How to get rid of error code F 35 - Office Equipment & Supplies
I am having error codes 35 and 75 come up on my induction cooktop
Thank you for your post, friend!
I located that on Electrolux Cooktop error codes "35" and "75" stand for input voltage too low. It could be an issue with your filter board or an issue within the voltages. I would recommend having a professional come out to your cooktop to properly diagnose to avoid any unnecessary part purchases. -Matt
Sep 20, 2014 | Frigidaire 36-Inch Smooth Surface...
Maytag F-35 (suds) error code resolved
Maytag Washer F-35 error code ( SUDS) >> Look for a faulty Pressure switch or bad pressure hose.... Problem solved !
on Aug 04, 2010 | Washing Machines
Error code 35
error code 35?
error codes on the minolta print /copy machines usually have a letter followed by four digits e.g. C2035,
please indicate which model and exact error code with a description of the error as seen by the user.
Sep 25, 2013 | Konica Minolta Office Equipment & Supplies
There is a error code 34 35 in my kawasaki z750,2008.let me know the reason for that
Error Code # 34 - Exhaust butterfly valve actuator sensor malfunction, wiring open or short. Error Code # 35 - Immobilizer amplifier malfunction (Equipped Models) These are the exact error codes from the service manual itself. Good luck.
Sep 16, 2013 | kawasaki Z750 Motorcycles
Toshiba e-studio 35 erreur code 303232
That's not your error code, that's your meter.
Feb 02, 2013 | Toshiba e-Studio 35 Copier
Error code 10 during sound calibration
Please ensure that you have turned on the Accoustimass module, this can cause communication errors when calibrating. Also check that all connections are correctly plugged in as if one is not quite sat right this may give the error, just try unplugging them and plug them back in.
May 31, 2009 | Bose Lifestyle 35 Series II System
Fan control relay error code 35 1995 Voyager
Locate the Fuse Relay Box under the Hood and Locate the Fan Relay and Change it from this Box. The Diagram should be inside the Lid for the Box or in the Owners Manual. Please Rate My Response! Thanks!
Feb 04, 2009 | 1990 Dodge Caravan
I have a problem.error code 35-000,DSR 1500AP.what is this?
error 35-000 on a dsr-1500 is a cassette compartment position error. check to see if something is obstructing the movement of the cassette compartment.
Jan 23, 2009 | Sony DSR-1500 Mini DV VCR
Error code
Problem: The Digital Panel is Reporting Code 34-1, 34-2, 35-1, 35-2 or 36-2 Cause: The copier is having a problem with the fusing unit.
  1. This is occasionally a false alarm. Try turning the copier off for about 10 seconds and turning it back on. If the code doesn’t clear, please call 1-800-877-2679 for service.
Sep 02, 2008 | Office Equipment & Supplies
Konica 1112 Error code 35
The procedure is as follows:
1. Turn machine off.
2. Turn machine on while holding the 2 & 5 keys.
3. Enter 47 on the keypad.
4. Press the Stop/Clear.
5. Enter 0 on the keypad.
5. Press the START PRINT button.
Power the machine off and on to exit the service mode.
You're done!
Mar 26, 2008 | Office Equipment & Supplies
20 people viewed this question
