Question about The Computers & Internet
How can i fix the battery issue?
I have a 3.7V lithium battery not working properly and over heating where the charge plug is this has been an issue since day 1.
  • The Master
  • 2,045 Answers
Replace it using warranty policy
Posted on Apr 25, 2017
Hi, I have a new ryobi touch start weedeater. I have used it twice. I charged it overnight for first use. It worked fine. After 2nd use ran out of charge so I re charged it . It doesn't seem
If it doesn't seem to be recharging or taking a full charge, check the charging jack to make sure no foreign object (leaf debris, etc) got into it. If it is clean, then you probably have a warranty issue with the battery or charging system.
Note: do not leave the string trimmer out in the sun or outdoors in cold weather while it is charging. The charging process only works properly at room temperature. In particular, lithium batteries are very finicky about charging conditions. Charging overheated lithium batteries can cause a fire, so they have a safety circuit to prevent charging outside the proper temperature range.
Nov 30, 2014 | Ryobi Garden
My IPhone will not turn on. It suddenly went off, like it powered down, but wont turn back on after a 20 minute charge...even when still plugged into charger.
Try to connect it with you PC via usb cabal...and if your PC shows that he founds device (Iphone), you will see on Iphone screen that he is start charging...after that you can put it to electicity charging, with regular adapter and charge it for 1 hour and then turn it on and it will work :) That happens when battery lose her voltage (need to be 3,7V)...Otherwise if you PC, when you connect it does not show nothing, than you have some hardware failure and you need to take you Iphone to some mobile service to fix it..
Best Regards!
Sep 05, 2013 | Cell Phones
Why so long when i'm charging my lenovo a1-07 ideapad
Frequent Charging Shortens Battery Life Frequent charging shortens the life span of a Lithium ion battery. Batteries should be charged only after they expend all their power. b> Switching Batteries Switching batteries helps preserve battery life: If a cell phone or computer user puts in a spare battery while separately charging the primary Lithium ion battery, that helps extend the life of both batteries. b> Removing Batteries Most laptops charge the battery when a user plugs in the AC adapter. Users can adjust this setting by changing the power options. Windows places this option in the Control Panel, while the Gnome Linux desktop places power options under "Administrative Tools". Cell phones incorporate their own power-saving features that the user usually cannot control. b> When to Replace a Lithium Ion Battery If a laptop battery does not hold a charge for more than a few minutes, a user must replace the Lithium ion battery if he wants to use the computer without an AC adapter. Other Ways to Extend Battery Life Storing a battery in a cool, dry environment causes a lithium-ion battery to last a little longer and reduces the frequency of needed battery replacements. Hope this helps.
Dec 29, 2012 | Lenovo IdeaPad A1 Tablet with 16GB Memory...
There is an issue with the laptop charging circuit as the machine indicated plugged in, charging. However, it did not charge at all. Laptop work fine with AC Adaptor.
How old is your battery? Lithium ion based batteries normal life is 2 years starting from the date of manufacture, sometimes even less. Try using another battery and see if it will charged properly. You can also use the adapter in a compatible laptop and check if it will charge the battery.
Jan 11, 2011 | Computers & Internet
Does it harm a Ryobi 18v lithium battery to leave on Charger?
Lithium-Ion batteries require careful charging and temperature monitoring while in the charger. Ryobi's Charging station monitors many functions and shuts off when the battery has gone through a complete charge. This is indicated by a steady Green light. Once the Charge indicator is a steady green the charger stops charging. With any battery It will slowly discharge and I don’t think the Ryobi will maintain a battery that is never removed. For example, if after a complete charge cycle if the battery was left there for 2 years and then you went to use it, it would likely be completely discharged. However if the battery charger is unplugged then plugged back in a new charge sequence would start. I lose power at my house about every 6 months or so. Once power is restored a new cycle would start and the charging cycle begins again.
Hope this helps and have a great day.
Apr 01, 2010 | Ryobi Two 18V Lithium-Ion Batteries +...
My battery on lm70 express laptop only charges to 70%.fitted new but same problem.charged in another comp.and charged fine.
How do you know that it has charged to 70% and it is the correct percentage on your Laptop?May be you need some other program that are available on the internet that will tell you the exact charge percentage. Make note that In many ways, lithium-ion is superior to nickel and lead-based chemistries and the applications for lithium-ion batteries are growing as a result. Short battery life in a laptop is mainly cause by heat rather than charge / discharge patterns.Removing the battery from the laptop when running on fixed power protects the battery from heat. Make sure the AC Adapter that you are using [on both laptops] is supplying the correct voltage and if possible check with Load.
Jul 08, 2009 | Computers & Internet
Computers & Internet Logo
Top The Computers & Internet Experts
Perry Ralston
Level 1 Expert
ashu k...........
Level 1 Expert
ted dux
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
