Pmd103cmtftlcd with dvd - Computers & Internet
Pmd103cmtftlcd with dvd does this have an external manual audio output setting
If no analog audio outputs the optical is it you have to go thru a receiver with an optical in using a to link fiber optic cable
Apr 24, 2017 | Televison & Video
Tip
How to copy protected DVD on Windows?
DVD Copy is the useful software for us to backup our dvd, it can copy DVD perfectly at super fast speed. This DVD to DVD Copy can easily copy DVD in 1:1 ratio; compress DVD-9 to DVD-5, also can make the DVD backup to DVD folder or ISO image file, even burning DVD folders or ISO image files to DVD.
This best DVD Copy has more additinonal functions, like available for you to choosing copy full disc or main movie of the source DVD, select target audio and subtitle even include or skip menu to meet your specific need and edit the volume.
The powerful DVD Copy is a easy to use DVD copy and clone software. Without complicated setting, this DVD Copy gives you the total freedom to copy and backup all DVD movies to DVD disc in 1:1 ratio, or save DVD movies to hard drive as DVD Folder or ISO image file.
DVD Copy is the best partner for you to clone DVD to a new disc or copy dvd to DVD Folder, with the best DVD Copy, we can backup our favorite DVD easily with several simple steps, just have a try.
on Aug 16, 2010 | Office Equipment & Supplies
Tip
How Can I Copy DVD Files Easily on Mac?
Have you ever troubled with how to backup, clone or copy your favorite DVD to computer as a DVD folder, or an ISO image file, or even to another DVD disc directly? Furthermore, are you still griping about whether copying DVD entirely or just copying DVD with main movie?
more information:mac dvd copy
iSkysoft DVD Copy for Mac is extremely easy-to-use DVD copying software to copy any DVD movie with excellent DVD copying quality in Full Disk Mode or Main Movie Mode. It can copy DVD movie to computer as DVD folder, ISO file, copy DVD to DVD disc; burn ISO file or DVD folder to DVD disc.
Guide - How to copy DVD files easily
Step1. Select DVD Source
Download iSkysoft DVD Copy for Mac and install it. In the “Select Source” field, click and select “Select source DVD folder”. Then browse your computer hard disc and select your DVD movie (either in a folder or from your DVD ROM).
Step2. Select DVD Copy Method
iSkysoft DVD Copy for Mac allows you to copy DVD to a folder on your hard disc or directly burn DVD to a new DVD disc.
In the “Select DVD Copy Method” field, click to select a method to output the selected DVD movie:
If you want to output your DVD movie to a folder on your hard disc, you can select the “Output DVD Folder” option, and specify a directory to save the copied DVD movie.
If you want to directly burn your DVD movie to a new DVD disc, you can just select the DVD ROM where you have inserted a blank DVD disc.
Step3. Program Settings
Set Buffer Directory: Specify a directory on your hard disc as the buffer directory to store the temporary files generated during the conversion. We recommend that you select a folder on a hard disc that has relatively big free space.
Select Language: Select an interface language for the program. The currently available languages are English and Simplified Chinese.
Step4. Start to Copy DVD
Click the Start button to start to copy DVD movie and/or burning it to a new DVD disc.
Note: If you are copying a DVD disc from your DVD ROM to a new DVD disc, iSkysoft DVD Copy for Mac will ask you to insert a blank DVD disc when the program gets ready to burn. Then you can just take the original DVD disc out and insert a blank DVD disc.
on Jun 21, 2010 | Computers & Internet
How can I copy from vcr to dvd without aremote
As for such situation, you may need a DVD Creator.
Leawo DVD Creator can convert video and burn video to DVD-5/DVD-9 content with abundant DIY features to customize DVD movies.
  • Create DVD-5/DVD-9 disc, folder or ISO image files from recorded videos, online videos and other videos;
  • Preset 40+ disc menu and template models for DVD burning, even allow DIY disc menu and template;
  • Convert 2D video to both 3D and 2D DVD movies, with 6 different 3D effects available for choice;
  • Practical and user-friendly video editing features to get customized DVD movies;
  • Fast DVD burning via Intel Quick Sync accelerating technology;
Besides, if it is necessary, you can also use Leawo DVD Copy which can help you copy and backup DVD discs, DVD folders and ISO Image Files to PC or disc, with marvelous bonus features.
