Question about Water Pik Hand Held Shower
I have a triton amber II, Just had it installed, im finding the temperature dial won't go no higher than 3 and it goes up to 10 on the dial, number 3 is very hot, when turning the dial round from 3 to 10 the water slows down to a stop. Just wondering how we go about resetting the dial so 1 is coldest and 10 is hot. Cant seem to get it on a cooler setting as the setting from 1 to 3 is tepid to hot. i havent got no instructions for this shower, it was only used a month by a family member, and cant find them.
5 Suggested Answers
  • 297 Answers
SOURCE: 1/2 water through shower head 1/2 through tube
patmac make sure the clear hose is a overflow first. then make sure all connections are correct,sounds like an areator problem,some after market shower heads don't come with one you can purchase one at your local plumbing store.
Posted on Jul 27, 2009
  • 20 Answers
SOURCE: I have a Triton Rapide R2 electric shower problem
you can check the pipe lines there are normally more thane one way to set the pressure of the water one by the shower knobs 2 by the behind the head in the wall there are some water valves that may need to be opened up or by the water heater there are some valves there one coming off the heater one just on a pipe by the heater they may need to be opened. try that if that doesnt work come back and let us know and see what else you can do to fix it
Posted on Nov 11, 2009
blueextc3221
  • 15935 Answers
SOURCE: fitted a mira sport 9.5 kw twice 2 different
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 05, 2010
emissionwiz
  • 78267 Answers
SOURCE: I have a Triton amber 2 electric shower with no hot water
Great to hear.
Posted on Feb 13, 2012
My freezer isn't cold enough. Are the higher numbers on the thermostat dial colder or are the low numbers colder? See full question below.
Hi, If I remember correctly, make sure the freezer control is set to on, otherwise neither will cool.
You need to give it 24hr for temp to settle, then check to see if freezer temperature is 0? to 2? F (-17? to -16? C).
Turn control to next highest number if too warm.
Turn control to next lowest number if too cold.
Allow 5 to 8 hours for adjustments to take effect.
Check to see that fresh food section is 38? to 40? F (3? to 4? C).
Hope this helps
David
Mar 02, 2018 | Amana Refrigerators
Top of fridge freezing with temperature on lowest setting
You need a new thermostat but there are some things you can check in the link. 1 is the warmest setting.
Most refrigerator temperature settings are controlled with a dial or slider. They are sometimes labeled 1 through 5 or 1 through 9. If you are not sure what to set it to, then set it somewhere in the middle. If the dial is numbered 1 to 5 set it on 3, if the dial is numbered 1 to 9, then set at 4. USUALLY the higher the number on the temp control dial, the colder the temperature your refrigerator will get. If your drinks and food are not as cold as you like, set the temperature dial up one number higher. If it is at 3 and you want your food colder, set it to 4 and test 12-24 hours later to see if your food is at the temperature you want.
Why Is My Refrigerator Too Cold
Dec 18, 2016 | Refrigerators
Dial not working correctly, set on low numbers water comes out at high pressure, set it on high numbers and the water pressure comes out on low pressure ???? why.... the item in question is a Triton Madrid...
It sounds like the numbers are for the temperature indication and the higher the temperature the more slowly the water runs because it takes longer to heat it.
Apr 16, 2010 | Home
How do I set the temperature?
Hello Elise, The Dial should be set to the middle number three (3) to start with and allow for 24 hours of running before you make any adjustments, either up or down.
The higher the number the colder the fridge temperature will be. Just remember that it takes almost a full day for the fridge compensate for any changes to the thermostat. Also, only make adjustments in the temperature setting by only 1 increment at a time (either up or down) and again, allow 24 hours before making further changes.
If your fridge has the red button in the center of the temperature dial, that is the manual defrost button. So if you've got a build up of ice on the freezer section, just push it and it will defrost the unit for up 2-4 hours.
Hope you find this Very Helpful and best regards!
Merry Christmas!
Dec 14, 2009 | Magic Chef MCBR440 Compact Refrigerator
Deciding which way to turn the dial to get the minimum temperature
Coldest when you are on the higher number or higher letter. Ave setting should be around 3 on a scale of 1 to 5.
Apr 12, 2009 | Refrigerators
Triton Electric Shower Temperature too hot
You could have mineral deposits on the temperature probe inside of the unit. If you remove the heater and purchase a bottle of lime and scale remover (lime away) to put inside of it. Let the unit sit full of water and chemicals for 24 hours. Flush out the unit to remove any residue. You may see the water is brown if you have a lot of buildup. Reconnect unit and test your settings. If this doesn't work, install a anti-scalding device, available at a plumbing supply store.
Oct 22, 2008 | Home
Beko LF320 temperature dial numbered 1 to 10 which way is coldest?
Right to the point people. ok to make it warmer, it is the lower the number
thanks and go night ;)
Oct 01, 2008 | Refrigerators
Temperature control
I have a danby mini fridge and freezer and noticed the same problem. The temperature dial has NO NUMBERS ON IT! it just has a strip that goes from light to dark blue. That's it. I looked in the manual and it doesn't say anywhere which way is colder...it makes sense that the darker the blue the colder the temperature but why keep us guessing?
Mar 15, 2008 | Danby 3.6 cu. ft. / 102 liter Chest...
Water Pik Hand Held Shower  Logo
559 people viewed this question
Top Water Pik Home Experts
john h
Are you a Water Pik Home Expert? Answer questions, earn points and help others
