Question about Watches
ASPEN WATCH MANUAL NEEDED FOR X-JACCE - Watches
How do I get the analog portion of the the Aspen 74041 watch to work?
be shour the battery is good....then there should be a knob on the side... pull it outword 1 click.. then turn the knob(pull out 2 clicks to change the date...)
Jul 17, 2010 | JCPenney Armitron Sport Link Bracelet...
Instructions for ASPEN from Omni Watch & Clock Co.
I could not find any instruction manuals on their web site, so I suggest that you contact them at "info@aspenjewelryandwatches.com" and request instructions.
Feb 16, 2010 | Watches
Need to remove crown stem on a Aspen wristwatch made in China.
on most movements the is a little arrow pointing to a hole. use a pin and push down and the stem should just pull out. please rate my solution
Oct 10, 2009 | Casio Edifice EF106D2AV Wrist Watch
Swatch Irony Aluminium instruction manual needed
hELLO THERE
please go to www.swatch.com and look for you brand and type there will be a online manual that you can use and download and print if needed ok?
best regards mike
Aug 05, 2009 | Swatch Irony watch
Aspen watch
this should work with your aspen watch let me know if it doesn't
http://dive.scubadiving.com/members/gearreviews.php?s=593
Quote
For the alarm: If you want to use it (I think both it and the light use battery faster than when not used), you set it by pushing mode button twice, as indicated above, then go to hour or minute setting by pushing the lap/reset button, and advance to the time you want by pressing the start/stop button. Pushing mode will take you back to normal time again.
To turn alarm on or off, hold lap/reset button in and at the same time push the start/stop button. Alarm icon will show on or off. When you release the lap/reset button, it will revert to normal time.
If the alarm is on, at the designated time it will start beeping for awhile or until the lap/reset button is pushed (off) or start/stop button (snooze).
Aug 08, 2008 | JCPenney Armitron Sport Link Bracelet...
Aspen watch
Setting my Aspen Digital Watch
Button designations:
(NITEGLOW) B C (START/STOP)
10:47
(MODE) A D (SPLIT/RESET)
To Set Time, Date and Day:
Press A 3 times; Seconds Flash; Set to 00 with C
Press D; Minute Flashes; Set Minutes with C
Press D; Hour Flashes; Set Hours with C
Press D; Date Flashes; Set Date with C
Press D; Month Flashes; Set Month with C
Press D; Day Flashes; Set Day with C
Press A to Quit
To Set Alarm Time:
Press A 2 times; Hour Flashes; Set Hour with C
Press D; Minutes Flash; Set Minute with C
Press A to Quit
To Set Alarm ON or OFF:
Hold D in to see Alarm Time and Press C to toggle Alarm ON/OFF
Operation:
Hold C to see Month and Day.
Hold D to see Alarm Time; Press C to toggle Alarm ON/OFF.
Mar 27, 2008 | JCPenney Armitron Sport Link Bracelet...
Instruction Manual
I don't know where you can get an instruction manual but have you tried pulling out the crown where you set the watch half a click. After you do that turn the crown away from you to set the day and towards you to set the month.
Mar 08, 2008 | Versace 27473-008-00 Wrist Watch
Aspen digital watch
threw it away!
Feb 16, 2008 | Watches
Product came with no instructions
duplicate post - go to this thread http://www.fixya.com/support/t136982-no_instructions :)
Mar 09, 2007 | Casio W752V3AV men's watch
Watches Logo
325 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
