Question about Radio Communications
Where to buy in Pa. - Radio Communications
Can i use a peavey PVi2 mic on my peavey renown 400?
No you need a preamp for the microphone found on audio mixers. You will not get good sound from it even if you do buy a mini mixer to provide a preamp for the mic. I would suggest a pa like the ones in this link. Most of them have built in mixers (with preamps) also.
Portable PA Systems Sweetwater com
Apr 12, 2016 | Peavey Audio Players & Recorders
Toshiba laptop adapter not working.should i go for a new original or is compatible duplicate safe
I will not recommend you to repair it, it's a sealed box, not worth it. Just buy another one. Always a 3rd party adapter will be more cost effective. Toshiba PA3215U-1ACA
Dec 09, 2011 | Toshiba AC Adapter/Power Supply Cord...
PA 21 adapter shows no sign of life. LED does not light up. No output voltage
Try another mains power cord. If this does not work then the PA-21adapter is faulty and needs to be replaced.
Jun 13, 2011 | Dell PA-21 Family AC Adapter For Dell...
I have a cobra 29 LTD that has no audio in the PA mode or the CB (transmit or recieve) mode i've changed mics and also changed the audio IC to no avail. where do i look now?
look into buying a new radio. If you had researched further you would have found out that unless you are on cb your radio will not operate . If you are on PA the you can only transmit through the PA system not the cb. If you changed the audio IC then you probably did a cold solder on it. You need an external speaker to operate the pa mode and an external speaker to operate the CB mode .If you decide to fix it more it will cost you more then buying a new radio.
Jul 14, 2010 | Cobra 29 LTD CB Radio
Where do you plug in a PA system on this HP Pavilion dv7-3164 Laptop computer?
Hi, if you have an head phone socket on the side of your laptop then this is where it will plug in, how ever you may need to go to a computer store and buy an adaptor so as the pa system will fit into the smaller laptop haed phone socket.
let me know what kind of fitting the pa system has then i can tell you what adapter your going to need ok
Jun 14, 2010 | Computers & Internet
My Proview PA-32JK1A my component video wont
Replace the RCA component video cable.Should work after that,not yes the cable box.Should reboot the cable box buy unplug,replug it an hour later or call the cable company for the replacement box.
Mar 16, 2010 | Proview PA-32JK1A 32 in. LCD Television
What type of stereo receiver should i buy
Generally speaking it is always better to have separate amp for subwoofers and separate for higher frequencies.
But why do you want to power PA speakers with home/hifi receivers? You don't 90% of features which receivers have. Look for some PA amplifiers and you will get much more power at similar price. Also most receivers have only about 80 - 100 W per channel and this is NOT continuos power over all 5 or 7 channels! Only the most expensive receivers can do that. You can have 100 W for any channel, but not 100 W to all channels at the same time (spikes yes, but not continuously). And 100 W is very little for your PA speakers.
You should buy amp which has the same rating per channel as your speaker continuous power handling. So if your speaker has rating of 300 W cont. / 500 W spikes, buy amp which has at least 300 W, but 500 W would be better.
Feb 19, 2010 | Sony STR-DE545 Receiver
Radio Communications Logo
23 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
