Question about The Computers & Internet
Where did the phrase May Day come from - The Computers & Internet
How do I disable ee home phone voicemail
try the following
send a text with the phrase remove voicemail divert to 150 will cancel the voicemail divert
(sending a text with the phrase voicemail divert to 150 will re-enable the voicemail service).
if that doesnt work ring EE customer service they can do it for you
May 03, 2017 | Lands Phones
I need a pass phrase or network key to be able to log on to my wireless internet connection for my laptop.
Good day. If your looking for your looking for the pass phrase or network key for your router. You can try to do the following.
1. Check for a WEP key on the router itself. Usually it is on a sticker located under the router or at the back of it. 2. You can go to the router page using your internet explorer or mozilla > just type in 192.168.1.1 on your browser > it will ask for a username and password > username: leave it blank password: admin > then go to wireless setting > then it will show you your WEP or WPA or Wireless key > Dont be confuse the wep or wpa or pass phrase are all the same > then just type it on the space where its asking you to type in a pass phrase and that should work
3. If still you can locate it you can contact your internet service providers technical support department and they will be able to walk you through it
Hope this information will be helpful in resolving your concern. Have a great day and thanks for using fixya.
Jun 25, 2011 | Linksys Computers & Internet
I have the Boss RC-50 Loopstation. It has been great. Perfect operation for about 8 months. Today, when I started to use it, I noticed that I couldn't select "Phrase 1" by tapping the pedal....
Likely the switch contacts for that pedal have failed. You will probably have to get it repaired. Stomping on the pedals is a good way to damage them, but the switches are often marginally designed anyway...
If you can access the switch you could try getting some CRC226 available at Home Depot in the electrical department into the switch, but often the internal parts of switches fail.
Jan 30, 2011 | Boss Rc 50
How do you use the translate on oz-590A?
Word Translator
English-Spanish bi-directional word translator function is available
for download. Refer to "Downloading database" on page 32 for
details.
1. In the Main menu, tap
]to enter the Word Translator Mode.
2. English
Spanish translation is set by default. To change the
translation direction, tap the division arrow, or use
m
and/or
k .
3. Enter the desired source word and press
x. The matching
English or Spanish word will then be displayed.
• When the icon "
j" or "
l" is activated, more letters exist. To view
the remaining letters of long words that cannot be accommodated
on the screen, use
j or l to scroll.
• If there is no matching word, "NOT FOUND!" is displayed. The
word next in alphabetical order will then be displayed.
• Press
to scroll through the word list, or enter a new
word using the keyboard, and press
xfor another search.
Notes:
• If you choose not to download the Dictionary Database for the
English/Spanish Translator, then the extra memory space will be
utilized by other applications.
In such case however, the Word Translator function will be disabled;
tapping the
]icon will display a message "NO DATA!".
To learn how to download the Dictionary Database, refer to the
section "Downloading database" on page 32.
• The downloaded database for this Word Translator is utilized also by
the Spell checker; do not delete the database if you intend to use the
Spell checker function.
5-Language Phrase Mode
5-Language Phrase Mode is available for download. Refer to
"Downloading database" on page 32 for details.
Select an English key phrase to find equivalent expressions in four
different languages - German, French, Italian, and Spanish.
A phrase can be browsed under a traveling situation, or can be
selected from a list of words.
To search phrases in a certain situation
1. In the Main menu, tap Phrases to
enter the Phrase Mode.
2. Select the desired target language.
3. Select the desired scene to
browse the relevant phrases. For
example, select "3. Airport".
4. Tap the desired phrase to select.
Tapping the phrase one more time
to display the entire phrase.
5. Press
x to display the equivalent phrase in the target
language.
The Database menu of the Desktop Utilities allows you to download
database for the Word Translator / Spell Checker, and 5-Language
Phrase Mode from the CD-ROM.
1. Insert the PC software CD-ROM.
2. Click "Download" in the Database of the Desktop Utilities.
3. Select a file you wish to download, then click "Open".
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response.
Thanks, Joe
Nov 23, 2010 | Sharp Wizard OZ-590A
How to activate voice command 3760t
Page 19 of your manual:
Activating Voice Command
Speak your wakeup phrase. The Voice Command menu appears.
Setting your Wakeup Phrase
The wakeup phrase is a word or phrase you can say to activate voice command. The default wakeup phrase is "Voice Command".
1. From main menu, touch Tools > Voice Command > Customize Phrase.
2. Enter a new wakeup phrase.
3. Touch "Done"
If this solves your posted problem, please come back and rate our answer. Thankyou.
Nov 05, 2010 | Garmin GPS
What is wpa pass phrase while setting wireless printer
WPA with a Pre-Shared Key (PSK), also known as personal. PSK is entered as a pass phrase between 8 to 63 alphanumeric characters in the ASCII format at both ends of the wireless connection. Although PSK accepts a minimum of eight characters, for proper security, it is a good idea to use ample length and should not use a commonly known phrase. This phrase is used to generate session keys that are unique for each wireless client.
WPA pass phrase is a password for the wireless network to make it secured. You can obtain the WPA pass phrase when you access your router. Check the manual of your router for the address, username and password of your router. Go to wireless settings, you will see ther the SSID or Network Name, Network Key or the Pass Phrase and Authentication (WPA/WPA2/WEP). You can personalize the SSID,Network Key and Authentication. Remeber that for you to connect wirelessly the Authentication and Network Key on the router should match the Network Key and Authentication of the Printer or Computer.
Thanks for using Fixya,
Aug 06, 2010 | Computers & Internet
On my printer a hp c7280 all in one it ask me for
This is the passphrase for your wireless network. When connecting to the printer wirelessly, it needs to authenticate. The WPA phrase is what you typed in to access the wireless network with your computer if you did so.
The wireless router is a gate. The printer needs to get through the gate so it needs the password otherwise it can't get access. If you don't have this info readily available, please check your routers documentation as to how to retrieve it.
Hope this helps. Have a great day and don't forget to rate!
Feb 26, 2010 | HP Office Equipment & Supplies
Add/remove phrase
Go to lexmark.com and click your way to publications tou will find downloadable inst. books there.
DickyO
Aug 04, 2009 | IBM Office Equipment & Supplies
Help me javascript just mail me at ramzy_213@yahoo.com thanx
hello there!!!
First things First !
1) download the ultimate JAVA APL. run again.
O S
Feb 19, 2008 | Audio Players & Recorders
Computers & Internet Logo
19 people viewed this question
Top The Computers & Internet Experts
Perry Ralston
Level 1 Expert
ashu k...........
Level 1 Expert
ted dux
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