  • Copy DVD to DVD disc, file folder and ISO Image File with no quality loss;
  • 1:1 disc to disc duplication while retain original disc quality;
  • Copy DVD-9 to DVD-9, DVD-5 to DVD-5, and even compress DVD-9 to DVD-5 with high quality;
  • Copy DVD contents in different copy modes: Full Movie, Main Movie and Custom Mode;
  • Copy and backup CSS-DVD discs and common DVD discs easily;
Easy to Convert Any Videos to DVD Disc Leawo DVD Copy Software Clone Copy DVD movie to DVD RW disc or hard drive...
Sep 19, 2016 | Televison & Video
Sir i am using acer 4736z i got problem with my dvd driver when i am inserting blank dvd for writing operation it shwos 0 bytes used free sapce 0 bytes not able to write data so what to do pls help me...
you have to make sure you are using the correct format for your drive i.e (+/-)
  • Read: 24X CD-ROM, 24X CD-R, 24X CD-RW, 8X DVD-ROM, 8X DVD-R, 8X DVD+R, 8X DVD-ROM DL (double-layer), 6X DVD-R DL (double-layer), 6X DVD+R DL (double-layer), 8X DVD-RW, 8X DVD+RW, 5X DVD-RAM, 4X BD-ROM, 4X BD-R, 2X BD-RE, 4X BD-ROM DL (double-layer), 4X BD-R DL (double-layer), 2X BD-RE DL (double-layer)
  • Write: 24X CD-R, 16X CD-RW, 8X DVD-R, 8X DVD+R, 6X DVD-RW, 6X DVD+RW, 5X DVD-RAM, 4X DVD+R DL (double-layer), 4X DVD-R DL (double-layer)
8X DVD-Super Multi double-layer drive:
  • Read: 24X CD-ROM, 24X CD-R, 24X CD-RW, 8X DVD-ROM, 8X DVD-R, 8X DVD+R, 6X DVD-ROM DL (double-layer), 6X DVD-R DL (double-layer), 6X DVD+R DL (double-layer), 8X DVD-RW, 8X DVD+RW, 5X DVD-RAM
  • Write: 24X CD-R, 24X CD-RW, 8X DVD-R, 8X DVD+R, 6X DVD-R DL (double-layer), 6X DVD+R DL (double-layer), 6X DVD-RW, 8X DVD+RW, 5X DVD-RAM
Apr 09, 2011 | Acer Computers & Internet
Tip
Dish Network DVD Remote Codes
DVD Codes BRAND COMBO CODE Aiwa DVD 634, 694, 751 Alpine DVD 653 Apex DVD 654, 655, 743, 744, 757 Bose DVD 758 Broksonic DVD 656, 752 Clarion DVD 686 Classic DVD 695 Daewoo DVD 657 Denon DVD 697, 696, 699, 700 Emerson DVD 658, 701 Fisher DVD 659 Funai DVD 658 GE DVD 702, 703 GO Video DVD 692, 693 GPX DVD 704 Hitachi DVD 632, 635, 660, 705, 706, 707 JVC DVD 636, 689, 708, 711 Kenwood DVD 761 Kinka DVD 637, 638, 753 Koss DVD 745 Lasonic DVD 762 Magnasonic DVD 762 Magnavox DVD 626, 661 Memorex DVD 709 Mintek DVD 710 Mitsubishi DVD 629, 767 NAD DVD 701 Nakamichi DVD 763 Norcent DVD 712 Onkyo DVD 713 Oritron DVD 723 Panasonic DVD 639, 662, 663, 714, 715, 716, 717, 734, 765 Philips DVD 640, 641, 766 Pioneer DVD 665, 718, 719 Proscan DVD 720 Qwestar DVD 721, 723 RCA DVD 627, 650, 666, 690, 742, 749 Sampo DVD 724 Samsung DVD 738, 651, 652, 667, 668, 691, 740, 741 Sansui DVD 725, 754 Sanyo DVD 643, 726 Sharp DVD 669, 727, 746 Sherwood DVD 728 Sony DVD 617, 644, 645, 670, 671, 729, 730, 731, 768 Sylvania DVD 658, 764 Teac DVD 732 Technics DVD 733 Techwood DVD 664 Toshiba DVD 616, 646, 647, 672, 735, 736, 750 Yamaha DVD 737, 738, 739 Zenith DVD 648, 673
on Jun 06, 2009 | Toshiba DR410 DVD Recorder
Necesito los codigos para dvd
DVD Apex Digital 0672 0717 0794 1056 0755 0797 1100 0796 1061 DVD Axion 1072 DVD Blaupunkt 0717 DVD Blue Parade 0571 DVD CineVision 0876 DVD Curtis Mathes 1087 DVD CyberHome 1024 1023 0816 DVD Daewoo 0784 DVD Denon 0490 DVD Dual 1068 DVD DVD2000 0521 DVD Emerson 0591 0675 DVD Enterprise 0591 DVD Fisher 0670 DVD Funai 0675 DVD GE 0522 0815 0717 DVD Go Video 0744 0715 0783 DVD GPX 0699 DVD Greenhill 0717 DVD Hitachi 0573 DVD Hiteker 0672 DVD JVC 0558 0623 DVD Kenwood 0490 0534 DVD KLH 0717 1020 DVD Koss 0651 DVD Lasonic 0798 DVD Magnavox 0503 0675 DVD Marantz 0539 DVD Microsoft 0522 DVD Mintek 0839 0717 DVD Mitsubishi 0521 1521 DVD Nesa 0717 DVD Norcent 1003 DVD Onkyo 0503 DVD Oritron 0651 DVD Panasonic 0490 1762 DVD Philips 0503 0539 0646
