Question about Dryers
Replacing door switch - Dryers
2001 Buick Regal. Power door lock swith will not lock doors.
Remove the door panel and unplug the connector to the door actuator. Probe the contacts with a voltmeter set on DC volts. Then operate the lock/unlock switch. You should see the voltage toggle from +12 volts to -12 volts. If you do, then the wiring, switch and connector are good and you have a bad actuator. Be prepared to start replacing all of them because they all operate the same number of cycles.
Jul 28, 2017 | 2003 Buick Regal
2007 hyundai entourage sliding door will not close when button inside top console and on the inside is pressed
faulty sliding door switch or its faulty which open/close the door.
The switch gets 12 volt source and it commands the motor.
Any of the one if gets faulty the same problem arises.Check 12 volt on motor and switch.If no volt the issue is there,on which part there is no volt.
Check the help link mentioned below for more help :-----
Details for replacing right side slide door light switch?
http://repairhelpcenter.blogspot.com/2012/01/details-for-replacing-right-side-slide.html
How to test Power door locks?
http://repairhelpcenter.blogspot.in/2012/02/how-to-test-power-door-locks.html
Car door will not close?
http://howtobyme.blogspot.com/2011/11/car-door-will-not-close.html
These will help.
Thanks.
Nov 28, 2012 | 2007 Hyundai Entourage Limited Minivan
Machine won't start code dl F
The machine is not starting because the door lock fails to lock the door as what error code FdL stands for. It flashes after the door locking routine fails to lock the door after 6 attempts. Replacing the door lock/switch assembly is the only viable if no problem is seen with the wire harness connecting the assembly to the central control unit. The link below contains the detailed instructions in replacing the door lock/switch assembly.
Replacing the Door Lock/Switch Assembly on Whirlpool Duet and Kenmore Elite Washers
Aug 26, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Error dl f: door will not lock to start wash
This is obviously a door lock/switch assembly failure. The fault code FdL flashes if the door locking routine fails, after six attempts, to lock the door. You should hear the door lock clicks six times before the fault code flashes. Replacing the door lock/switch assembly is the only viable solution and it's a do-it-yourself repair. You only need a pair of needle-nose pliers to stretch the door gasket retaining hoop and a Phillips-head screwdriver to remove the screws securing the door lock/switch assembly to the front panel. Click on the link below for the detailed instructions on how to replace the door lock/switch assembly.
Replacing the Door Lock/Switch Assembly on Whirlpool Duet and Kenmore Elite Front Load Washers
Jun 17, 2011 | Kenmore HE3T Washer
I notice F22 error message on washer. Door seems to be jammed and will not unlock
This is a door lock failure code and it means the door lock is broken or just failed to unlock. Click on the links below for the detailed instructions for manually unlocking the door and replacing the door lock and switch assembly if it has indeed failed.
Manual Door Unlocking of Whirlpool Duet and Kenmore Elite front-Load Washing Machines
Replacing the Door Lock and Switch Assembly on Whirlpool Duet and Kenmore Elite front-Load Washing Machines
Mar 12, 2011 | Kenmore HE2 Plus Front Load Washer
Kenmore front load washer goes through wash and rince cycles but will not spin
These are symptoms of a broken door lock and switch assembly and the only viable solution is replacing the said assembly if no issue is found with the wire harness connections. The machine will not advance to the spin cycle unless the door lock spin switch is activated. This is a safety feature to prevent the door from opening and avoid injuries during the high-speed cycle. Replace the door lock and switch assembly and it should solve the problem. Click on the link below for the detailed instruictions on how to replace the door lock and switch assembly. The part number for the door lock and switch assembly of your machine may be different but the instructions still apply.
Replacing the Door Lock and Switch Assembly on Kenmore Front-Load Washing Machines
Mar 05, 2011 | Kenmore Washing Machines
Control panel displaying DL F and not starting
The door locking routine fails to lock the door after six attempts the the error code FdL flashes to indicate a failure in the door lock and switch assembly. The only viable solution is replacing the door lock and switch assembly. Click on the link below for the instructions in replacing the door lock and switch assembly.
Replacing the Door Lock and Switch Assembly on Whirlpool Duet Front-Load Washers
Nov 03, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Door start-stop switch sticking
Hi, the door pressure switch is malfunctioning at this time. simply replacing this switch will fix this issue.
There are just a few screws to release and a couple of wires to disconnect. once this is done, simply replace the old switch with the replacement switch. the actual switch mechanism is becoming unstable, causing the sticking. i recommend replacing it.
The switch itself can be found in the inner part of the rim in between the dryer door and the dryer drum/basket.
please rate and have a gret day:)
Apr 27, 2009 | Dryers
No power to passenger doors or locks
Double press and hold the entry button to reset all doors to open. The key fob as set itself to driver door only by the sounds of it.
Take the battery out and leave a few minutes, then insert and pair. ( driver door open )
Jun 11, 2017 | 2000 Pontiac Bonneville
Door switch
youd have to open the control panel and OHM out the switch with a mater to ck if it functions properly, however upon open panel its sometimes obvious that a switch would need replacing( for instance sometimes they're real corroded and dont switch on/off. sometimes they're physically burnt up and melted.
Mar 20, 2008 | Maytag 24 in. MDBH950AWS Built-in...
Dryers Logo
22 people viewed this question
Top Dryers Experts
