Question about Winix Air Purifiers
Winix air filter wifi signal blinks red - Winix Air Purifiers
I found a key and it has, winix, 5 circles, and a british flag, all ingraved in it. i want to know what the key opens! please answer my question!!!
Apparently they used for Vaultz storage boxes. It seems to be a common item. Here is a photo of a box with the key installed. I will post the link as well. You can make out the word WINIX on the key is you look carefully.
https://s.yimg.com/hd/answers/i/d95612a21fc34b5290ee92ffb5718d0e_A.jpeg?a=answers&mr=0&x=1449781209&s=aaecb71a94c8c70b96084689a3d14bda
Dec 10, 2015 | Winix Air Purifiers
What air filter do i buy for a replacement?
http://www.amazon.com/Winix-115115-True-Replacement-Filter/dp/B002QUZJAS
Jun 26, 2014 | Winix PlasmaWave 5000B Air Purifier
Where can I find replacement filter for Kenmore 85500 air cleaner
I just went to the chat site for sears parts and asked them to find one. They ordered part #119010 Filter CATEGORY: Plumbing and Heating
PART NUMBER: 119010
which comes up to this page... http://www.searspartsdirect.com/partsdirect/part-number/119010..... I did order it through them.. I hope this helps anyone else looking for a replacement filter for the Kenmore #85500 with filter #85501.. With the link above you can order it online.
Feb 14, 2013 | Kenmore EnviroSense 85501 Air Purifier
When I'm in my bathroom and showering the light turns red- what does this mean- Mold?. moisture?
The simple answer is moisture. If you have a bathroom exhaust fan, be sure to run it during and after you're showering. Typically, for a bathroom exhaust fan to reduce the moisture properly, it should remain ON for at least 15 minutes after your showering is complete,
Hope this helped to answer your question.
Apr 23, 2011 | Winix PlasmaWave 5000 Air Purifier
I just replaced my filter for the winix 5300 model and the replace filter indicator does not seem to turn off. Are there any solutions or procedures as to how i should go about this matter?
Remove the front cover and locate the FILTER RESET button below the DUST SENSOR level display indicator lights. Press and hold this button for 3 seconds until the unit beeps and the REPLACE FILTER indicator light goes out.
Apr 02, 2011 | Winix PlasmaWave 5000 Air Purifier
Mother gave me her filterqueen defender.. no manual. 360. There is a flashing red light even though its a new filter. Why?
The light is a reminder to change the filter, it does not sense if the filter has been changed or not.
When the red light is blinking, press and hold both up and down arrows until the red light blinks RAPIDLY, release both for a second or two, and press and hold both again until it stops blinking.
Dec 28, 2010 | Filter Queen Defender Air Purifier
How do you reset the machine, to get rid of the flashing red light after changing the filter?
Dec 09, 2010 | Filter Queen Defender Air Purifier
I've replaced the filter. why won't the red replace filter light shut off?!
Remove the front cover and locate the FILTER RESET button above the dust sensor level indicator lights. Press and hold this button for 3 seconds until the unit emits a beep and the REPLACE FILTER light goes out.
Sep 03, 2010 | Winix PlasmaWave 5000 Air Purifier
How do I reset the "replace filter" light? I put a new filter in an don't know how to make the red light go out. Thank you
With the unit on - take off the front panel - right under where the "replace filter" light is, there is a button that says "Reset" hold that button in until it beeps - then the light should turn off. Hope this helps :)
Jul 31, 2010 | Winix PlasmaWave 5000 Air Purifier
Filter Queen Defender red light will not blink
no with the red lite on it mean that you need to change your filter its a safety feature so you dont burn out your motor and also so you dont blow unpurified air through out your home
Oct 13, 2007 | Filter Queen Defender Air Purifier
Air Purifiers Logo
126 people viewed this question
Top Winix Air Purifiers Experts
Are you a Winix Air Purifier Expert? Answer questions, earn points and help others