Jan 13, 2011 | One For All URC-3021 Remote Control
What disks to buy? dvdr dvdrw dvd+ dvd-????
DVD stands for Digital Versatile/Video Disc, DVDR stands for DVD Recordable and DVDRW for DVD ReWriteable. If you're familiar with regular audio/music CDs or regular DVD-Video discs, then you will know what a recordable DVD looks like. A recordable DVD stores up to 2 hours of very good quality DVD-Video, including several audio tracks in formats like stereo, Dolby Digital or DTS and also advanced menu systems, subtitles and still pictures that can be played by many standalone DVD Players and most computer DVD-ROMs. If you choose to lower the video quality it is possible to store several hours video on a recordable DVD using low bitrates and low resolution with video quality more like VHS, SVHS, SVCD, CVD or VCD. It is also possible to have up to 4.37* GB ordinary data or mix DVD-Video and data on a recordable DVD that can be played by most computer DVD-ROMs.
There are three competing DVD Recording standards, DVD-R/DVD-RW and DVD+R/DVD+RW have pretty similiar features and are compatible with many standalone DVD Players and most DVD-ROMs while DVD-RAM has less DVD Player and DVD-ROM compatibility but better recording features.
DVD-R and DVD-RW
DVD-R was the first DVD recording format released that was compatible with standalone DVD Players.
DVD-R is a non-rewriteable format and it is compatible with about 93% of all DVD Players and most DVD-ROMs.
DVD-RW is a rewriteable format and it is compatible with about 80% of all DVD Players and most DVD-ROMs.
DVD-R and DVD-RW supports single side 4.37 computer GB* DVDs(called DVD-5) and double sided 8.75 computer GB* DVDs(called DVD-10).
These formats are supported by DVDForum.
DVD+R and DVD+RW
DVD+R is a non-rewritable format and it is compatible with about 89% of all DVD Players and most DVD-ROMs.
DVD+RW is a rewritable format and is compatible with about 79% of all DVD Players and most DVD-ROMs.
DVD+R and DVD+RW supports single side 4.37 computer GB* DVDs(called DVD-5) and double side 8.75 computer GB* DVDs(called DVD-10).
These formats are supported by the DVD+RW Alliance.
DVD+R DL
DVD+R DL or called DVD+R9 is a Dual Layer writeable DVD+R. The dual layered discs can hold 7.95 computer GB* (called DVD-9) and dual layered double sides 15.9* computer GB (called dvd-18).
DVD-R DL
DVD-R DL or called DVD-R9 is a Dual Layer writeable DVD-R. The dual layered discs can hold 7.95 computer GB* (called DVD-9) and dual layered double sides 15.9* computer GB (called dvd-18).
I got this info from http://answers.yahoo.com/question/index?qid=20071016055835AApo5e6
If your dvdrom supports dvdrw I would suggest buying these disks as you can re-write over them if you need too.
Most recent dvdroms support all of the above.
I hope this helps
Jan 19, 2009 | Electronics - Others
Macbook dvd burning not possible ?
If you don't know how to burn DVD on Mac, I think this step by step guide would help you
http://www.mac-dvd.com/mac-guide/how-to-convert-video-to-dvd-on-mac.html
Jan 13, 2008 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
