still make the noise? If so from where? No noise? Then has someone walk on the treadmill and try and isolate the noise. You may need to remove the motor hood.
Jul 28, 2010 | Proform 540ls Treadmill Walking Belt
THE BELT ON OUR MACHINE IS BROKEN CAN I BUY A REPLACEMENT AND HOW DO WE FIT THE NEW ONE ON ?
The treadbelt can be installed by removing the front roller, the drive belt, rear roller and screws in the siderail. You do not have to remove both sides, just lift the deck and slide new belt on. To save yourself some agravation, you may cut the old belt off.
Exercise equipment service Treadmills Ellipticals and Bikes Parts Assembly... 877-805-1030
Mar 15, 2010 | Reebok Rt1000 Treadmill Walking Belt
Exercise & Fitness Logo
101 people viewed this question
Top Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
